Question about HP Photosmart C6180 All-In-One InkJet Printer
Installed a new light cyan cartridge using HP original - message now reading "replace the following ink cartridges to resume printing. Press for more information". Have tried reinserting cartridge, turning off machine, etc. Any ideas??
There is another cartridge that is near empty... that same thing happended to me...
Posted on Oct 17, 2010
I installed a new black cartridge and my L7780 is still telling me to replace the empty ink cartridge
You may want to try the clean the printhead:
  1. Press the Setup button.
  2. Select Tools.
  3. Select Clean Printhead.
Oct 29, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
Ink cartridge cannot be used after initialization
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Says cartridge cannot be used after initialization but brand new HP 363 cartridge sent directly by HP to me. This happens ever time I put a new cartridge in when prompted by printer to do so. Do I put new...
Sep 21, 2009 | HP Photosmart 3310 Printer
Hp printer will not detect new ink cartridge has been installed. Thought it was the cartridge, bought a new one and it still says it needs replaced.
I have had similar problem with my HP C6180. Over several months I have replaced Lt. Magenta at least 6 times. Finally I got a "Cannot Print" message after the 6th full cartridge. I tried removing/replacing cartridges, doing a hard reset, and clearing the hardware failure status (press # and *, enter code 1,2,3, scroll to 'System Configuration' press OK then scroll to 'Hardware Confifuration) - all to no avail.
I decided to remove the BIOS battery. Only do this if you're ready trash your C6180 and able to buy a new printer immediately! Remove 2 the black screws holding the left side panel in place and remove it to reveal the circuit board. Remove 5 silver screws securing the circuit board, and carefully tilt it up. On the back side, center front, is a silver 3 Volt Lithium battery; remove it. Cover the printer and let stand overnight. I did this, and when I put the battery back in and powered up the printer, error messages were gone, and it printed normally. I was lucky, but if you're prepared to take a total loss on your C6180, this might just work. My theory is that the hardware "forgot" it' error message.
Sep 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
Won't print after replacing cartridges
The following text copied from HP website to tackle this problem. minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
  1. Verify that the unit is on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00718797.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Remove the new ink cartridge from its packaging.
  5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
  6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
  7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  8. Close the ink cartridge door. Figure 5: Closing the ink cartridge door c00718798.gif
s.gif s.gifHave a Good Day
Jul 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
78 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
