I'm repairing Canon IR 7095 the problem is in the Finisher V1, the error code is E542. could you provide me a service manual of this model Finisher V1.because i cannot locate where the problem is coming from.
2 Suggested Answers
  • 58 Answers
SOURCE: canon IR 7095
if you can not use the finisher and the machine says Functions limited
press additional function
press common settings and then scroll to find limited functions mode if its on press the off button press ok and turn off the machine and then back on
Posted on Aug 07, 2009
The canon IR 7095 image-runner that i need help with it has an error code E000578-8001
That error Indicates there is a malfunction in the finisher Unit . I am not sure if the problem is any of the delivery trays of a stapler error
May 17, 2017 | Canon Office Equipment & Supplies
C3852 error code
Fusing code I. the fusing unit is not warming up to the proper temp. Open the front to the right below where the cleaning clothes are kept there is a cover at about 45 degrees have to get on the ground and look at it there is hole small screwdriver to push the small switch to reset the machine for tha code it will not reset by powering off than on or closing the door.
Aug 10, 2014 | Konica Minolta bizhub C450P Laser Printer
ERROR CODE IN IR 7095 EOOO2- 0001
this error refer there is a problem in the fixing unit, check thermistor and clear that error from service mode
Apr 13, 2014 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
Canon IR 7095, error code E000005-010
Hello to all
I have a client server ir Pass has forgotten his password and I reset.
how reinitialiser server S2 canon ir Pass?
Thank you for the help.
Dec 27, 2012 | Canon Imagepass S2 Fiery For Ir...
Canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Canon IR 7095
Jul 28, 2009 | Canon imageRUNNER 3570 Copier
Error code e542
The error code means that the finisher bins could not find HP. The problem shows up when something is placed under the bins and stops them from moving down, most of the time a "G" file or a case of paper. Move the object and move the bottom bin up till you hear it click. Before doing that make sure the MAIN Power Switch is OFF on the right side of copier... Then turn the copier back ON and it should clear it self.. Good Luck
Apr 18, 2009 | Canon imageRUNNER 6000 Copier
Canon imageRUNNER 7095 copier has the error code E00057a-8003 ..... can you tell me what this means? can we fix it on our end? Let me know as soon as possible because our copier has been down for 3 days....
This Problem occured with a finisher V1/V1L attached to our Canon iR7095.
The staple unit didn'tmove back to it's initial position. After restarting the printer there was a really strange clattering sound coming from the staple unit.
Problem was solved by removing all trapped pages from finisher and copier. Probably you have to restart several times. The system should reset and move the staple unit back to initial position.
Aug 12, 2008 | Office Equipment & Supplies
334 people viewed this question
jasbo
jasbo
