Question about Dell Vostro 1015 Laptop
My scroll pad is not working help me? - Dell Vostro 1015 Laptop
    President:
  • 1,015 Answers
Well I will try my best to help you with the little bit of information you have given. There are several things that might have caused this issue. It could be a software issue(new program installed or a windows update), driver issue(update or malfunction), touchpad settings were changed(scroll function disabled) or the scroll part of your touchpad is inop due defective parts.
The first thing I suggest is checking the touchpad settings. These settings can be usally found by double left clicking on the toupad icon found in the lower right hand corner of your taskbar(by clock). You may need to expand your icons to see it. That should take you to the mouse/touchpad properties where you can make adjustments to your touchpad and scrollpad. If you cannot find the icon then you can use the control panel and then pick the keyboard/mouse settings. If the scroll is not disable and all the settings appear correct then comes the next step.
Next go into the control panel and select hardware and then the device manager. Once you are in the device manager you will need to locate the mouse tab and expand it. Then right click on the mouse device and select uninstall device. Once you do this your touchpad will stop working and this is expected. You will then need to re-boot your laptop. So you will need to press "ctrl" "alt" and "del" all at the same time. That will bring up the task manager where you can use the tab key to highlight restart and then hit enter to restart the computer. If that does not work hit control, alt and delete a second time and the computer should shut down. Now re-start or wait for the computer to re-start. Windows will recognize the touchpad and should re-install the drivers automatically. Hopefully your scrollpad starts working again. If not on to the next step.
The last thing to try is using system restore. System restore allows you to return your computer to a state it was before the scrollpad stopped working. You can find system restore in the control panel. It's location is different for each version of windows. So the best thing to do is go to help and support and do a search for "system restore". Then you can find where to go to start it. You will want to pick a date that was just before the scroll pad stopped working. Once you choose a date the computer will be restored back to that date. Any software that you have installed after that date will be gone. Files,pictures and anything that existed before that date will still be there. Once this is done check to see if you scrollpad is working. If it is then you may have installed a program or there was an update that disabled it. Be aware if that program or software is installed again the same problem could happen. If it does not work after trying these things then I would say that the scroll pad itself is defective. Replacing the scroll pad is not an easy task and the parts would cost more than it is worth. I suggest getting a usb mouse with a scroll function to use with your laptop if this is the case. They are pretty cheap and simple to install...just plug it in.
I hope that I have helped you with your problem and thanks for using FixYa.
Posted on Oct 15, 2010
    Guru:
  • 832 Answers
Hi there!
Did you tried reinstalling your mouse drivers? please do so, if still doesn't work, you may bring your laptop to a service center to further check the hardware.
regards, fossildude
Scroll pad wont work!!!
Click on the Scroll Lock or Num Lock buttons
Dec 13, 2013 | Gateway NE56R10u Laptop Intel Celeron...
I recently deleted some old files and temp files to free up disc space and when i rebooted, the scroll on the right side of the mouse pad is not working the buttons are and the double click function is too...
The files in temp folder can be safely deleted and have nothing to do with touch pad atleast. Something else might have gone wrong. Just check from the Device Manager or Control Pannel that the drivers for touch pad are installed. If so, check for the scroll option (synaptics touch pad utility) and set it accordingly.
If it doesn't work, you may download and reinstall the touch pad drivers again from the manufacturers support site.
Hope it helps! Good Luck!
CreativeTECH
Apr 20, 2011 | Computers & Internet
Can not scroll on lap top pad
Is your pad scroll capable? Not all are. If it is, have you enabled it in the mouse settings via control panel? The default mode for some pads is non-scrolling and you have to manually enable this function. Also, some pads have small areas where the scroll works. Usually along the right and bottom edges of the pad. Anywhere else = no scroll.
Sep 15, 2009 | Computers & Internet
Touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Mar 14, 2009 | HP Pavilion dv4000 Notebook
Touch pad
If you have the drivers for the touchpad installed then you should be able to run your finger up or down the right hand side of the touch pad and have it scroll the page you are one.
If it doesn't work then you may need to either reinstall the drivers or find the program that handles the touch pad settings (usually found in program files) and turn the scrolling feature back on.
Hope that helps :)
Mar 13, 2009 | HP Compaq Presario 2200 Notebook
I WAS READING AN ARTICALE IN THE TOUCH PAD SENTIVE ON THE MOUSE IS TO HIGH OR TO LOW
GO INTO CONTROL PANAL OPEN THE MOUSE LOOK IN THE PROPERTIES SETTING IN THE SCROL SECTION AND ADJUST THE SETTING WITCH WAY YOU WANT YOU WANT THE MOUSE TO WORK, WHEEL ADJUSTMENT MAY ALSO HELP ON HOW MANY LINE DO YOU WANT TO DO AT ONE TIME
Jan 03, 2009 | Acer Aspire 4520-5582 Notebook
My touchpad mouse has stopped scrolling otherwise it works
the scroll in a touch pad has nothing to do with the touch pad. It is the software that handles it. If you know what software or drivers you need, try reinstalling it. I can't help you to much with that part. All I know is that your pad is perfectly fine.
Nov 08, 2008 | Computers & Internet
Windows Vista Laptop Touch Pad Scroll not working
download touch pad driver from internet
giveme your laptop company and model number
Apr 03, 2008 | Computers & Internet
Defective Scroll Pad iRiver H10 20Gb
As stated above the 5/6gb units and the 20 gb units use the same scroll bars but they sit on different metal platforms. The platforms are not interchangable. The only way to do it is to remove the old/broken scroll bar from the 20gb metal platform. Then CAREFULY peel the working scroll bar off the 5gb platform be very careful the unit is in multiple layers of plastic and is very FRAGILE. Re attach the working scroll bar to the 20 gb platform and gently plug the little tail into the slot on the motherboard.
OR, buy a working 20 gb scroll bar from ebay. two screws and you're done.
Apr 21, 2007 | iRiver H10 MP3 Player
Touch pad issues
Next time you try scrolling on the touch pad, also push down (really) hard on the touch pad(kind of like you're squeezing the player). Keep doing this, and you may get it working. I've dropped mine a few times, and this push/squeeze/scroll seemed to work.
Aug 10, 2006 | Creative Labs Zen Touch MP3 Player
Dell Vostro 1015 Laptop Logo
511 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
