Question about Thermador SC272T Electric Double Oven
Hello! I have a Thermador double oven and it is beeping F-7 as it is finishing up a self-cleaning. In addition I am also getting F-1 F-1. The bottom oven cleaned and unlocked with no problems. Now the top oven is giving me a problem with the f-7 and F-1. What is going on?
Hello, Per my manual:
F7 - This is caused by close contact to the control panel for more then 32 seconds,such as someone leaning against the controls or objects hanging in front of controls.
F-1 - Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn it back on. If condition persists, note the code number and call an authorized servicer.
Hope this helps,
Vicki
Posted on Oct 25, 2010
Our Thermador oven starts to beep when you shut it off and the way we are getting it to stop beeping is to set up a fan in front of the open oven to get it to cool. This stops the beeping after 10 m
Check if the internal ventilation fan is running. It is intended to cool down the oven exterior. Some units made 2004-2007 can overheat during self-cleaning.
Oct 14, 2014 | Thermador C301U Electric Single Oven
How to clean an older Thermador self cleaning wall oven
self cleaning ovens need temp set to highest to clean.
Mar 14, 2013 | Thermador C272 Electric Double Oven
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
How to self clean
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Apr 18, 2011 | Thermador C302U Electric Double Oven
How do i self clean
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following products. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: Thermador� Built-In Ovens
Units: About 37,000 (42,000 built-in ovens were previously recalled in June 2007)
Manufacturer: BSH Home Appliances Corp., of Huntington Beach, Calif.
Hazard: The ovens can have gaps in the insulation where overheating can occur and when used in the self-cleaning mode it can cause nearby cabinets to catch fire. This poses a fire hazard to consumers.
Incidents/Injuries: BSH Home Appliances has received three additional reports of incidents, including two that resulted in fires that damaged surrounding cabinets. No injuries have been reported.
Description: The recall involves Thermador Brand built-in double ovens with model numbers C272B, C302B, SEC272,C301U, SEC302, SECD272 and SECD302 and serial numbers between FD8403 through FD8701. Model and serial numbers are located on the underside of the control panel.
Sold at: Appliance and specialty stores nationwide from June 2004 through July 2007 for between $3,000 and $4,400.
Manufactured in: United States
Remedy: Consumers should immediately stop using the oven�s self-cleaning mode and contact the firm to schedule an inspection and free repair, if necessary.
Consumer Contact: For additional information, contact Thermador at (800) 701-5230 24 hours/day, 7 days/week, or visit the firm�s Web site at www.thermador.com
Dec 05, 2010 | Thermador C301U Electric Single Oven
Self clean wont turn on!
Hi, If the self-cleaning operation on your double oven will not work, make sure the oven clock on the upper oven shows the correct time of day. In addition, Make sure the Lock Lever is in the cleaning position, pushed all the way to the right on the top oven. If a delayed start time has been programmed, that may be the cause of the cleaning cycle not beginning right away.
Thanks for using fixya....
Oct 28, 2010 | Thermador SC302T Electric Double Oven
How do I use the 'self clean' feature? I can't find the manual and it needs to be done
Good luck with that - whenever we use the self-clean function it goes crazy on us - beeping, error codes - door locks up - have to reset breaker to make it shut down. The last time the door got permanently locked - nightmare!!
Also, there is a recall on some of the wall units - ours of course isn't part of that recall - Thermador doesn't care that we can't open our oven - they'd rather you purchase another piece of junk!!
Oct 20, 2010 | Thermador SC302T Electric Double Oven
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Feb 19, 2009 | Thermador C272 Electric Double Oven
Thermador SC272T Electric Double Oven Logo
276 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
