Question about ElectroVoice RE20 Professional Microphone
No sound comes from the microphone. - ElectroVoice RE20 Professional Microphone
  • 10,865 Answers
If the microphone has a battery in it, replace it with a brand new one. Joe
4 thumbs up please. thanks.
Posted on Oct 15, 2010
Comoaqwindows 8 microphone muted how do i turn it on
From the Start screen, type sound to open the Search charm, and then select Sound from the search results.
The Sound window opens.
Click the Recording tab.
Select the microphone, and then click Properties.
Click the Levels tab.
Change the microphone level to 100 and the Microphone Boost to +10.0dB.
Click Apply.
Disconnect and reconnect the microphone. Then check the microphone recording level.
Do not run more than one application at a time which uses the microphone.
Aug 16, 2014 | Compaq Computers & Internet
No sound coming out of microphone
Do you have the sound adapter? This microphone CANNOT just be plugged in as it is likely a condenser type requiring a "phantom" power source. This source is designed to be supplied by a Sennheiser WIRELESS body pack.
Mar 02, 2013 | Sennheiser ME3 Microphone
I cannot hear any microphone playback
I cannot hear any microphone playback 2) Installing the driver software for it takes sound out of my computer my microphone seems to be fine because the green light comes on when i test it, but no playback in speaker when i record. I know im jus missing one little thing...can you help me?
Feb 08, 2010 | Tascam US-122 USB Audio/MIDI Interface...
No sound from microphone nor headphones
No sound should be coming from the microphone. Its... a microphone. And if you cant get any sound through your heaphones, be sure that you are not plugging them into the microphone port, and into the headphone port or line out port.
Jul 24, 2009 | Computers & Internet
Backpanel socket for microphone is not recognised. Speaker socket is alright.
in order to hear sound on the microphone you need to check the Mixer settings as the default setting for microphone (for playback) is mute as you would get some horrible feedback..
double click on the speaker icon in the bottom left and chose properties from the options menu you may (or may not) have the option to select microphone for playback, however there should be a setting for recording which should give you a slider to set the recording levels for the microphone, use sound recorder or other recording software to test microphone is working
Apr 13, 2009 | Intel Motherboard
Dell inspiron 6400 Soundcard Microphone
sorry for the delay in responding:
for Vista system ... use the following picks:
Start ....Control Panel,...... Hardware and Sound, .... Manage audio devices....Recording......Line in ...try the advanced features to control the computers auto adjustment etc.
Hope this helps
Apr 05, 2009 | Dell Inspiron 6400 Notebook
My internal microphone doesn't work
If you are refering to the internal microphone on your computer then try this. Open up your windows sound recorder from Start - Program - Accesories - Entertainment. Hit the record button and talk or yell something if you would like. You should see recorded sound waves in the middle of your sound recorder. If you do not see the recorded waves this might mean that your microphone is turned off. To turn it on just Double click on the little speaker icon on your taskbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure the microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder and try to record again. If this does not work your internal microphone may not be working or your computer may not have come with a built in microphone.There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 17, 2009 | Audio Players & Recorders
No sound
Hi
the program your using is not set to use the sound that comes from the webcam, instead its using the sound thats coming from the line in or microphone port on the computer.
you will have to change the settings or plug a microphone to the line in or microphone input to solve the problem
Thanks,
Ekse
Feb 12, 2009 | Logitech QuickCam Communicate STX Personal...
No sound from in-built microphone and sound through headphones
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Nov 28, 2008 | Computers & Internet
No Sound Coming out my Microphone
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
Mar 28, 2008 | Philips PH62080 Uni-Directional Microphone...
ElectroVoice RE20 Professional Microphone Logo
74 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
