Question about AEG Washing Machines
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
read this site: http://www.askanowner.nl/qa/view.asp?s=2&qid=152459&arrqueryparts=&arrquery=code%3Bce kind regards, w vd vegt
Posted on Aug 28, 2007
SOURCE: aeg lavamat 538
Your door will not open if there is water still in the machine. Try "spin only". If this fails, get a bucket, remove your outlet tube from the wall drain, put into bucket. Wall plug off first. After all the water is drained try the door, do not force it.
Then check your outlet filter; the water does not go thru for there may be a block in your filter, or tube from the tub to drain area. Or finally in your pump. Dont forget to refix drain pipe in wall in exact position.
And rate me pl.
Posted on Dec 01, 2007
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
Posted on Sep 25, 2008
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Feb 23, 2013 | AEG Washing Machines
Apr 23, 2012 | Washing Machines
Aug 07, 2011 | Washing Machines
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Oct 25, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
Aug 03, 2017 | AEG Washing Machines
Oct 11, 2008 | AEG L86800 Front Load Washer
91 people viewed this question
