Question about HP (153147-001) Sound Card
I need to select my soundcard on my hp pavillion laptop, but it won't allow me. I'm trying to run audacity and need the soundcard as my recording device, but the computer does not show the soundcard as the device, it only shows the microphone device.
  • 707 Answers
THAT'S CORRECT. TRY UPDATING OR ROLLING BACK DRIVERS FOR REALTEK. OR GO HERE DOWNLOAD AND INSTALL
http://www.realtek.com.tw/Downloads/downloadsCheck.aspx?Langid=1&PNid=14&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
GO TO DEVICE MANAGER MAKE SURE AUDIO IS WORKING WITH NO CONFLICTS. WILL NOT SHOW AUDIO CARD AS RECORDING DEVICE.
GOOD LUCK
Posted on Oct 15, 2010
    Genius:
  • HP Expert
  • 1,325 Answers
PCI audio card - Creative Labs Sound Blaster Live is the sound card (according to the p/n)
have you considered reformatting your computer ? do you have the recovery CDs ?
if not go here http://restoredisks.com/
How to transfer vinyl to cd-simply-I have manual but very confusing-simple step by step needed-thank you-Al B
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
  1. Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
  2. Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
    • Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
    • Make sure that your cables and adapters support stereo.
  3. Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
  4. Start playing the record on your record player.
  5. Hit the red circle that represents the "record" button in Audacity.
  6. Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
  7. Hit "Stop" to stop the recording.
  8. Stop the record player.
  9. Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
  10. Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
Aug 26, 2015 | Audio Players & Recorders
I want to record along with backing tracks on computer using audacity
Well depends a bit what soundcard you've got. If it is a good one and has an input channel you can connect your instrument with that.
in the preferences of Audacity you can select where you're recording from. So you have to select your soundcard there. It will also record the backingtrack as well if the same souncard is used. I use Reaper a DAW that is shareware and drag the backingtrack to a track and play along with it.. Advantage of reaper is that you can also use vst plugins. Hope you succeed ;-)
Oct 10, 2014 | Music
Why can I not record to a CD from the "aux in" port?
Your question has not provided enough information. Are you trying to record vinyl onto a cd?
You cannot record onto a normal cd player. You need a cd burner(/recorder).
Vinyl turntables have a quieter output signal too so unless you have a device that has a phono (vinyl) input you will not be able to record your vinyl. If you have a laptop then the easiest way to record vinyl onto cd is to buy a soundcard that has phono input. You can then use free software (programme) like audacity to record your vinyl and covert it to a format (wav aiff or mp3) to burn to cd using iTunes or Windows Media player.
Sep 27, 2014 | Audio Players & Recorders
Getting lidl silvercrest turntable / audacity to transfer records to computer
Assuming you've installed the Audacity software, first check your recording device. If you use Windows, first check the Audio Control Panel. For Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click on the Manage Audio Devices link. In that window, click on the Recording tab. Select the USB option and make it the active device.
In Audacity, you may also need to make sure that this is the recording device that is active. That should be the third drop down from the left in the Device Toolbar. (If it isn't visible, click View > Toolbars and check it.) The Device Toolbar is right above the recording trace section in my version of Audacity.
Now click Record (the red circle) and start your turntable. Do you see a change in the trace? You should see a flat line for up to 10 seconds and then see this change to a set of high and low values.
If you don't get this, check if your USB ports are working. If you use a USB hub, try a direct connection. Check the device manager under Universal Serial Bus for a triangle with a red x or a yellow triangle. Try updating the driver by right clicking on the device. Also check Windows Update (for an optional update) or your computer manufacturer site for a new driver.
Unfortunately with the USB, you can't hear the recording as it is made. Do a short recording and then stop it. Then play back the selection. Adjust the input volume level lower if your trace is hitting the top of the box. This is clipping and your recording won't include the full signal from your record.
I've used Audacity for recording cassettes through the line in port. You can do this with some turntables if you add a pre-amplifier and use RCA to 3.5 mm adapter. Connect to the line in on the back of the desktop (blue).
If you could not install Audacity, go to http://audacity.sourceforge.net/ to get a version that works on your computer's OS.
I hope this helps.
Jul 05, 2012 | Audio Players & Recorders
No digital line in or stereo mix option vista hp artist edition
Your sound card fitted to you unit can not support what your trying to do - end of story
Mar 09, 2009 | HP Pavilion dv2890NR Notebook
Cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
Sep 15, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Audacity download
Greeting My name is Mark And I will be able to assist you. If you are trying to record music in to audacity it must be in a mp3 format. This can be achieved by changing the format of your music by downloading "switch sound" converter then change the format to mp3. I use audacity all the time It is a great free program.
Be mucho blessed,
Mark
Sep 13, 2008 | HP Pavilion dv6000z Notebook
Hp pavillion dv6000 - speakers buzzing after recording
First of all, check if the issue is with the Microphones of your Notebook.
Try disabling or turning off the Microphone of the Notebook to check this.
Additionally, try reinstalling the Audio Drivers of the notebook if possible by checking the Notebook driver page.
Sep 06, 2008 | HP Pavilion dv9000z Notebook
How to use
the best way is to connect your master output to the uca200 input and uca out to your amp. u have to use a sound editing software to record.suggestions-audacity.
Yours DjNicq
Jul 21, 2008 | Behringer (UCA202) Sound Card
NO SOUND ON PLAY-BACK
I had a similar problem but I just plugged in some heaphones into the mic and I got everything in the DAW to play back through them.
May 18, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
HP (153147-001) Sound Card Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
