Question about MSI MS-6390 (-6390-010) Motherboard
I have a Compaq Presario 5000, and it just doesn't boot. The problem is that the monitor is blank. I can see the HD, CD lights go on, but nothing happens after that. I tried three different video card, but with the same results. I assume that the Motherboard is shot (but have no beeps at bootup) please can anyone Helpppp meee.?
    Brigadier General:
  • 4,044 Answers
If you have no post then the motherboard is most likely shot or having a conflict. If your using AGP card and have another expansion card in the first expansion slot the Graphics card will not work because those two slots share IRQ's. Remove all expansion cards except the Video card and remove any floppy, hard drive or CDROM and all ram from the machine and see if you can at least get a post and access to the BIOS. If you can boot to post it is a matter of isolating what is causing your problem by connecting 1 item at a time until it stops working. Until you can get a POST the motherboard, for all intensive purposes, is dead.
Posted on Oct 15, 2010
My compaq presario 500 wont boot up?compaq screen comes on then, blank screen,a little cursor in the upper lefthand side
virus is the cause. You are going to have to put in your windows cd and boot from it. Then do a "repair" and hopefully recovery your system if not you are going to have to do a total system wipe.
Sep 02, 2014 | Compaq Presario 5000 PC Desktop
I have a Compaq CQ50-210. Problem with the HP COMPAQ Presario CQ50-210US NoteBook AMD Athlon X2 QL-62 15.4' Wide XGA 2GB Memory 160GB HDD... I have a Compaq CQ50-210. When I try to boot it, the screen...
Power up the external monitor first and then boot up the laptop, the video info will automatically divert to the external monitor.
If you do not see a Windows image on the external monitor then it is definitely a motherboard issue, because the video card is built in on the motherboard.
The Video card uses shared RAM (part of the RAM module/s ), try re-seating the RAM modules, also test the RAM modules.
You can test the hard drive by removing the hard drive and connecting it to an USB hard drive adapter, then connect the adapter into a working computer's USB port. If the hard drive is OK, this computer will see it as an external storage device and you can open the various folders and files on the hard drive.
Dec 12, 2010 | HP Compaq Presario CQ50-210US Notebook
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
The compaq will not boot up
try loading your OS cd but it will wipe out all the files on your drive. if this wont still work, then it might be prob with the hard drive itself. replace hard drive.
Mar 31, 2010 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Can't get computer to turn on (compaq presario 5000)
Either your Hard drive (hd) crashed or your hd cable or port is faulty. if your software is corrupt boot with a boot disk (assume you are using XP or Vista), press R on the blue options screen. you will be given a black dos prompt screen. Type in fixboot and type Y for an answer.
Oct 26, 2009 | Compaq Presario 5000 PC Desktop
PC DO NOT BOOT
It seems that you don't have any Operating System installed. You need some bootable OS setup disk, and change BIOS settings to boot you PC from CD. Insert disk and restart PC, then follow onscreen instructions to setup OS.
Jan 27, 2009 | Compaq Presario 5000 PC Desktop
COMPAQ PRESARIO V-6000 LAPTOP WILL NOT TURN ON
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Jul 13, 2008 | Compaq Presario 5000 PC Desktop
Screen goes blank
try reinstalling xp.(im asumming thats what ur running).
Mar 13, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq presario 5000 startup problem
Firstly the keyboard does blink, but do you hear 2 beeps one then another a few seconds later, if not memory or graphics fault. Are you able to start in safe mode(press F8 when pc is booting up)when menu comes up highlight 'Start windows with last known good configuration' then press enter and it should re boot. The graphics card(if it's not onboard)may need to be removed and re seated, also the memory. Also check hard disk drive ide and power cable.
Jan 15, 2007 | Compaq Presario 5000 PC Desktop
MSI MS-6390 (-6390-010) Motherboard Logo
59 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
