Question about Sony Handycam DCR-TRV510 Digital Camcorder
Error C:31:42 I am unable to play any tapes as this error C:31:42 is immediate - along w/ an eject symbol in the middle of the screen. Is this reparable? If so, how and is it something I (novice) can attempt? Thank You, Vangie
2nd Aug 08. Seattle.
perfect solution
1. Fully charge the battery
2. remove and put the battery back.
3. remove and put the cassette back
4. smack on all sides. Moderate force :-)
it works !!!!!!!! Smacking does the job actually
Thanks to whoever did it first
mine works just perfect now
Thanks
jon
Posted on Aug 03, 2008
    President:
  • 4,402 Answers
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jun 11, 2008
Tape will not run
The "will not run problem" was solved by replacing the CR-2025 Lithium battery. The eject symbol continues to appear sometimes and I can remove it and continue operating the camera by turning the power supply "Off then On" again. Camera is now running a recorded cassette but quality of picture is low.
Jan 14, 2010 | Sony Handycam CCD-TRV68 Camcorder
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Jun 02, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Error Code C:31:00 in a Sony CCD-TRV75 Handycam Camcorder
    This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment
 Thanks for using fixya.
May 21, 2009 | Sony Handycam CCD-TRV75 Camcorder
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Tape/Display problem
Straight from the manual:
C:21:ss Moisture condensation has occurred.
-> Remove the cassette and leave your camcorder for at least one hour to acclimatize (p. 291).
Mar 12, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
Cannot play tape nor record on tape
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Oct 08, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
Error "04" on display & tape won't eject
you have bad capacitors in your power supply. i would suggest you take your unit to a good shop in your area and request a power supply re-build and mode switch cleaning.
Jan 22, 2007 | JVC BR-S822DXU VHS/S-VHS playback VCR
Sony Handycam DCR-TRV510 Digital Camcorder Logo
210 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
