Question about Jura Capresso EspressoPRO 112 Espresso Machine
The machine makes noise like it is going to dispense the coffee but it doesn't come out ... It seems the water is not being pumped out of the reservoir through the machine and past the grinds down into the cup
SOURCE: Cuisinart Grind & Brew not using all the water in the reservoir
Same problem . Sent my first machine back (less than 1 year old, you pay shipping and handling both ends) and now after 4 months, same issue. Not sure what to do.
Posted on Feb 17, 2008
  • 3 Answers
SOURCE: no coffee will dispenses
How fine have you got you grind setting, if it is a new machine it needs to be on course Grind, fine grinds clog the filter.  You need to reach into where the tray goes with a cloth and wipe clean the filter bin which is right behind a flap
Posted on Dec 09, 2008
SOURCE: "Fill System/Press Steam"
Remove the tray at the front of the machine. Look inside and you will see a rubber flap which separates the right and left side of the machine. Gently lift this to the right and look inside to the left (a small mirror like from a womans compact and a flashlight will help you see in there.) You will find a small circular screen (about the size of a half dollar.)  You need to wipe ALL the coffee grinds off of this screen. That should fix the problem. If you use dark beans, you are probably grinding them to fine and some of the oily residue is sticking to this screen. Try grinding the dark beans more coarsely. Only change the grinder WHEN IT IS GRINDING by adjusting the litlle knob in the box where you place the beans. If the problem started just after changing the filter you may have air in the water line and it needs to be flushed. Try running the tea portion hot water until it clears. These suggestions were given to me by Capresso and actually worked for my machine. Good luck. Gary
Posted on Dec 14, 2008
SOURCE: Jura Impreza E8 - only water comes out no coffee
going to get it fixed.
Posted on Jan 11, 2009
SOURCE: GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Posted on Apr 03, 2009
Waterpump makes a lot of noise
It is possible that the water coming into the pump from the mains is obstructed. If you have a water filter, that might need to be replaced. Some of the pumps have a stone filter on them, you will see a huge nut on the inlet side of the pump, that might need to be cleaned. Also check all water lines make sure you have no kinks. Pay attention to the gauge on the machine when the noise is happening if the water dispensing pressure lever should be at about between 3-6 bar when not being used and about 9 when brewing espresso.
Feb 19, 2014 | Faema Smart A2 Automatic Espresso Machine...
I am getting no coffee to dispense out of the coffee output. It gives me no error message. It grinds the coffee and acts like it is dispensing the coffee. But nothing comes out. My coffee grounds...
firs of all try to make preground coffee ,but without coffee powder if the water come out then you have to change the pump. If no water come out -your machine needs to be descaling
Oct 18, 2013 | Saeco Royal Professional Espresso Machine
No water is pumping thru the water spout or the coffee spout, the machine is reading fine grounds and press okay for water. i've adjusted grinder dial and pressed water button but nothing happened
I got this machine and there was grinding noise but no water coming from the spout or coffee from the dispenser.
Took the back cover off. The big lump in the middle is the water pump. One of the wire connections was hanging off mine. Pushed the connector back on and everything worked fine.
Great coffee, rubbish construction!
Sep 18, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Jul 20, 2010 | DeLonghi EAM3400 Espresso Machine
No hot water or steam
Well, I have little exposure to Saeco, but a lot to commercial coffee machines.
Saeco have a lot of custom made components, although these can be purchased, nothing is cheap! Neither is their repair service!
First, is the boiler heating?? If so:
No hot water/ no steam suggests a blockage. Assuming you can hear the pump working when attempting to do a coffee, you will probably find the water flowing back into the water tank via the relief valve. Of course, this valve itself could be the problem, or the pump failing to work through a blocked inlet filter or other problem.
Look now at the group head. Ever cleaned it? The filter and spray block should be removable, do so and clean them carefully. While you have them out, see whether water reaches the head by "making a coffee" into a cup placed under the head. BE CAREFUL OF SCALDING. If water now flows, cleaning the screen and spray block should restore operation.
Beyond that, it's inside the machine! There is a 3- way valve that operates when making a coffee. This can become clogged with coffee. There is another valve to open the steam.
If, like Saecos I have worked on, the boiler does both the hot water and the steam one at a time, look for problems BEFORE the boiler.
Hoe this helps a little....
Jan 19, 2008 | Saeco Vienna SuperAutomatica Coffee...
Flashing water light - will drain water but will not make coffee
Something is wrong on the coffee cycle side of the machine. Check the brew unit screens and and try doing a preground cycle with out inserting coffee. IF water comes out, I would looking into your grinder a little bit and try increasing the grinder size.
Espresso parts and service
www.cerinicoffee.com
Dec 08, 2007 | Saeco Magic De Luxe Espresso Machine
Machine working but not brewing coffee
Hi mate, Check the water - in pipe to ensure there is no blockages/. also check up around the group head to ensures old coffee ground have not been left there and gone hard.
Jul 31, 2007 | EXPOBAR Office Pulser Espresso Machine
Jura Capresso EspressoPRO 112 Espresso Machine Logo
59 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
