Question about Microsoft Windows XP Home Edition
I want to write my name at start icon of windows
hi my name mr birbal IT
i am interested in hardware field please advice me
how i can write my name at start icon of windows xp
    President:
  • 1,257 Answers
Hi birbal IT,
You can use the link below and follow the steps to change the name of start button :
http://www.theeldergeek.com/change_text_on_xp_start_button.htm
________________________________________________________
If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 02, 2008
Explorer cannot find d link, was working for a long time then quit, then working, now not working
Improve the Fixya.com experience for everyone by voting!
Unfortunately, you haven't provided any details as to the steps you've thus far taken. So lets start at the beginning and solve your problem step-by-step.
Step 1 Locate the Queue name, or Port name, of your printer.
Click here for instructions on locating the Queue name since you are using a DPR-1260.
Step 2 After you locate the Queue or Port name, you will want to write it down. (You can also highlight it with your cursor, and copy the info. This will allow you to paste it in to the wizard later on.)
Step 3 Click Start and then Control Panel. Locate the Printers icon. Click the Add A Printer icon.
Step 4 Click Add a Local Printer. Use this option only if you don't have a USB printer. (Windows automatically installs USB printers when you plug them in).
Step 5 Select Create New Port. For the port type, select standard TCP/IP Port. Click Next.
Step 6 Click the drop down menu for Device Type and choose TCP/IP Device.
In the Hostname or IP Address field, input the ip address of your print server. (The default address for most of D-Link's print servers is 192.168.0.10).
The PORT NAME field is purely for identification purposes. This allows you to discern the port you've created later on for configuration.
Step 7 Windows will attempt to detect the printer. Please allow a few moments for the operating system to do this.
Step 8 Highlight the radio button labeled Custom and press the Settings button.
Step 9 Click the radio button labeled LPR.
The LPR Queue Name field will now become available. Here you will need to enter the Queue or Port name that you acquired in Step 1.
Check the box labeled LPR Byte Counting Enabled. Click OK.
Step 10 At this point, you'll be brought back to the previous window. Click Next.
Step 11 Windows will now attempt to detect and install the printer driver. If Windows is unable to detect the printer and find a matching driver, you will be given the option of selecting a printer from a list of available printer drivers.
Step 12 In the left window you have a list of manufacturers, and on the right side you have the various models. Select the model that pertains to your printer. Click Next.
Step 13 Next you will be prompted to give the printer a name. You can leave the default Windows name, or you can create your own if you wish. Click Next.
Step 14 Once the printer successfully installs you will be given the option to print a test page. If the test prints then the print server is configured properly. Click Finish.
You should be linked up now.
All the best
Ben
Jul 11, 2011 | D-Link RangeBooster G DPR-1260 (DPR1260)...
My computer does not recognize hardware. FYI: Machine hums when I insert a disk.
These are the steps to resolve the issue for the cd/dvd icon missing in the My computer.
Step 1: Please perform manual registry set up by following the below steps:
Please make a full backup of your registry files, particularly user.dat, system.dat, and policy.pol. If you make any incorrect entries, the backed-up registry files can be used to replace the corrupted registry entries.
Follow these steps to backup registry:
1. Click Start, select Run. In the "Open" field type REGEDIT
2. Click OK and click "File" in the menu bar
3. Click "Export" from the drop down menu this will open a new box
4. Click the down arrow beside "Save In" and select "Local Disk (C:)"
5. In the File Name field type BACKUP.REG Verify that under the "Export Range", that the radio button is beside "All"
6. Click Save.
Now make the following changes in registry:
1. Click Start and click Run(XP) or type Click Start and type regedit in search then hit enter(vista, Windows 7).
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better
to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right
window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next
method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right
window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor.
Step 2: Please uninstall the CD/DVD drive form Device Manager :
1. Click Start and select Control Panel.
2. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.
3. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously.
4. Click the Hardware tab and then click the Device Manager button.
5. Click the plus (+) sign next to the DVD/CD-ROM drives .
6. Right-click the driver listed under this Category and select Uninstall. In the Confirm Device Removal dialog box, click OK.
7. Repeat step 6 until all entries under the device category are deleted.
8. Restart the computer.
After the notebook is restarted it automatically detects the drive and the drivers are installed.
Regards,
Shami
Nov 22, 2010 | HP DVD1040e DVD-RAM Burner
My computer will not recognize the dvd1260i burner
6. Click Save.
method.
Regards,
Shami
Oct 31, 2010 | HP DVD1260i DVDRAM Burner
I cant see my dvd/cd drive in"my computer" wndow, but it is visible in "device manager"
6. Click Save.
method.
Regards,
Shami
Oct 28, 2010 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
TSST Corp CDRW/DVD TSL462D ATA Device (code 10) will not start up.
Please perform the below steps to fix the issue:
6. Click Save.
method.
Regards,
Shami
Oct 04, 2010 | Computers & Internet
Toshiba Satellite A135 S2276 with windows 7 Ultimate
  • Hi, when ever there is a [? mark] next to any of the Components in the "Device Manager" there is a {Problem!} The only solution is to "Uninstall the Hardware Device" and reinstall it. Next your going to have to "Update the Drivers," and restart the computer afterwards. To "reinstall" the "Display Drivers," do the following; open the Start Menu, in the [Start Search Window], Type: toshiba, next scroll to find the [Toshiba Application Installer]. Open the window and "Install" the Display Driver. Restart the Computer after all changes are complete. "Let me know how things worked out for you by giving a "Helpful Rating," and thanks for using Fix' Ya.
Jul 01, 2010 | Toshiba Satellite A135-S2276 Notebook
OVERHEATING DRYER
First make sure the vent is not blocked relieving air flow in back for examlpe remove exhaust hose and let it run with a window open for ventalation of course and let me know if this stops the problem
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
How i create a data base in ms access
Start, Programs, Microsoft Office, Microsoft Office Access 2007. Click the Office Icon in the top left corner of the Access 2007 window. Click New, locate where it says "Blank Database". In the field labeled "File Name", type the name of your new database. To choose a folder on your computer to save the new database, click on the folder icon next to the "File Name" field, and select the folder, then click Ok. Then click "Create".
Please let me know if this helps or if you have any questions.
Thank You, Raphael
Sep 08, 2008 | Microsoft Office Professional 2007 Full...
Frequently changes its status to offline; have wireless connection
please perform the steps below:
Step 1:
Determine if the printer is paused or offline :
1.Open the printers folder, if necessary.
a.Click the Start icon.
b.Click Control Panel.
c.Click Hardware & Sounds.
NOTE: This step is not required when using Classic view in Windows Vista.
d.Click Printers.
2.Right-click the name of the printer and then click Open.
3.Click Printer.
4.Verify that Pause Printing and Use Printer Offline are not selected.
5.Press Esc to close the window without making any changes.
Step 2:
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Aug 12, 2008 | HP Photosmart C7180 All-In-One InkJet...
Microsoft Windows XP Home Edition Logo
95 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
