Question about RCA Audio Players & Recorders
Need to know specifications of RCA 15 inch PF
    Genius:
  • 1,325 Answers
Pleas ebe more specific -- what is the unit model number ?
Posted on Oct 15, 2010
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
Mar 01, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
Hi I DeLonghi T130ARC model air con and no remote and getting a messgae of PF error does anyone know what this means Andrew
Hello my name is Heath it wil be my pleasure to assist you. The PF usually means there was a power failure and the only thing you can do is turn the power off to the unit unplugg the unit and let it sit for 15-20 minutes and then repower the unit and see if the pf goes away.
Aug 02, 2010 | DeLonghi Pinguino PACL90 Portable Air...
2000 Grand Am GT: I need the firing order diagram for a 2000 pontiac...
2000 Pontiac Grand AM 3.4 liter V-6 VIN "E"
Hope helps (remember rated this).
May 17, 2010 | 2000 Pontiac Grand Am GT
Can a sdhc card work on a mustek pf-b800?
Only your manual can tell you that. Find out what card is compatible AND make sure you format it first using your digital photo frame settings software. You manual will tell you how to do that.
Always works better that way.
Dec 22, 2009 | Mustek Pf T80B 8 Inch Digital Picture...
Please tell me what is flyback 1600V working voltage PF (near the horizontal transistor)
Hi
Flyback is a step-up transformer multifly the voltage depends on the size of the tube and supplied high voltage to cathode ray tube.The minimum output voltage of this is 14000v DC for 14 inches crt monitor what if your crt is 17 inches 17000v DC very dangerous if you are not electronics repairman.
Jul 14, 2009 | SAMTRON 55V 15" CRT Monitor
Torque Spec for '99 Chevy C1500 5.7L engine lower intake manifold
On 5.7L engines, install the bolts and torque in sequence as follows:
  1. Step 1: 71 inch lbs. (8 Nm).
  2. Step 2: 106 inch lbs. (12 Nm).
  3. Step 3: 11 ft. lbs. (15 Nm).
Mar 14, 2009 | 1999 Chevrolet C1500
Convergence problem with old rca 46 in rear projection TV
you will need to have a shop re converge it or order a new convergence board.
Nov 17, 2008 | RCA P46924 46" Rear Projection Television
2005 phillips crt 27 inch tv
need electrolytic capacitor replaced in vertical circuit
May 07, 2008 | Televison & Video
23 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
