How i make the racord motherboard - with wires to the front panel ? PWR, HDLED, RST,etc... I want, please , the scheme. Thanks... P.S. The name of the motherboard is MATSONIC 8167 C
  • 32 Answers
ASUS MOTHERBOARD A7V8X-X FRONT PANEL WIRING DIAGRAM
Most of the wires on the front panel are just for LED Lights other than the Power Button. Look on the motherboard for the abbreviated spellings of PWR for the Power Button, RST for Reset, HDD for Hard Drive, etc. Only the PWR will keep your system from booting up. If you place the others on the wrong set of pins the Led light will not illuminate.
Jun 02, 2012 | ASUS Computers & Internet
I have an MS-7502VER:1.2 motherboard and i cannot find wher to plug the power switch into
Hi scouts692
The Front Panel Header Pin arrangement for this motherboard is unusual, in that the header only appears to have 8 pins in a single column rather 2 parallel columns of 6 Pins with 1 blank, as most conventional motherboards do.
Pin 1 is POWER SWITCH orange or red (PWR SW 1)
Pin 2 is POWER SWITCH white or black (PWR SW 2)
Pin 3 is POWER LAD + (PWR LED -)
Pin 4 is POWER LED - (PWR LED +)
Pin 5 is HARD DRIVE LED - (HD LED -)
Pin 6 is HARD DRIVE LED + (HD LED +)
Pin 7 is RESET SWITCH blue or green (RST SW/RST 1)
Pin 8 is RESET SWITCH white or black (RST SW/RST 2)
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 17, 2011 | Intel Motherboard
Problem with the MSI 7050 v2.0 (HP dx5150) Motherboard Front panel wiring colour diagram please.... PWR LED, HDD LED, PWR SW, AND RST SW
You should read manual of the moterboard, there is wiring diagram that you need. But however, i suggest to you - take it to the expert, if you don't know how to do it.
May 20, 2011 | Intel Motherboard
How can i correct the front panel connections
your motherboard has three sockets for the front panel connection:
-USB socket, to connect any front usb ports you might have
-AUDIO socket, to connect speaker/microphone socket on the front of your case
-FRONTPANEL socket, where are connected the turn on/reset buttons, the ide/power leds and the buzzer. To connect all the pin in the right way, refer to the attached picturefranzer_2.jpg
Hope it helped,
Franz
Mar 02, 2011 | Gigabyte GA-8SMML Motherboard
I need a diagram showing all power/pin connections for e210882 motherboard,hard drive and disc drives.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19492&keyword=%22e210882%22&lang=eng
read on this page.
"e210882" are not indicative of board model.
try download cpu-Z (you can download on this page http://www.cpuid.com/softwares/cpu-z.html) run it and find your motherboard model.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Mar 01, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
How do i wire-up the: ( eg. power l.e.d., HD led, reset led ect. to the board
The various wires from the case front panel should be labeled to indicate power LED, HD LED, etc.
The motherboard front panel jumper pins should be grouped together and the pins should be labeled to indicate PWR, HD. RST etc.
You can go to the motherboard manufacture's WEB site to download a diagram of your model motherboard and it will show all the locations of the connecting pins.
Jan 30, 2011 | Chaintech MP4M266A Motherboard
I am having a problem connecting my power supply to my motherboard i can plug in everything except the one connectors that require a connection to a part called PWR-LED
Take a look at the picture below:
If I am right, the Front Panel connector should look similar as shown above (it's an assumption since you didn't mention the Motherboard's name and version). Look at the front panel connector on the motherboard carefully, you'll see similar name/indicator as you are seeing on the above picture like Pled, Hdled etc... I hope the front panel connector has 9 pins, and remember, one should be left without any connection.
Simply you have to connect the two female Pwr-Led to the Pled+ and Pled-, and Power to Pwr and Gnd, the same sequence with hard disk led and Reset switch as Hdled+ and Hdled- and Gnd and Reset respectively.
If the front panel connectors on your motherboard has less than 9 pins, then I am sorry, I have no idea about it and I am afraid if it exists or not.
If you still have the problem, let me know.
Good luck.
Aug 01, 2010 | Computers & Internet
Info to connect front panel leds
Each of the ends of the cables that lead to the LEDs should be labelled, e.g., 'PWR/power', 'RST/reset', 'SPK/speaker', 'HDLED/hard-drive-LED', 'PWRLED/power-LED'.
Connect each labelled connector to the labelled pins on the motherboard.
May 29, 2010 | Matsonic MS9158EP (DSMTSMS9158EP)...
Asus P5LP-LE Motherboard Front Panel Pinouts
N/C Reset Gnd HDLED- HDLED+
GND PWR PWLED- PWLED+
Mar 11, 2010 | ASUS P5LP-LE Motherboard
Front panel connections
PWR > PWR (aka PWR SW), HDD LED > HDD LED, RST > RST (aka RST SW and Reset)
May 31, 2008 | Iwill XP333-R Motherboard
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
