Question about Philips 30PF9946 30 in. HD-Ready Plasma Television
You turn on the tv and for a fraction of a second the screen flashes blue then it goes black you can still hear the audio and change channels but no picture philis 30pf9946d/37
  • 132 Answers
Check your wires for a break in the circut, then check your connections to ensure good contact from your adapter.
Posted on Oct 15, 2010
  • 998 Answers
Try to check the cathode lights of your plasma it might be busted.
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
How can I repair my LGSMART TV?
hi sounds like failed led or leds in the panel, thanks
shaun
Mar 02, 2017 | Televison & Video
I have a Olevia lt37hvs, When i plug it in the blue(olevia)light comes on then goes off and the screen will be blue for 5-6 second then go black for 1-2 seconds then screen goes blue again and it just...
tried to connect again the supply for main board and disconnect the supply for the inverter board of back light. and turn on the tv, if the indicator stay the inventer board was the cause of voltage drop at the power supply board.
Sep 08, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Polaroid LCD tv - model TLX-04244b . Flashes the blue polaroid screen then goes black ,I hear a buzz coming from the inverter board. I have replaced both inverter boards and the same problems exisis .
I just changed out the invertor boards and mine was fixed. I had the same problem. Im not a TV repair man but replace the board thats buzzing and it will work again.
Jun 23, 2012 | Polaroid 4226TLMB 42 in. LCD TV
Black screen but still able to hear sound. Have tried turning off and leaving off for 24 hours and still no joy
This sounds like an LCD problem. My tv did something like this. Only my screen lit up and flashed random colors.I took it to a shop and was told the LCD was bad and throw it away.I kept the tv and just found a replacement LCD on EBAY for a grand total of $88.Now I can fix my tv for a fraction of an new one. The part number is LTM190M2-L31.I hope this helps.
Jan 14, 2010 | Samsung LN-T1953H 19 in. LCD HDTV
No Video but have Audio
I found my product manual and called the Tech Support line. They said it was a problem with the display and would have to schedule and appointment to fix it.
Jun 19, 2009 | Dynex DX-LCD32-09 LCD TV
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Black screen - sound works
westinghouse_w32701_27_in_hdtv_lcd
power on no picture good sound and channel page up and down works
on background u can see dark picture
Aug 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Open Questions:
HDMI quit working I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent problems with the HDMI audio bleeding in to the other inputs. Sometimes if for instance I turned on the PC, I could hear the audio from the HDMI output on the satellite receiver through the TV speakers. Other times, I might just hear a crackle in the audio when in PC mode. If I switched back and forth between HDMI and PC inputs a couple of times, both issues would go away. I tell this just as background to what happened next. Since I have my PC hooked to the VGA input on the TV, I have been forced to manually switch the HDMI input from the Satellite receiver to my XBOX 360. (Sorry, I was too cheap to buy the $100 switch). Anyway, I usuall make this switch hot (TV on, Satellite receiver on, but XBOX off. This system although a pain, was working until yesterday. I was watching HD satellite, when I decided to play XBOX. I switched the HDMI cable, but when I turned the XBOX on, it wouldn't start up. I immediately assumed my XBOX had crapped out , but when I switche the HDMI cable back to the satellite, the TV would not recognize the signal. I have since tried the XBOX and satellite on another tv with HDMI, and both still work fine. I am thinking that some sort of switch in the tv has gone out, but I don't know. Should I just junk this TV for a new 1080P? My problem with doing that is that I use PIP with the PC on one side, and HDMI on the other. This tv does that, but I can't find another tv that does.
Feb 28, 2017 | Philips 30PF9946 30 in. HD-Ready Plasma...
Philips 30PF9946 30 in. HD-Ready Plasma Television Logo
308 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
