My cousin is playing a game,suddenly a message arrived(horse power)with in 15sec my monitor switched off.I am not using lcd monitor.Can you guys help me.
  • phanimbbtc Oct 15, 2010
    i donno the model no,I am using the crt monitor,tarzan is the game he is playing.I can see the power light blinking,cpu is running.No i don't tried any other lcds.
    Genius:
  • 1,325 Answers
I need more specifics
what is the mdoel of the computer, monitor, what game was she/he playing ?
what condition or state is the monitor in now ?
have you tried another LCD monitor to operate your computer ?
Posted on Oct 15, 2010
Testimonial: "i donno the model no,I am using the crt monitor,tarzan is the game he is playing.I can see the power light blinking,cpu is running.No i don't tried any other lcds."
Trying to download/play games but get this message: Input not supported - then my computer FREEZES and I have to reboot. This a brand new Dell Computer (but not monitor - monitor is 6 years old).
This is cause the game you are trying to play is configured to play in a high resolution but your Monitor not supporting this resolution. If you havent try to play older games, try to play an older game and see if this is happening again. Thanks. Please Rate my Solution.
Apr 28, 2011 | Acer AL1916W 19" LCD Monitor
My HP W1907 monitor works fine until I try to play The Sims 3 game. I play for several minutes or hours and the monitor shows the message that it is going to sleep and the light on the monitor goes...
Hi there. I had the same problem months ago when I try to play high end games like Sims 3 my monitor goes into power saving mode. I tried to check every possible causes of the problem. It could be that your computer is overheating try to clean your computer and check if your fans still works. Second it could me your power supply malfunctioning, maybe it does not meet the required power to make your game work. Last cause is your video card malfunctioning, what I did is to just buy a new video card and it works.
If you do not have spare power supply or video card you can go to a computer repair shop for them to check the possible problem that causes it to go into power saving mode. It can also save you money before you can buy a new one.
Hope this helps, Have a good day!
Oct 03, 2010 | HP w1907 LCD Monitor
The computer suddenly shows no display
it's about the game and videocard drivers
Jul 01, 2009 | Gigabyte Computers & Internet
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Apr 17, 2017 | Sony STYLEPRO SDM-S71R/B (Black) 17" LCD...
"No Signal" with the Acer AL1917W LCD Monitor
NeroVampire, Will this problem happen while running other applications other than gaming software? I'm not a gamer so I don't fully understand how playing high speed games affects things such as memory usage and other things like how fast the monitor must be to not get lost or confused when the pc is pumping out screen data at a rate so high that the DSP cannot keep up with it. The only advice would be to swap in a different monitor and see if it screws-up also. You could also move the acer to a KNOWN GOOD fast pc and see if it gets confused there also. Good luck guy! I'm louie12fix on fixya.
May 06, 2009 | Acer AL1917W LCD Monitor
Gateway monitor, black screen with blinking power button
wjfarm48, Sure sounds like a power supply problem. How old is it? How many hours of use? Do you understand what a switch-mode-power-supply and an inverter supply is? If not, then here are your options. Check with Gateway to see if there is a swapout program. You box up and ship them your monitor+cash, and they return a REFURBISHED same model with new CCF tubes and inverter/SMPS. When you box up the monitor, follow this lead. "A 3 inch thick layer of breathable air shall be the only thing touching the lcd front panel" Next option is find some local TV/Monitor repair guy who can get parts and or replacement boards/CCFtubes from Gateway. Last but not least, is to repair yourself. Not Recomended.. But do a search on lcd monitor repair or Bad Capacitors In LCD Monitors or Repair of SMPS in LCD/FPD Monitors. Also check for videos on YouTUBE related to lcd monitor repair just for your own info. Here 's what you are dealing with. The light that makes your FPD bright white is generated by Cold Cathode Fluorescent Tubes (2) that require 600-1200vac at high frequency that is generated by an INVERTER which gets 12-24vdc from the SMPS. Almost the same technology is used in the new style screw-in curlie-que Compact Fluorescent light bulbs. Only they call the inverter a electronic ballast. Anyway, thats about all the info I have. Let me know how you make out in you quest to get your LCD up and running again. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Apr 03, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Make sure Resolution is 1440 x 900......
hello,
did your monitor support 1440X900 resolution. if yes then go to desktop properties then change the resolution to 1440X900 then play the game.
if not support then remove the game from your pc.
ramesh
Nov 29, 2008 | Envision 19" Widescreen Flat Panel LCD...
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
POWER SAVING MODE while playing computer games
Check to see if your fan on your video card is spinning and is not clogged with dust. Almost sounds as if it is overheating and causing a reboot.
Feb 01, 2008 | LG Flatron L1715S 17" LCD Monitor
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
