Question about Rowenta Vacuums
I have a Rowenta Ultrasteam handheld and I have never been able to use it because it heats up but steam doesn't come out, and only two times I have seen the light torn on, but when I press it nothing comes out and its torns back off.
5 Suggested Answers
SOURCE: My Europro shark steam mop won't steam, light on but no steam.
Hard water deposits. I ran some white vinegar through mine, like a coffee maker, and it worked for a while, but clogged again. So I unplugged it, let it cool and turned it over in the bathtub and squirted a small amount of Lime-Away into the hole where the steam comes out. Let it soak for 5- 10 minutes and it is working like is is brand new.
Posted on Oct 10, 2009
  • 85 Answers
SOURCE: The hose on my spot bot has torn
yes you can replace the hose for $25
If your unit is less than a year old it will be under warranty and replaced at no charge to you
Posted on Dec 15, 2009
SmartAlec
  • 171 Answers
SOURCE: The hose as torn along the metal ring. How do I
Hi Jim,
SmartAlec from NelsonVacuums.com.au here.
It is possible to take the end off and re-attatch (but its very fiddly and a real pain). You need to simultaneously push in the small oval pins on the side of the hard plastic part and pull the hose out. Be aware that there is 2 tiny springs inside and if they dont go back in the hose will not lock on. Once you have hose out simply cut out the bad part and reinsert to the end.
If this is too hard or some small parts go missing you will need a new hose.
You can get a new hose from NelsonVacuums.com.au
Posted on Feb 23, 2010
I called one of the local service centres to order one 2 months ago, still haven't heard back. Last weekend was our city's curb giveaway weekend and I got a busted Bissell Pro Heat 2X Turbo which I removed the hose from. You can order them online, just not from Bissell directly.
Cut the old hose off, you won't need it.
You have to disassemble the unit mostly. Several screws on the bottom, several under the collection tank, etc... The tubing is held together with Brass tubing clamps, they're not glued. The inner hose needs to run inside, through to the outer channel underneath the 90degree bend that the outer hose plugs into and will connect to a T shaped 3 way hose connector. My hose was wider and needed the holes to be widened. If you have to use the same outer hose connector, the coiled hose will twist in, once you remove the old hose but the new hose will need to be siliconed or glued with something that will seal it.
My new salvaged hose had the handle on it already.
It's not a pleasant procedure, have a shower after because you may get sprayed.
That being said, this process is doable, but it isn't a 5 minute fix. It took about 40 minutes all and all.
Posted on May 23, 2010
Aquamark hand held mod.am680 not steaming why
hi there did you find a solution i have the same problem thanks
Mar 01, 2013 | McCulloch MC1246 Handheld Steam Cleaner
I have the euro steam blaster s3325 when I turn it on, the steam ready **** comes on right away not heating can the heating element be replaced? thanks
There is a device attach to the heating element called a thermo fuse, this devise brakes down when it get to hot.
open the machine and replace it with the same value. it is written on it..
Nov 20, 2012 | Euro-Pro S3325 Handheld Steam Vacuum
Eureka HotShot 350A heats up great but no steam when I press button.
Remove water fill cap. Remove rubber washer under cap. Unscrew three phillips head sscrews, one on end of handle, two under rubber washer. Take handle apart. remove clip holding rubber hose onto steam flange. Unloosen plastic steam flange and remove. Using a large pair of pliers or channel locks gently squeeze valve together. It will only move an eighth to a quarter inch. Dove several times until you can depress the pin by hand. Reassemble.
Jan 18, 2011 | Eureka 350A Handheld Steam Vacuum
Rowenta Effective DX 1700 model---won't spray water?!
Mine was getting slow to steam, downloaded a manual (could only find model #1900, but close enough), and found out how to clean- fill with water, heat to the highest temp, hold over the sink horizontally and hold the steam lever over to the "self clean" position for one minute. That's supposed to purge the system of junk. Manual site: http://dl.owneriq.net/2/28c59722-2a7e-45ae-b333-c20240d7e9f5.pdf It's a free download.
Dec 29, 2010 | Vacuums
Shark handheld steamer heats up but does not spray
Try rinsing it out with CLR, it gets rid of calcium, lime and rust deposits i heard its very good.
Jul 10, 2009 | Euro-Pro Ultra Steam SharkTM II Hard...
No Steam after heating up
Sounds like the switch on the handle or the steam release solenoid on the steam chamber is faulty ,use a volt meter/tester to see if you have current to the solenoid when you turn on the switch.
Dec 02, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
Sanapathic
do you not have instruction book opration guide?? to make steam you req water then a method of heating it thus produce of steam results and pressure which expels via a nozzle ? just like the electri kettle
Oct 19, 2008 | Oreck Sanapathic DMS2000 Handheld Steam...
Heats, but no steam.
The people who manufacture this unit and box it are idots. The manufacturer should that steam can be dangous, and , a user manual should be shipped inside the box. Hey SCUNCI STEAMER dum dums,. Put a printable manual on the site so your customers won,t get hurt by not knowing robert ferriss
Aug 29, 2008 | Scunci 52001 Handheld Steam Vacuum
Vacuums Logo
54 people viewed this question
Top Rowenta Vacuums Experts
Charles T Nevin
Charles T Nevin
Are you a Rowenta Vacuum Expert? Answer questions, earn points and help others
