Question about ViewSonic VX924 19" LCD Monitor
When i start up my computer my view sonic vx924 monitor flickers on and off for 5-10 minutes then stops and works fine. whats wrong?
  • 11,361 Answers
Look for bad caps as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX924/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 15, 2010
Monitor is black, power line flashing. Help
I assume you mean the power light is flashing? This means that there is aconnection problem or your video card/chip is faulty. Check both of the VGA cable (monitor & PC) are securely connected and there are no bad twists or bends in it, if so replace it. If both ends are secure and cable is o.k. then it is likely that the video card/chip is faulty and needs replacing. Best of luck. Ian.
Mar 29, 2010 | ViewSonic VX924 19" LCD Monitor
No power light - no power
Open up the set, check the fuse first then look for bad caps in the power supply, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | ViewSonic VX924 19" LCD Monitor
My view sonic monitor does not work properly
sounds like the power supply inside of the monitor is going bad. did you replace the cable from tv to the wall?
Oct 16, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Problem with View sonic monitor
Hold down CTRL+ALT and hit the up arrow.
That should rotate your screen.
Aug 07, 2008 | ViewSonic VX924 19" LCD Monitor
View sonic flat screen monitor
Problem seemed to be a short in the power cable to the monitor. Replaced the power cable and for the time, the monitor is working correctly.
Jul 07, 2008 | ViewSonic VX924 19" LCD Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
Flashing on and off
I would suggest trying another monitor to rule out your PC or monitor card. I would also check the video settings on the PC. Then assuming your cable/connector and video card are okay, it sounds like a lamp or lamp driver (a.k.a. ballast or inverter) issue. In other words, an internal issue that probably needs component-level troubleshooting.
Jan 08, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
83 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
