Question about Kenmore Refrigerators
Why is or fridge leaking water out the bottom. Bottom mount fridge, checked the water try in the back, no cracks, no leaking, Twice in four days days it leaks water on the floor. No problems cooling, everything else works great.
I've seen this occur when the refrigerator door is getting closed fully Either a food item is preventing complete closure, (though it may look closed) or a seal is failing. Check the seals by pulling a dollar bill out from in between the seals. If it doesn't catch make sure the seals around the doors are ingood shape and clean.You can also use a heat gun to warm -up the seal and get to expand so you get a good suction
Posted on Oct 15, 2010
Maytag bottom freezer refrigerator, leaks from the bottom.
As with all electrical, before you touch make sure the power is off! Taje the plug out, and make sure it stays out! Tie a plastic bag around the plug! Now, empty the fridge and freezer, and defrost, you can use hot water bottles and gave the hearing on in te house, be careful using hair dryers, you can warp or crack the plastic inner housing of your fridge or freezer.
Check on you tube or the Internet it Manuel whee the drain hole is! Get a funnel and out boiling water down, just in case there is any ice here. Then with a piece of wire (old cable )prod clean this drain hole. Check the internal plastic of the freezer for cracks or damage, use a torch and your hand. If cracks or damage is visible, you are safer with a bee freezer! Remember water and electrics can be fatal!
Think safe, be safe, remember it could be your child or partner killed just by touching the freezer if the water and ekectrics are causing a short. If there is no damage or cracks then plug in, and jet the freezer freeze, check for Leaks, if you have no leaks then happy days! If you still have leaks.......off to the electrical shops...... But to save shoe leather and time, have a look online, write prices down, see what warranties you are getting. Good luck
Mar 19, 2016 | Maytag Refrigerators
Refrigerator leaks
If it a frost free fridge it should self defrost every 6 to 8 hours all by its self. If you see ice or frost buildup in side the freezer usually back wall harder to notice if the cooling fins are just under the freezer floor but above the fridge ceiling or better picture it as the fridges taint. Sounds like the fridge is having defrost problems and if it every once in awhile does go into defrost or you do it, all that water flows down a hose and out the back around the compressor. Heat from the compressor or other gadgets evaporate the water. If it only defrost a few times a year it is going to overflow the catch basin. Easy to check some times catch basin or drain hose move check back bottom or remove front cover look if bottom catch basin. Main fault is defrost timer stuck in run, location all over in or out, defrost element around cooling fins,defrost thermostat on cooling fins,wiring to / from / joining the last two.
Mar 17, 2017 | KitchenAid KBRP20ERSS Stainless Steel
Leaking water from inside the fridge once or twice a day.
Usually if a refrigerator is holding water this means that the condensate from the freezer is not going down into the pan in the bottom, the water has to go somewhere so it ends up in your refrigerator. Find the drain line in the bottom and try some how to blow it out, if you can do this and clean the pan you should be ok. let me know.
Mar 11, 2011 | Fisher and Paykel Refrigerators
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
My refrigerator started leaking underneath on the right back side. Can you tell me what is wrong and what needs to be done?
If you have icemaker in your fridge - remove cover on the back and down and check the plastic water tubing for cracks and loose connections.
If nothing found or you don't have icemaker - there is a drain pan on the bottom, behind the same back cover. Check if it has any cracks or tilted. Check if the drain tube is routed to the drain pan and is securely attached to the drain port on the bottom of the fridge.
Oct 12, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Water leaking
hi. thanks for the question. the problem you have is with a clogged drain . pull fridge away from wall .remove back panel . clean all coils. locate the drain tube from fridge. clean. thanks the appliance doc
Oct 04, 2008 | GE Profile PSI23NCR Side by Side...
Water leaking from fridge
Hello I had a problem close to this, at the back of the fridge on the bottom you should find the motor ,sitting on top of the motor there should be a small cream plastic catch tray if you dont have one this may be the problem as the motor evaporates the excess water, Hope this helped. djdizzys
Feb 14, 2008 | Refrigerators
Refrigerators Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
