Question about Sony Ericsson XPERIA X10 Cell Phone
How do I set up my voicemail on the sony xperia? Ive held down 1 and nothing works....
Go to your Dialer..hold down the number 1 button and it'll take you to the voicemail setup
Posted on Dec 18, 2010
My phone hasnt been used for a few mths when ive put it on charge theres a red light and the sony logo keeps flashing on and off
It's probably just charging. It's gone completely dead, no residual charge left at all, and it will do that because the phone is off and charging. After it does this awhile, you can turn it on while it finishes charging.
Mar 07, 2016 | Sony Xperia Z2
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA S smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA S
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
Dec 19, 2013 | Sony Ericsson XPERIA S LT26I Nozomi Arc HD
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Mar 05, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Ive set it to the wrong language. how do i choose the correct language
Press the first button on the Xperia X10 the one with four squares and select settings i.e the image with the screwdriver and spanner on the lower right.Keep scrolling down the list until you see an " A with three dots under it" . Should be just under the search (Magnifying glass icon).There select the first option.On clicking you will be presented with a language list scroll down and select English.
Jan 19, 2011 | Sony Ericsson XPERIA X10 Cell Phone
How do I listen to my voice messages? what do I do?
you can hold down 1 or dial 123 and this will take you to your voicemail box. you can also dial your phone number and when you hear your message press * and then your voicemail pin (should be the last 4 of your phone number) and youre set!
Jan 03, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Avaya Partner line always lit
If the line button is lit then something within the system has picked it up. If the phone is a multiline set, the line 1 light on the set that is using the line will show green. The line could also be held by either a cordless phone on the system or the voicemail system. The easiest way to clear the line (if the held set isn't apparent) would be to cycle down the power to the phone system for a moment. That will clear the line if its held by the voicemail
Jun 02, 2010 | Avaya Corded Phone avaparp18d
I will like to change my xperia x1 phone language
Tap the windows start --> Settings --> System --> Regional Settings, on the Region tab, select your Language.
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more.
Apr 20, 2010 | Sony Ericsson XPERIA X1 Smartphone
Nokia 1600 - Key #1 Voicemail
go to setting>restore factory setting>enter 12345
now restart phone
preess and hold 1.
enter the no of Voicemailbox
Feb 16, 2008 | Nokia 1600 Cellular Phone
I want to change the # to access my voicemail
Go to Main menu, then "Messaging". Within Messaging go down to "Message Settings". #3 is voicemail. click voicemail and you will be able to edit the number.
Oct 25, 2007 | LG Shine KE970 Cellular Phone
Sony Ericsson XPERIA X10 Cell Phone Logo
1,694 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
