Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Dropped my camera lens seems to be stuck
I dropped my ND40. It still takes pictures ok, but the lens seems to be stuck. I cannon move it. Any thoughts. thanks
    Problem Solver:
  • 6 Answers
Contact Nikon USA (if you're in the US) and ship them the camera and attached lens.This will cost, which they will estimate up-front, but it is the absolutely best solution to the problem. Anything else is a hack job!
Posted on Jun 06, 2008
Hi, I have a Cannon Powershot A610 and when I take a picture the picture comes out too dark. How can I adjust the it? thanks
"Too dark" or do you really mean "totally black"? I'm asking because a stuck shutter is a very common failure mode for your particular model camera.
The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 06, 2011 | Canon PowerShot A610 Digital Camera
I have a Cannon 40D 28-135mm lens. With the lens in auto focus, the lens will act as if it has found the target will focus, beep, ready to shoot. The lens then makes a focusing sound and moves just a...
Does the camera still work even thought it does a small extra adjustment?
Are your pictures fine and is the camera working ok otherwise?
If your pictures are good then theres noting to worry about.
if on the other hand you can't take pictures, try reseting the camera, there should be a small reset hole in it.
Jul 04, 2008 | Canon Cameras
I dropped my cannon powershot a1100 it'll play back the pictures on the memory card but the lens won't come out to take any pictures. and when i push the on/off button it won't work. how can i fix it?
It sounds like you dropped it on the lense, and the little motor inside that moves it broke. If you still have a warrenty on the camera, exchange it at the place you got it or send it to the manufacturer.
Mar 08, 2011 | Canon PowerShot A1100 IS Digital Camera
My cannon s21s has a blank screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 20, 2009 | Canon Cameras
Hi! My grandson dropped my cannon sd750 while the
The lens cover is not really needed, but you can replace it yourself if you can find that other part. If you can't find it, just remove the lens cover entirely and just be careful with your lens. Here's an example:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 08, 2009 | Cameras
Cannon PowerShot S2 IS lens is stuck
I have the exact same problem, took it completely apart removed the zoom motor, physically turned the zoom gear and retracted the lens, reinstalled the motor, put it all back together, and found that I had the same problem and the lens wouldn't move out, so im pretty certain that the motor is bad, as the lens moves smoothly once the motor is not attached to it... looking for a replacement motor as i type...
May 29, 2009 | Canon PowerShot S2 IS Digital Camera
E18-lens stuck out-not fully out-won't budgein or out any further
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. As you've dropped it, you might need to start with Fix #7:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 06, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
I have a cannon powershot sd79is. it states lens error, restart camera but when I do so error is still there. it seems the lens is stuck
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 25, 2009 | Cameras
Autofcous and manual focus do not work
excuse me if this is a dumb question but you wouldn't believe the things people do...., but in manual mode are you actually manually trying to move the lens? as manual mode means just that you take hold of the lens and turn it. If it wont turn it sounds like the lens is jammed and needs returning/repairing.
if taking hold of the lens and turning it works for manual mode, take the lens off and clean the gold contacts on both the camera and the lens with a pencil erasor this may bring the auto focus back to life, switch back to auto and try again, if not its most likely the lens but take the body to a canon store and try another lens just to double check the body is ok
drop me a line if i can be of further assistance
best of luck
Jun 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Lens is stuck open
We had the same problem with a Casio Exilim. Had been stuck for months...had nearly given up until I saw another post about banging the camera pretty forcefully to get the lens unstuck. I hit it once on the bottom onto my desk(w/ paper and blotter on the desk-so soft), then twice with the back of the camera against the desk. I turned it on and the lens was unstuck!! Immediately took a couple pictures and it seems to be working fine! If the camera may be lost, you've got nothing to lose to try this out...Good luck!
Apr 26, 2008 | Casio Exilim EX-S500 Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
262 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
