Question about Casio Exilim Zoom EX-Z80 Digital Camera
Lens error and how much will cost if i change the lens....
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 15, 2010
Showing system error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a video summary of some of the steps (note that the above link goes into much greater detail):
Nov 24, 2011 | Nikon Coolpix 4300 Digital Camera
LENS ERROR SHOW NIKON S220
Sep 28, 2011 | Nikon COOLPIX S220 Digital Camera
My canon a470 camera lens wont retract and keep saying lens error restart camera-please help?
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 10, 2011 | Canon PowerShot A470 Digital Camera
Turn camera on lens error comes up 0xo41100000 how can i fix this?
lens error is not so easy to fix. this error comes if you have make a pressure on the camera lens..or the camera have becom a knock or is falling down.. this problem can you solve with the lens changement. this fixing is for professional fixer. if you was in italy i can fix you this problem with 50 euro but in uk i dont now what is the cost for change the lens of your camera... i am sorry that i can t help you better..but if you dont have knowledge for camera fixing, is impossible that you can fix it alone
Oct 10, 2010 | Pentax Optio E60 Digital Camera
How much would it cost to fix a lens error
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Aug 10, 2010 | Canon PowerShot A480 Digital Camera
My coolpix displays lens error when it is turned on. The lens opens and closes twice before the display reads lens error.
his generally happens if you have dropped it. when the message comes. try tapping the camera. if it works then you are lucky. if not then you have to change the lens array. it costs about 60$
Jul 15, 2009 | Nikon Cameras
I dropped my camera and now the lens won't retract
get written estimate - should be free and then cost new camera -expect they will say about 2 mos to get repaired
Sep 11, 2008 | Kodak EasyShare C330 Digital Camera
Re lens damage
When replacing a lens, there is some optical and electronic calibration required.
In your situation, if there is any part of the camera case that was knocked out of shape or slightly bent, then for sure the repair will be too expensive.
A bend or change of a few thousandths of an inch of the case cannot be seen by eye. But with the precision and magnification of the lens, any slight misalignmenet would be visable in the photos.
You should call Canon just to know the cost of servicing the camera. I am sure it will be more than 50% of the cost of a new one.
Jerry G.
Apr 02, 2008 | Canon PowerShot A710 IS Digital Camera
Lens error 122
ok,white screen is LCDproblum or flex conecting pro,error 122 is ur lens barrel stuckup or mechanical gears problum this is repareable u try ur local repairer
Mar 03, 2008 | Kodak EasyShare M853 Digital Camera
Canon powersshot a450
Lens motor system is shot - if more than a year old replace camera- repairs costs can be silly
Aug 14, 2007 | Canon PowerShot A450 Digital Camera
Casio Exilim Zoom EX-Z80 Digital Camera Logo
108 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
