Question about Home
Can't find PInvoke Dll 'SCNAPI32.dll' - Home
SOURCE: OVTFBoot.dll
OK ya must be trying to install into Vista? anyway whats happening is ya NOT using Admin mode... and that DLL isn't being allowed to be put in the system32 dir... so disable UAC open admin prompt and find it, & copy .. so after ya install find the DLL on the install media .. then copy and paste it to ya windows\system32\ dir.. register it if reqiured should be all good.
Better still install properly with admin rights and such. GL
Posted on Jul 29, 2008
SOURCE: hpxp2436.dll
HP scanjet 2400 free download
Posted on Dec 17, 2008
SOURCE: trouble with slbcsp.dll and sccbase.dll
Taken from forum.cnet by QuinS33
Instructions:
Firstly, delete all the copies of the dll you obtained from everywhere. There should only be one copy of each in the C:\WINDOWS\system32\ folder.
Then you need to become familiar with regedit. Its a pretty easy utility to learn, but don't mess around with stuff you could really mess stuff up. To start it up, go to the start menu, click run..., and type in regedit. We are a quarter of the way to fixing this now. Stay strong!
To get this to work you are going to need those two subkeys in your registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Cryptography\Defaults\Provider\Schlumberger
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Cryptography\Defaults\Provider\Infineon
You can get to these paths through regedit. The two subkeys (keys are the things that look like folders in regedit): "Schlumberger Cryptographic Service Provider" and "Infineon SICRYPT Base Smart Card CSP" need to be created in the Provider key. In order to do this click on the Provider key and in the Edit menu click on new... then key in the submenu. Do this twice and rename the created keys:
[Halfway there now!]
Okay, lets get crazy and add some info to these keys. Click on the keys you created. You should have one value in the window to the right . It should be named (default) and it should have (value not set). This is fantastic. Right click in the window to the right with the default value. In the new menu, click on string value. A new string value will be created you need to rename this value "Image Path" then right click it, and select "modify". Set the value to C:\WINDOWS\system32\slbcsp.dll for Schlumberger and C:\WINDOWS\system32\sccbase.dll for Infineon.
[3/4 of the way done]
Two both of the created subkeys add two DWORD values the same way you added the string values. These values should be named "SigInFile" and "Type". Simply modify the Type one to have a value of one (hexidecimal or decimal ... it doesn't matter numbers 1 - 9 are the same in both bases). Done!
That should do it for your pirated copy of windows, which is probably a crippled copy of windows used for corporations with lots of workstations that doesn't require a key. If you are going to pirate OS software you NEED to learn your intermediate computer skills like regedit and batch commands etc... Don't be lazy and expect everything to work for free and then complain about some customer service not getting back to you in a timely manner. And don't post anything else here except thank you cause I just fixed your problem for FREE on my own time. Good luck.
Posted on Apr 29, 2009
SOURCE: I cannot find "hpxp2436.dll"
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/hpxp2436.dll/
as I registered few dll's from this site as it is free...worked in my case :)
Posted on Jan 06, 2011
SOURCE: I need the drivers for my computer but cannot find
try this home web of nvidia ;-)
http://www.nvidia.com/Download/index.aspx?lang=en-us
Posted on Jan 11, 2011
Windows 7 Media Player 12.0.7601.17514 configuration setting are corrupted and remain corrupted after resetting the Media Player to its default settings. How do I completely rebuild the default Media
You may be able to remove then put back WMP from Programs and Features in Control Panel. Click on add/remove features and you should see it there. Uncheck the box and apply. Restart afterwards then check the box and apply. May require another reboot.
Jan 14, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Tip
Add Remove Programs list is blank -- Windows 2000
Usually It happens due to some virus activity or any corruption in system files. So when you go to Add Remove Programmes, It shows nothing but a blank space.
· To resolve this issue with Internet Explorer 6.0 installed, repair Internet Explorer 6.0:
Click Start, and then click Run.
Paste the following command in the Open box, and then click OK:
rundll32 setupwbv.dll,IE6Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
Because this command is case sensitive, you should copy the command, and then paste the command in the Open box.
· To resolve this issue with Internet Explorer 5.0 or 5.5 installed, repair Internet Explorer 5.0 or 5.5:
rundll32 setupwbv.dll,IE5Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
If the Add/Remove Programs tool still does not function properly, shows no content, or if you want to try to fix this issue without upgrading to later versions of Internet Explorer, check the following registry keys to make sure that they contain entries:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache
Note If the previous registry keys are blank, the Add/Remove Programs tool may also be blank.
Use the command line REGSVR32 [path\filename] to register each of the following files:
%systemroot%\System32\Appwiz.cpl
%systemroot%\System32\Mshtml.dll
%systemroot%\System32\Jscript.dll
%systemroot%\System32\Msi.dll
Program Files\Common Files\System\Ole DB\Oledb32.dll
Program Files\Common Files\System\Ado\Msado15.dll
%systemroot%\System32\Msdart32.dll [not registerable]
%systemroot%\System32\Mshtmled.dll
%systemroot%\System32\Mswstr10.dll [not registerable]
If the Add/Remove Programs tool displays incomplete information or is blank, verify the file dates. Where possible, register the following files:
%systemroot%\System32\Gdi32.dll [not registerable]
%systemroot%\System32\User32.dll [not registerable]
%systemroot%\System32\Msvcrt.dll [not registerable]
%systemroot%\System32\Ole32.dll
%systemroot%\System32\Shlwapi.dll [not registerable]
%systemroot%\System32\Imm32.dll [not registerable]
%systemroot%\System32\Indicdll.dll [not registerable]
%systemroot%\System32\Urlmon.dll
%systemroot%\System32\Version.dll [not registerable]
%systemroot%\System32\Lz32.dll [not registerable]
%systemroot%\System32\Comctl32.dll [not registerable]
%systemroot%\System32\Clbcatq.dll
%systemroot%\System32\Oleaut32.dll
%systemroot%\System32\Mlang.dll
%systemroot%\System32\Shell32.dll
%systemroot%\System32\Shdoclc.dll [not registerable]
%systemroot%\System32\NetapI32.dll [not registerable]
%systemroot%\System32\Secur32.dll [not registerable]
%systemroot%\System32\Netrap.dll [not registerable]
%systemroot%\System32\Samlib.dll [not registerable]
%systemroot%\System32\Ws2_32.dll [not registerable]
%systemroot%\System32\Ws2help.dll [not registerable]
%systemroot%\System32\Wldap32.dll [not registerable]
%systemroot%\System32\Dnsapi.dll [not registerable]
%systemroot%\System32\Wsock32.dll [not registerable]
%systemroot%\System32\Plugin.ocx
%systemroot%\System32\Wininet.dll [not registerable]
%systemroot%\System32\Crypt32.dll [not registerable]
%systemroot%\System32\Msasn1.dll [not registerable]
%systemroot%\System32\Msls31.dll [not registerable]
%systemroot%\System32\Imgutil.dll
%systemroot%\System32\Cscui.dll
%systemroot%\System32\Cscdll.dll [not registerable]
Now Restart your system.. and Voila !!
Your problem is gone..
on Jan 24, 2010 | Computers & Internet
Whenever i try to install win 7 with xp in dual boot configuration,i receive a error at xp logon page saying "a problem is preventing windows from accurately checking the license of this...
To fix that problem,
Open your computer in safe mode,
open a command promt
Register the following DLL s
it should be in the %system root% \ system32 folder
just type the following statements one by one and see you got success information popup
regsvr32 licwmi.dll
regsvr32 regwizc.dll
regsvr32 licdll.dll
regsvr32 jscript.dll
regsvr32 vbscript.dll
regsvr32 msxml.dll
regsvr32 shdocvw.dll
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 initpki.dll
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 sccbase.dll
regsvr32 slbcsp.dll
regsvr32 cryptdlg.dll
then try to restart,
Aug 11, 2011 | Computers & Internet
When I right click on a website that is sent to me in my email, I choose, open in a new tab or window, I get this message on many of the links to websites sent to me by email. oops Internet Explorer could...
Dear klaireh,
Follow this steps to resolve the problem with opening links in outlook .
(In this resolution we are going to register the DLL files for the internet explorer and outlook )
1. Copy the whole command line below and paste it in a notepad .
2.Save the file as internet.bat
3.Right click on the file and click RUN AS ADMINISTRATOR
cd /d %SystemRoot%\system32
regsvr32 comcat.dll /s
regsvr32 shdoc401.dll /s
regsvr32 shdoc401.dll /i /s
regsvr32 asctrls.ocx /s
regsvr32 oleaut32.dll /s
regsvr32 shdocvw.dll /I /s
regsvr32 shdocvw.dll /s
regsvr32 browseui.dll /s
regsvr32 browseui.dll /I /s
regsvr32 msrating.dll /s
regsvr32 mlang.dll /s
regsvr32 hlink.dll /s
regsvr32 mshtml.dll /I /S
regsvr32 mshtmled.dll /s
regsvr32 Wininet.dll /I /S
regsvr32 msjava.dll /S
regsvr32 urlmon.dll /s
regsvr32 softpub.dll /S
regsvr32 wintrust.dll /s
regsvr32 initpki.dll /s
regsvr32 Dssenh.dll /s
regsvr32 rsaenh.dll /s
regsvr32 Gpkcsp.dll /s
regsvr32 sccbase.dll /s
regsvr32 Slbcsp.dll /s
regsvr32 plugin.ocx /s
regsvr32 sendmail.dll /s
regsvr32 scrobj.dll /s
regsvr32 mmefxe.ocx /s
regsvr32 corpol.dll /s
regsvr32 jscript.dll /s
regsvr32 msxml.dll /s
regsvr32 msxml3.dll /s
regsvr32 mssip32.dll /s
regsvr32 imgutil.dll /s
regsvr32 thumbvw.dll /s
regsvr32 cryptext.dll /s
regsvr32 rsabase.dll /s
regsvr32 inseng.dll /s
regsvr32 iesetup.dll /i /s
regsvr32 cryptdlg.dll /s
regsvr32 actxprxy.dll /s
regsvr32 dispex.dll /s
regsvr32 occache.dll /s
regsvr32 occache.dll /i /s
regsvr32 iepeers.dll /s
regsvr32 urlmon.dll /i /s
regsvr32 cdfview.dll /s
regsvr32 webcheck.dll /s
regsvr32 mobsync.dll /s
regsvr32 pngfilt.dll /s
regsvr32 licmgr10.dll /s
regsvr32 icmfilter.dll /s
regsvr32 hhctrl.ocx /s
regsvr32 inetcfg.dll /s
regsvr32 tdc.ocx /s
regsvr32 MSR2C.DLL /s
regsvr32 msident.dll /s
regsvr32 msieftp.dll /s
regsvr32 xmsconf.ocx /s
regsvr32 ils.dll /s
regsvr32 msoeacct.dll /s
regsvr32 inetcomm.dll /s
regsvr32 msdxm.ocx /s
regsvr32 dxmasf.dll /s
regsvr32 l3codecx.ax /s
regsvr32 acelpdec.ax /s
regsvr32 mpg4ds32.ax /s
regsvr32 voxmsdec.ax /s
regsvr32 danim.dll /s
regsvr32 Daxctle.ocx /s
regsvr32 lmrt.dll /s
regsvr32 datime.dll /s
regsvr32 dxtrans.dll /s
regsvr32 dxtmsft.dll /s
regsvr32 WEBPOST.DLL /s
regsvr32 WPWIZDLL.DLL /s
regsvr32 POSTWPP.DLL /s
regsvr32 CRSWPP.DLL /s
regsvr32 FTPWPP.DLL /s
regsvr32 FPWPP.DLL /s
regsvr32 WUAPI.DLL /s
regsvr32 WUAUENG.DLL /s
regsvr32 ATL.DLL /s
regsvr32 WUCLTUI.DLL /s
regsvr32 WUPS.DLL /s
regsvr32 WUWEB.DLL /s
regsvr32 wshom.ocx /s
regsvr32 wshext.dll /s
regsvr32 vbscript.dll /s
regsvr32 scrrun.dll mstinit.exe /setup /s
regsvr32 msnsspc.dll /SspcCreateSspiReg /s
regsvr32 msapsspc.dll /SspcCreateSspiReg /s
exit
Sep 20, 2010 | Microsoft Internet Explorer 8
I cant update my computer. i receive error 0x80070424. im running vista home premium
Some spyware, adware, viruses block the windwows update sites.
If this doesn't work
The above explanation was for a previous Version of BITS but, there has been
an update for BITS since Vista came out.
<http://support.microsoft.com/kb/939159>
Is BITS disabled ? It can be set to Manual and the system will update
successfully but, will not update if BITS is Disabled.
Suggest you run the BITS Repair Tool to see if that helps resolve the issue
after installing the update for it:
<http://support.microsoft.com/kb/940520>
Ensure you do not have "Vundo". Clean it up if you do.
It seems possible that your Windows installation has been deliberately
damaged by a trojan (Vundo, along any uninvited guests. (SDBot and ZLOB, all
protected by a rootkit.)) so as to prevent you updating your system or
removing the trojan.
Your first priority must be to cleanse your PC of all malware.
A very good antimalware app is SUPERAntiSpyware.
There is a free version (on demand scanning only), the paid for version
includes active monitoring, similar to Windows defender:
<http://www.superantispyware.com/>
The trial version of SUPERAntiSpyware Pro (SAS):
<http://www.superantispyware.com/superantispywarefreevspro.html>
Can't fix BITS - Windows Update
<http://www.microsoft.com/communities/newsgroups/en-us/default.aspx?&lang=en&cr=US&guid=&sloc=en-us&dg=microsoft.public.windowsupdate&p=1&tid=307d2 1a2-eb9a-4859-b139-78997305deff&mid=307d21a2-eb9a-4859-b139-78997305deff>
This will give you a starting point for your troubleshooting anyway.
Please let us know if the problem remains
I hope this helps (it should)!
Download this "Update for Background Intelligent Transfer Service (BITS) 2.0 and WinHTTP 5.1 (KB842773)"
from link below
http://www.microsoft.com/downloads/details.aspx?FamilyId=B93356B1-BA43-480F-983D-EB19368F9047&displaylang=en
It should fix your problem if you are using Genuine Windows.
Dec 27, 2009 | Acer Aspire 5720 Notebook
Problem with accessing and sending mail from yahoo account
Re-register the following .dll files:
Softpub.dll
Wintrust.dll
Initpki.dll
Dssenh.dll
Rsaenh.dll
Gpkcsp.dll
Sccbase.dll
Slbcsp.dll
Cryptdlg.dll
To re-register these files, follow these steps:
1.
2.
In the Open box, type cmd , and then click OK.
3.
At the command prompt, type the following lines and press ENTER after each line:
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 slbcsp.dll
4.
Click OK when you receive the message that DllRegisterServer in FileName succeeded.
5.
Type exit .
Mar 23, 2009 | Microsoft Windows Vista Business Edition...
Trojan - antivirus-xp-pro-2009
Take my notes as a guide and hopefully this will work for you.
1. Start > Run > msconfig > “Start Up” tab > Disable All
2. “Services” tab > Check box “Hide Microsoft Services” > Disable All
2.5 Exit out, but don't reboot yet
3. Start > Right-click “My Computer” > “Properties” > “System Restore” > Check box “Turn off restore on Hard disks”
4. Start > Run > type %temp% > Edit Select All > Shift-Delete
Reboot machine
1. Combofix.exe. This program will run on its own. Also, it will likely wish to reboot the machine. Let it complete.
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
2. WinSockFix.exe. This will fix any issues with the network connection.
3. SuperAntispyware.exe. This will remove all remaining spyware, tracking cookies, and browser hijackers.
Check to see that your favorite internet browser is working. Install or re-enable your favorite antivirus that failed to catch this in the first place.
Stop WinAntiVirus2008 Processes:
mav_startupmon.exe
uwa7pcw.exe
rtasks.exe
WinAv.exe
wa7pinst.exe
Remove WinAntiVirus2008 Registry Values:
2178F3FB-2560-458f-BDEE-631E2FE0DFE4
6F520BE0-9B54-4558-816F-224E67997DF3
459F4226-1AAB-43B6-9DC1-B6313EF83749
1AC5C88A-DEA7-462b-A232-04AF5CA42E7E
723D54C7-7483-4EB8-8EED-CE5B2AEA534D
Find and Delete these WinAntiVirus2008 Files:
WinAntiVirus Pro
WinAv.exe
uwa7pcw.exe
mav_startupmon
mav_startupmon.exe
rtasks
rtasks.exe
wa7pinst.exe
IH.exe
WinAntiVirus Pro.lnk
Reinstall or Uninstall WinAntiVirus Pro.lnk
WinAntiVirus Pro Manual.lnk
WapCHK.dll
rpt.dll
awvtr.dll
yayyvsp.dll
fcyxx.dll
gebxyax.dll
asmngr.dll
fopnl.dll
IEFWBHO.dll
Scnkrnl.dll
settings.dll
sqlite3.dll
WAV6COM.dll
winpgi.dll
BORLNDMM.dll
SCANADWR.dll
SCANBCDR.dll
SCANLDR.DLL
SCANDOS1.dll
SCANEMUL.dll
SCANFUNC.dll
SCANMCRL.dll
SCANOTHR.dll
SCANSCR.dll
SCANTOOL.dll
SCANTROJ.dll
SCANWIN1.dll
UNACPU.dll
UNADBX.dll
unamscan.dll
UNMIME.dll
UNPACK.dll
UNPACKS.dll
UNPACKS2.dll
UNPEPACK.dll
Vista
Stop WinAntivirus2008 Processes:
(Learn how to do this)
WinAntivirus2008.exe
mav_startupmon.exe
uwa7pcw.exe
rtasks.exe
WinAv.exe
wa7pinst.exe
Find and Delete these WinAntivirus2008 Files:
%UserProfile%\Desktop\Viruses.bdt
%UserProfile%\Desktop\WinAntivirus2008.lnk
c:\Program Files\WinAntivirus2008
c:\Program Files\WinAntivirus2008\Viruses.bdt
c:\Program Files\WinAntivirus2008\VRM2008.exe
c:\Documents and Settings\All Users\Start Menu\Programs\WinAntivirus2008
c:\Documents and Settings\All Users\Start Menu\Programs\WinAntivirus2008\WinAntivirus2008.lnk
%UserProfile%\Application Data\Microsoft\Internet Explorer\Quick Launch\WinAntivirus2008.lnk
%UserProfile%\Application Data\Mozilla\Firefox\Profiles\s1jqw0bz.default\cookies.sqlite
WinAv.exe
uwa7pcw.exe
mav_startupmon
mav_startupmon.exe
rtasks
rtasks.exe
wa7pinst.exe
IH.exe
WapCHK.dll
rpt.dll
awvtr.dll
yayyvsp.dll
fcyxx.dll
gebxyax.dll
asmngr.dll
fopnl.dll
IEFWBHO.dll
Scnkrnl.dll
settings.dll
sqlite3.dll
WAV6COM.dll
winpgi.dll
BORLNDMM.dll
SCANADWR.dll
SCANBCDR.dll
SCANLDR.DLL
SCANDOS1.dll
SCANEMUL.dll
SCANFUNC.dll
SCANMCRL.dll
SCANOTHR.dll
SCANSCR.dll
SCANTOOL.dll
SCANTROJ.dll
SCANWIN1.dll
UNACPU.dll
UNADBX.dll
unamscan.dll
UNMIME.dll
UNPACK.dll
UNPACKS.dll
UNPACKS2.dll
UNPEPACK.dll
Remove WinAntivirus2008 Registry Values:
5222008A-DD62-49c7-A735-7BD18ECC7350
HKEY_CURRENT_USER\Software\WinAntivirus2008
WinAntivirus 2009
# 1. Find and Remove the following Antivirus 2009 Processes:
* av2009.exe
# 2. Find and Remove the following Antivirus 2009 files and folders:
* C:\Program Files\Antivirus 2009
* C:\Program Files\Antivirus 2009\av2009.exe
* c:\WINDOWS\system32\scui.cpl
* c:\WINDOWS\system32\winsrc.dll
# 3. Find and Remove the following Antivirus 2009 files and folders:
* HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\ CurrentVersion\Run\15358943642955870504508370025739
Mar 06, 2009 | Microsoft Windows XP Home Edition Service...
Internet explorer raised unhandled exception in third party module IE will not start and the below call stack pops up every time. BASE:16940000,001B:1699D18C WINUTIL5.DLL,...
hi there,
it seems u got a big problem with ie7,
this is what is get right : Internet Explorer Unhandled Exception
> Internet Explorer raised unhandled exception in third party module and
> should be closed. We are sorry for inconvinience.
> Extended Exception Information
> Module: urlmon.dll
> Version Info: UNICODE; v.4, 0, 2, 3
> Call Stack:
> BASE:7E1E0000,001B:7E21B5CE urlmon.dll
> BASE:7E1E0000,001B:7E1F3FD9 urlmon.dll
> BASE:7E1E0000,001B:7E2150F2 urlmon.dll
> BASE:7E1E0000,001B:7E203342 urlmon.dll
> BASE:7E1E0000,001B:7E1FCD5C urlmon.dll
> BASE:7E1E0000,001B:7E1FCD32 urlmon.dll
> BASE:7E1E0000,001B:7E1FCB8C urlmon.dll
> BASE:7E1E0000,001B:7E1FCB69 urlmon.dll
> BASE:7DC30000,001B:7DE84E02 mshtml.dll
> BASE:7DC30000,001B:7DD69D68 mshtml.dll
> Restart Internet Explorer Close
there is a simple solution for that just follow these steps and than all will go good
I would recommend resetting it to it's default state. This usually takes care of any problematic plug-ins. below has details on how to do this.
1. Click the Tools menu, and then select 'Internet Options.
2. Next, click on the Advanced tab to the far right and click Reset.
3. Another dialog box will then open up, click Reset.
4. Once IE7 is done restoring to the default settings, click Close and then OK.
5. Close any browsers you may have had open and restart it. Everything should now be reset to the default.
or for just click this link and than click on download and run ie7 new
Dec 18, 2008 | HP Pavilion dv6000z Notebook
Videos
try this works for me
Fixing Internet Explorer Javascript Links
Sometimes in IE when you try to open links that open in new windows, they don't open. At the bottom left of the IE window you will see a yellow triangle which indicates its a Javascript problem.
  1. Start » Run » Type regsvr32 /s URLMON.dll
  2. Then do the same but change the DLL names to the following:
    scrrun.dll
    Msxml.dll
    Mshtml.dll
    Shdocvw.dll
    Browseui.dll
    Msjava.dll
    Actprxy.dll
    Jscript.dll
    Vbscript.dll
    oleaut32.dll
  3. Restart IE and your links should be fine.
  4. Alternatively you can copy this in to a text file and save it as a batch file (.bat file)
    regsvr32 /s scrrun.dll
    regsvr32 /s Msxml.dll
    regsvr32 /s Mshtml.dll
    regsvr32 /s Shdocvw.dll
    regsvr32 /s Browseui.dll
    regsvr32 /s Msjava.dll
    regsvr32 /s Actprxy.dll
    regsvr32 /s Jscript.dll
    regsvr32 /s Vbscript.dll
    regsvr32 /s oleaut32.dll
  5. This will re-register all the DLL files. All of the above are used by IE.
Oct 11, 2008 | YouTube Videos
Windows xp updates
Why don't you try using this website, Reimage.com - its mainly for power users and PC repair professionals.
Jan 26, 2008 | HP Officejet 4215 All-in-One Color Photo...
Home Logo
1,365 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
