Question about Liquid Video L17LCD2 17" Flat Panel LCD Monitor
My monitor comes on for a short period of time and then shuts off. The blue light is still on and if you shut it off an back on the monitor will come back on and after about 5 seconds it shuts off agian. I was told it is a capetor but cannot find out where to download the manuals for my L17LCD2 17" Flat panel LCD monitor (silver)
    Problem Solver:
  • 5 Answers
As Bud mentioned, this seems to be a common problem. I put together a vtutorial on YouTube for the fix : http://www.youtube.com/watch?v=vWGmtsqQYno
Hope this helps!
Posted on Oct 01, 2012
  • 11,361 Answers
You just have to open it up (remove all the screws and stand and then use flat blade screw driver to crack it open starting at the bottom edge first and work your way around and be careful on the cable attached to the front panel). You may be able to see some bad caps with leaking/bulging tops.
Learn more here:
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 16, 2010
Dell UltraSharp 2001FP (Gray) 20.1" LCD Monitor
Most likely, this is failing "inverter."
The backlight of the monitor (that makes the image visible) is controller by a special chunk of electronics called an inverter. They tend to fail over time. The symptom is that the backlight either never comes on, flickers, or shuts off after a short period of time.
It is a moderately advanced repair job to change out the inverter, but you can usually get the part on eBay. Search for the exact monitor model number and "inverter".
The 2001FP has six lamps and the inverter is fairly expensive. You might be better off putting that money towards a newer monitor.
Apr 11, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
SHUTS DOWN AFTER A SHORT PERIOD OF TIME. GREEN
this is a technical problem.have someone professional come and take a look.
Jun 15, 2010 | Heating & Cooling
I shut down my computer at night. When I come back the next morning the computer is off and the monitor is in standby with an orange power light (so far so good). When I turn the computer on, the monitor...
that blue light show and error or faulty problem internally or there a problem with in the connection or computer but first check the makers website or manual for troubleshooting.
Dec 13, 2009 | LG L1932TQ LCD Monitor
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
Opens for a short period of time only and then turns off again.
The problem is already solved. I bought a new battery and changed it.
Feb 02, 2009 | HP Pavilion dv1000 Notebook
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
TV shuts off and red standby/timer lights blinks red until I power the set off. When it shuts down it does so with a very loud snap. When I turn it back on the screen is blue and has light blue...
The most common cause for what you are seeing is a shorted gun in the picture tube. When 2 elements (heater and cathode) of one of the guns inside the neck of the picture tube touch, that gun goes full on and overloads the flyback (high voltage) transformer. If it is in the blue gun, the screen will go bright blue with light blue "retrace" lines in it. The computer senses the overload and shuts the set off. At 2 years old the tech most likely tried removing the short by arcing between the elements. This works sometimes but the short often comes back a few months later. Another attempt at removing the short could be tried, and it might work this time, but it may or may not work for long. The ony other solution is to replace the picture tube but that would cost much more than the set is worth. A qualified tech will be able to tell you if this is the problem in your set.
Aug 21, 2007 | Sony KV-35S36 35" TV
Liquid Video L17LCD2 17" Flat Panel LCD Monitor Logo
74 people viewed this question
Top Liquid Video Computers & Internet Experts
Marcin
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
