Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
Setup please i need your help on this pressing matter. my cdrom drive is faulty hence i cant run the storejet 2.5 in order to run my new external hard drive. please is there a download setup file you can assist me with.
  • devrajshenoy Aug 12, 2008
    STOREJET 25 mOBILE
Recently i bought Transcend Jetflash 8GB pendrive. when i am copying mp3 and other vedio files, it is showing some different files with file extension. plz suggest me how to solve this problem
Posted on Jun 03, 2008
The driver switches on the blue light and run for about 10 seconds then stops and it cant be recorgnized by the pc, whats the matter please help i only have 3 months using it. my email address is...
Did you tried running it on other PC ? If it works on other PC then Try removing you USB drivers, restart your PC. and Insert your driver again.
If it doesn't, then try using other DATA cable.
Oct 08, 2013 | Transcend Information Transcend StoreJet...
How to format transcend 25 storejet 500gb
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you must go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Jun 27, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
My mac is reading my transcend storejet 25 mobile 320gb, but i cant copy files from my mac unto it
Hello Kinoshia,
It seems that Transcend external hard drive have different file system. This is because the Mac machine is not able to transfer the files on to external hard drive. Please format the Transcend external hard drive from Mac machine and then hard drive is ready to accept the data from Mac machine. The drive either has to be formatted for Mac( HFS & HFS+) or FAT32 partitions. If you want to use
Transcend external hard drive for both Windows and Macs than format the drive to be FAT32.
Jun 05, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I bought a new Transcend Storejet 25M 320 GB. When I connected it to my laptop, after the installation of the software by itsely, it said you need to format the drive. I pressed OK but the formatting...
Use partition magic 7.0/ 8.0/ 8.2 or advance, make new partitions and then format it. Sure, your problem will resolve. Let me contact for further more information.
Best of Luck
Mar 13, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I getting error 'USB device has malfuntioned and Windows does not recognize it" when I attach my transcend storejet 25 mobile to the computer. I have critical data in it and need somehow to get the...
Hi, most external hard drives come with a seperate power supply, the exception is "pocket" externals which some have the ability to run from the USB socket alone. They have laptop drives in them. Many of these drives come with a USB cable that occupies 2 USB sockets in order to obtain enough ppower to run. (Or a second cable that occupies a second USB with a power plug on the end for a drive. They will often not run on one socket. If your device came with a double USB lead then use this. If it came with an external power supply then use it as well as the USB lead. Try the same on another PC just to confirm the USB sockets on the one you currently use are ok or try a different device to prove correct function.
If all this fails to get your drive running then the drive itself is probably faulty. Is it under guarantee? If so then you can get a replacement. This will lose your data though as the guarantee does not cover stored information. In this situation, is the data more important than the drive? If very important, buy a replacement empty external drive case, remove your drive from the original case (voiding the warranty) and fit the drive in the new case and try again. If it now works you have a dead interface board in the old case, if still not working you have a faulty hard drive. Does the drive click continouously? If it spins then you could try data recovery software or run "HDD regenerator 1.71" on it to fix potentially bad sectors and try again. This is a time consuming process but if the data you need is saved then it is worth it!
I hope this helps
Steve at Olive country Computers.
Feb 20, 2011 | Transcend USA 120GB Storejet 2.5" SATA -...
The netbook can't detect the hard drive and doesn't boot up at all upon startup. Tried re-installing Windows XP from my external DVD rom but when it reached the middle of the install, message comes up...
Hello.
It's possible that your Master Boot Record is corrupted. To fix:
First, restart your computer with the Windows XP setup disk in the CD drive.
2. When prompted, boot from the CD drive by pressing any key. If Windows loads automatically, you will first have to enter the BIOS setup and change the order of the boot devices to start with the CD drive.
3. Once the setup loads, you will see the option to press R to repair a Windows installation.
4. Once the Recovery Console loads up, you will have to type in a number that corresponds to your Windows installation. This is normally just 1. Press Enter and then type in the Administrator password.
5. Now at the prompt, type in fixmbr. Your damaged MBR will now be replaced with a new master boot record and your computer should now be able to boot properly. Also run the fixboot command to repair the boot sector with a new one.
If still a problem, your hard drive is probably faulty and needs to be replaced.
Hope this resolves your problem.
Dec 11, 2010 | Compaq Presario Notebook
I purchased a WD My Passport external hard drive to transfer my iTunes files from a Mac to a Windows Vista machines. Had to reformat it to FAT+ first but copied the files from my Mac to the WD external....
Simple, your BIOS is setup to boot on external devices first. Try prioritizing your system to boot up to your system hard drive if you don't want to see that error anymore.
Jan 04, 2010 | Computers & Internet
Very slow computer
You can reformat the hard drive when installing windows. In order to get this done you will need a bootable windows instalation cd. Just start the computer and press f12 to select boot from cd. When the windows instalation starts, among the first things it will do is to ask you how to reformat the hard drive. In order for this to be shown however, you will need to boot the cd when you start the computer instead of running it from windows. Make sure you copy the files you don't want to loose to another hard drive or usb stick before you attempt this. Once you allow the windows instalation cd to format the drive you can't recover anything from it, and a new, fresh copy of windows will be installed with factory defaults.
If you need more informations please reply.
Jan 20, 2008 | Dell Dimension 2350 PC Desktop
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
105 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
