Question about Cell Phones
There is one icon in green colour at the top of the display it looks like U shape and In the middle of the U one arrow upwards. This U shape is looks like a half of reqtangle (cut reqtangle in middle horizontally) So please advice me what is it?
  • 597 Answers
The phone that brings up such symbol is a nokia phone.
The symbol simply is communicating something to you, and it means there an open operation you need to be attended to.
Mostly that comes up when you have a message that is not sent(go to the outbox of your phone for any unsent message), or a message in your inbox that you have not read or maybe you have a missed call you have not checked(go to call log and select the missed calls).
The solutions are in the brackets, follow them and the symbol will leave the screen. Do not panic, your phone is not having any software or hardware problem.
Take care
Posted on Oct 15, 2010
I have wifi but not sure if i am using it.not good on computer.
Hi again Donald
On a Windows 10 computer there will be a small icon down by the clock on the lower right side. It may be hidden under the upward facing arrow ^. Click it and look for the icon that looks like a Monitor. Click it and the top line tells you if you are connected.
Dec 19, 2016 | Computers & Internet
I found a new icon on the top of my Iphone 3g the icon is u shape arrow with lock beside the time display what is that and i can i remove it
It means that when you turn your phone, the screen is locked from rotating with it. To change this, Press home twice quickly, slide left & then press the icon with the lock in the middle of the circular arrow.
Oct 22, 2012 | Apple iPhone 3G
How do I turn up the volume control IPhone 3GS?
when you hold the Iphone in your hand with the round button with the square inside it on the bottom of the phone. turn the right side of the phone down to the floor while you do this look for 3 buttons on the side of the phone the TOP button must be pushed upwards at all times this flip switch is your MUTE switch pushed down it is in must mode switched up is sound mode.
Below this is 2 buttons the button just under the top flip switch is volume up the other one is volume down there ya go.
Please rate my solution and leave testimonial this is how i earn my achievements thanks in advance.
Apr 22, 2012 | Apple Cell Phones
Can I get rid of the date from my pictures?
To turn on or off the Date and Time stamp features, push the menu button. It's the small silver button on the back panel directly beneath the printed letter M, and just above the little green LED. This opens the menu. Now, press the right side of the ring shaped control button, where the little lightning arrow is. This will scroll through the different menu categories. Keep scrolling until you get to the one at the far right of the screen. It is a blue icon that looks like an envelope and a clock. This will bring up the menu for toggling the Date and Time stamp. Use the top and bottom of the ring to select the setting you want, and press the button in the middle of the ring, marked SET DISP, to select it. Then press the menu button again to get out of the menu and return to taking pictures.
Jan 20, 2011 | Polaroid i830 Digital Camera
The blue is oval shape drawn upward on the bottom and oval shape drawn on the top middle
YOU HAVE CONVERGENCE PROBLEM. you need to have an electronic technition replace convergence ics and related resistors and pico fuse. J.D.W.
Jun 25, 2010 | Samsung HCM5525W 55" Rear Projection...
U-Line clear Icemaker clr2160 cube shape
Hi Joe
That is normal. You will get that dimple because the grid is shaped that way. You can try adjusting the thickness. Hold the up arrow then press the down arrow 3 times,then release the up arrow last.You should see a number 0-5 or 0 to -5. when that happens use the up arrow to 3 then press the light key. This should take it back to ice on the display. Wait 24 hours and check the ice.
Apr 06, 2009 | U-Line Refrigerator Ice Maker
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
My Cyberhome DVD player power on Button never turns to green
There was a problem with Electrolytic capacitors a few years back. It affected all kinds of electronics. When these capacitors blow, the unit may look dead or if operating act erratic.
With unit unplugged open it, and look at the power supply (small tan board). Check the electrolytic capacitors they are the taller cylinder shaped objects on the board. Look at the top of all of them, they should be flat. If any are bulged upward, they need to be replaced. The two suspect ones will be towards the front of the unit, by the transformer.
Aug 04, 2008 | Cyberhome CH-DVD 300 DVD Player
Resistors and capacitors
Resistors are usually cylindrical, depressed in the middle and have three coloured rings (sometimes 4) around it to show the resistance value (but they do come in other shapes as well). The leads are generally on the base, one on each end. They are usually placed length-wise on the board. Here is a sample pic:
Capacitors, on the other had, are usually cylindrical all the way through and are encircled by a plastic sheath. Sometimes they look like small rectangualr compressed boxes.The leads are usually both at the base end on one end only. The top or cap is usually visible and point upwards from the board. They have their values usually printed on the plastic sheathing.
Here's a sample pic or two:
Here is a LINK that will give you more info, if you wish.
Hope that helps, and dont forget a Fixya rating!
Cheers,
IrishDruid.
May 10, 2008 | Panasonic PT-65WX51 65" Rear Projection...
Cell Phones Logo
62 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
