Question about Danby DWC283BLS Wine Cooler
Hot on the sides and in the back in the bottom,
    Problem Solver:
  • 6 Answers
Your coils are built into sides and top of cooler. Allowing unit to cool, by disipating heat.
Posted on Oct 28, 2010
Bottom of freezer has a layer of ice, that returns after removal, no aparent drain or leak
there is a drain hole in the bottom of freezer near back wall if its a side by side. take out bottom crisper drawer to locate drain. than take hot water in a turkey baster and run hot water doen drain hole to unstop drain.
Aug 31, 2014 | KitchenAid KFXS25RYMS 25 cu.ft. french...
My GE Profile Side by Side Refrigerator (PSC23MGNA) has ice below the bottom try in the freezer. I tried to thaw out the area on the back but I am not sure where the drain is located. Need Help on wha
drain is located in very back of bottom of freezer an a little ledge 6 inches from bottom.... ice build up normally means drain is clogged and needs hot water / turkey baster to force hot water down drain. (gently chip away ice careful not to crack plastic
Aug 28, 2014 | Refrigerators
Water pools at the bottom on the inside the freezer side of a side by side frigidaire. This frig has a water line for automated ice and dispenses water/ice on the outside. At the bottom there is a vent...
your defrost drain is plugged remove the back panel in side the freezer at the bottom you will see a metal pan with a hole in it clean around the whole and flush it with hot water a turkey baster works great for forcing hot water thru the drain and clearing what ever is plugging it
Mar 07, 2010 | Refrigerators
Water pooling under freezer side of cabinet. Ice forming in bottom of freezer.
drain in bottom fo reezer is frozen w/ice (location is very far left in back lookbehind vent. use hot water and baster. force hot water through drain. /remove ice /it will work good. mm pls leave feed back..mm
Dec 07, 2009 | Maytag MZD2766GES Side by Side...
Freezer side has a drip inside on back panel that
if you can find the a hole the opening is size of a hose, that is where that water should go, see if there is any small object blocking the way out or the hose maybe clogged, just clean it with hot water, turn it off first
Nov 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Sides of freezer extra hot
The problem with the fan is causing this. We need to test the fan motor and the power going to the fan motor. Let me know, Sea Breeze
Jul 23, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Water on Floor Outside Freezer (Side by Side)
take a wire and run it through the drain until there is no resistance and then put hot water into it.
Mar 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Overheating
the drain plug is on the bottom of the rediator on the drivers side on the back side of the radiator.
Dec 31, 2008 | 2004 Dodge Stratus
Fan not working and sides are still hot
For your water flow problem and leak; Check in back of the refrigerator bottom right side facing the back. You will see two plastic tubes, one is for the water dispenser and the other is for the ice maker. Check for a loose connection at that point for the water leak.
May 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Danby DWC283BLS Wine Cooler Logo
287 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
