Question about Concept2 2 Rowing Machine
The display of my concept 2 monitor (PM2) does not work after replacing the batteries. Before now the battery leaked inside. How do I fix it ?
Display not working
Most likely the batteries in your display have been depleted. Check your console for the battery compartment and change them.
For customer service, Concept 2 can be reached at (800) 245-5676
Dec 02, 2013 | Concept2 2 Rowing Machine
My hp series HSTNN-105C won't turn on, but the lights that mean it is getting power from the charger is on, does anyone know how to fix this? if so, then what part do i need to replace, or do i ev
HP HSTNN-105C is a Laptop Battery,
http://www.usbphoneworld.com/hp-6120-hstnn-105c.html
Look on the bottom of the laptop, and in the white Service Tag.
Give me the Product Number. (P/N)
[NOTE*
S/N = Serial Number. Do NOT give out on a public forum. ONLY to authorized HP dealers, and repair shops ]
According to the website in the link above, this battery may fit;
HP Compaq NC6000 series, NC6120 series, NC6220 series, NC6400 series, NX6100 series, 6710B series, and 6910P series of Notebook PC's.
IF the above holds true there is NO panel to simply just remove, and you have access to the CMOS Battery. (Also referred to as RTC Battery. Real Time Clock Battery)
You MAY have to completely disassemble the laptop down to the motherboard in your hand. The CMOS battery is located on the Bottom of the motherboard.
HP Compaq NX6110 series is different. With these type of models the Keyboard is removed, to gain access to the RTC battery,
http://www.hardware.com.br/tutoriais/manutencao-notebooks-nx6110/parte.html
The above is in Spanish, and you are on Page 2. (Parte 2)
Posted for the photos.
Scroll the page down, and look at the second, third, fourth, and fifth photos.
The CMOS (RTC) Battery is the round silvery looking object, with the red wire attached.
NOTE*
There is a PROPER procedure for removing the RTC Battery. It isn't just remove the Keyboard, and replace the Battery.
1) ALL power is removed first. Remove the AC adapter (Charger) and Battery.
(Main battery)
2) FOLLOW Anti-Static Precautions. Static shock your laptop, and you will have an expensive doorstop, or paperweight.
3) The Keyboard does NOT have to be removed all the way.
Once you post what Product Number you have, I can give you detailed information.
Before we begin;
I would like you to attach an external VGA monitor, and see if the display is OK on it.
1) Laptop OFF, monitor OFF. Attach a VGA monitor to the VGA port on the laptop.
Do not know what HP Compaq laptop you have, can't give you detailed info of where your VGA connector (Port) is on your laptop.
This is an example of a VGA connector, and a VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
External VGA monitor:
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
2) Monitor attached turn it on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
There are however at least 3 display options;
A) Laptop internal monitor ONLY
B) Laptop internal monitor AND external VGA monitor
C) External VGA monitor ONLY
Press, and hold down on the Fn key. At the same time tap once on the Display Toggle-Over key.
Which one is it? It is one of the F keys at the top of the Keyboard.
F2, F3, F4, F5, and so on. It will have a monitor symbol on it, and a second one connected to it.
(GENERALLY, it is the F4 key for HP laptops. That is GENERALLY )
Tap once and no display on external monitor?
Hold the Fn key down again, and tap again on the Display Toggle-Over key.
It could be the laptop IS working, but there is a component, or components, that are bad for the internal monitor of the laptop.
Display doesn't show on laptop's LCD screen.
Could be something as simple as a bad connection of the Video Cable to the motherboard, or to the back of the LCD screen.
Could be a bad Video Cable.
Could be a bad screen Inverter.
Could be a bad Backlight.
For the above; a simple test,
Laptop on use a flashlight, and aim it at the LCD screen of the laptop.
Shine the flashlight at various angles.
Tell me what you see.
Primer:
An LCD screen does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or series of LED lights. (Present technology)
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm Thick, and almost as long as the LCD screen is high.
2mm is a Little more than 1/16th of an Inch, or about the width of this letter -
N )
Post back in a Comment.
Regards,
joecoolvette
Apr 09, 2012 | HP Computers & Internet
My computer willnot power up anymore.
Instructions
1.Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings.
2.Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet.
3.Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary.
4.Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover.
5.Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced.
6.Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too.
7.Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws.
I hope you find it very helpful. Thanks.
Oct 04, 2011 | HP DeskJet F4280 All In One Printer InkJet
Computer wont start in any mode, black screen
Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have 1.lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings.
Sep 28, 2011 | Computers & Internet
I just put a new battery in the Polar F4 heart rate monitor watch and it does not work. The battery died about 2 years ago and I never replaced it until now. How can I get the heart rate monitor working...
This is a common issue. The Polars and other Heart Rate monitors are not designed to be fixed by the consumers except for very specific models. These only look like watches, they are in fact mini computers and very susceptible to internal damage if not handled properly.
You need to send the unit it to a Polar Authorized Service Center to have fixed properly. There is not reset within the computer, if you had done everything correctly then it would work.
Dec 12, 2010 | Polar F4 Heart Rate Monitor Watch
Well my digital concepts camera has been charging for three days and it still wont turn on
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Oct 25, 2009 | Digital Concepts Cameras
OMRON Model Hem-711's display is messed up. Over one-half the top of the numbers are not showing. Is there a fix for this, or should I scrap it. I assume it an eternal problem in the window (Liquid...
Same problem on my Omron HEM-711. Manufactured in 2003, past the 5-yr warranty. Cust Suppt told me to replace unit. I opened the unit up and looked inside. Two very tight phillips screws, one on back panel, other in battery compartment. Case pries apart. LCD display looked intact, ribbon was undamaged. Unit appeared to work properly, just did not display correct reading, some of the liquid crystals in a few of the digits were not activating. I installed batteries with case still open, turned power on while pressing ribbon along edge of circuit board. Ribbon is manufactured with glue to circuit board, some of the leads come loose after several years due to manufacturing defect. In my case, pressing towards the bottom side corrected problem. You can see when it's working properly because all the display crystals light up simultaneously when unit is first powered up. I clamped down ribbon with two small paper clips insulated with a few bits of paper, works fine now, saved eighty bucks.
Sep 05, 2009 | Omron HEM-711 IntelliSense Automatic Blood...
My pm2 only has a functioning low speaker, the
www.fostexusa.com Then service centers, enter your state and model number. That will get you Authorized Service. Hope this helps
Jul 09, 2009 | Fostex CR500 CD Player / Recorder
LCD Monitor takes time to display HANNS.G Model
there is leak capacitors problem inside of your monitor they need to be replace so that your monitor work normaly
May 22, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Concept2 2 Rowing Machine Logo
810 people viewed this question
Top Concept2 Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Concept2 Exercise and Fitnes Expert? Answer questions, earn points and help others
