Question about Canon PIXMA MX700 All-In-One InkJet Printer
Encoder strip has come loose Canon MX700. Anyone tell me how to put back in place?
aomcopier
  • 22 Answers
SOURCE: Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Posted on Apr 01, 2007
Cindy Jo
  • 74 Answers
SOURCE: Encoder Strip
What is the question? Where should you put the numerical strip of ownership? Let me know and I will send you in the right direction.
Cynthia Charczenko
Posted on Jan 15, 2008
IB4G2008
  • 3587 Answers
SOURCE: Canon mx700 rejecting remanufactured ink cartridges
big issue with remanufacturing is how integritous is the fit of the cartridge, and also the interface. When these are re cut, so to speak, tolerances can stack up, and one thing about Canon, is they are a stickler for tolerances. You may have an issue with the cartridge fitting in the carriage, but not interfacing with the system. Happens sometimes..
got backup?
Posted on Feb 15, 2008
damanpreet_c
  • 69 Answers
SOURCE: encoder strip
It is not possible for you to hook the encoder strip back to print, its kind of a Hooks on both ends which is holding it, even if you are able to put it back, it will not work,
I would refer you to a local computer tech, however I'll suggest you to get a new printer, coz tech might charge lot more than what the price of new printer
Posted on Nov 07, 2008
  • 4 Answers
SOURCE: encoder strip part c8941-80005
an encoder strip is seriously easy to replace! the strip rides thru a sensor on the ink cartridge carriage. one end hooks on to a small "hook"" on the left side of the plotter. the other end connects to a small "hook" on the encoder strip spring which connects to the right side of the plotter. Most manufacturers consider anything inside the case to be "not user replaceable". but really, its harder to keep the pictbridge bezel (cover) from falling out than it is to replace the encoder strip.
in response to jktyler.. my 2 year old did the same. if the small slots on the ends of the encoder strip are broken, then the strip is definitely damaged.
Posted on Dec 10, 2008
Yellow light keeps flashing underneath triangle- Error code 6480. Please advise what this means? many thanks
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also will fix a gap in the printing running lengthwise (not across the page like a clogged head).
Mar 09, 2011 | Canon MX700 Office All-In-One InkJet...
I have canon mp145 printer. when it starts to print it gives the service error 5100 message
Tried greasing (actually WD40) per linzi's reply, but it did not help. In the process, I think the solution presented itself. There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Jan 27, 2011 | Canon MX700 Office All-In-One InkJet...
How do I fix hardware error: 0502
Hi There, Please follow the below steps to get off this error :
Re-position the Encoder Strip on your Printer
To re-position the encoder strip, perform the following steps:
1. Remove the power cord from the unit.
2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
NOTE
NOTE: There is a small slot that the encoder strip fits into, which is going to be located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the lid to the unit.
9. Re-connect the power supply to the All-In-One.
10. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
See attached pictures, one for an out or place encoder strip, the other for a well placed strip.
Other faults that can bring up this error is a carriage rail that needs cleaning and oiling (so you might want to do that while your inside the thing), and also obstructions to the paper ways. Try removing paper jams, and put the printer upside down to shake loose anything that might jam the mechanism.
Oct 28, 2010 | Lexmark X6170 All-In-One InkJet Printer
How to solve the error 5b00 for mx700?
Oct 05, 2010 | Canon MX700 Office All-In-One InkJet...
Whenever I start to print or copy, it says error code 1500 on my MX700 Canon...It is not quite a year old.
I don't see an error 1500 for your machine, but error 5100 says that either the carriage is being blocked from moving back and forth properly, or there is grease on the encoder strip. Look on the plastic strip that runs behind the carriage assembly for any grease spots and wipe gently with a Q-tip if there are grease spots on it. Beyond that, you have warranty for a full year and can call Canon at 1-800-828-4040 to find the nearest shop.
Dec 14, 2009 | Office Equipment & Supplies
I have a canon MX700 and it is showing error code 5100, I looked it up in the manual and there is nothing for this code..help!
Try this.....
Sep 09, 2009 | Canon PIXMA iP90 Mobile Printer
Canon MX700 printer - vertical lines aren't straight
Have you tried to do an alignment. Also check encoder strip
Aug 19, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printing lines not straight and letters shadowed. Help!
Open the cover over the print head and *carefully* inspect the clear thin plastic strip that runs from left to right near the print head. If you see any lubricant (white grease) on this encoder strip, it needs to be cleaned off.
1. With the cover open and the print head in the center, unplug the power cord. This will allow you to gently move the print head left or right.
2. With a cotton swab wetted with rubbing alcohol, *gently* wipe the grease spots from the encoder strip. (Be VERY CAREFUL you don't dislodge the strip.) You may need to move the print head to the left or right to get all areas cleaned.
3. Let the alcohol dry off completely. With the area clear of cleaning tools, debris, and fingers, plug the power back in.
4. Try a test print.
Jun 17, 2009 | Canon PIXMA MX700 All-In-One InkJet...
ERROR 0502
Re-position the Encoder Strip on your all in one Printer
NOTE
Dec 12, 2008 | Lexmark X6170 All-In-One InkJet Printer
Canon PIXMA MX700 All-In-One InkJet Printer Logo
116 people viewed this question
old marine
old marine
