My laptop will only burn DVD-RW but i only have DVD R dvds and i was wondering how can i get my latop to burn DVD R dvds?
    Guru:
  • 832 Answers
Hi there!
What is the model of your laptop? Its is actually will depends on your laptop, but here's some infos about it, a DVD-R is a write-once format: once you've burned the data onto that DVD platter, the disk is forever frozen with that information. Add the "W" to that, and you'll find that DVD-RW can be erased or rewritten up to a thousand times. Seems kinda weird, but if you can do so, DVD-RW obviously has significant advantages over DVD-R. DVD-RAM was even more flexible, however, since it let you erase and rewrite sections of an existing DVD, something that you cannot do with DVD-RW.
Moving to the plus side is where things get a bit confusing, because DVD+RW came before DVD+R. The plus formats have the same data storage capacity as the minus formats (4.7GB), but DVD+RW offers faster writing, better internal linking (a technical obscurity you don't have to worry about), and support for drag-and-drop desktop files, which makes it easy to compose the contents of a disk. DVD+R is a write-once format intended to be more compatible with more DVD players, though at this point it seems to be about even with DVD-R, which remains the most compatible computer-burned DVD format.
In your case, since your drive is a DVD-RW, you're effectively limited to DVD-R and DVD-RW format discs. Stay away from any of the "plus" formats, as those won't work with your drive (and being newer, they cost more anyway). As to whether you want to use DVD-R or DVD-RW, that depends on what you want to use them for. DVD-R is a write-once format, just like CD-R, and you can't erase the data once it's written. DVD-RW is rewritable, so you can use it somewhat like a 4.7GB floppy disc, for all intents and purposes. In general, I suggest that you use DVD-R for archival purposes -- stuff that isn't going to change, and DVD-RW for more fluid data. DVD-RW discs are more expensive than DVD-R discs, so that may also influence your decision.
How do you confirm what format your drive works with? One way, if you're on a Mac, is to use the System Profiler application. You'll find this useful utility in Applications -> Utilities. Launch it, then click on the "ATA" item on the list. If you have an internal DVD burner, you'll see something like what I get: "PIONEER DVD-RW DVD-106D". If it's an external DVD drive, you might find it in SCSI, USB or FireWire, depending on how you hook it up.
As far as your second question, your data-burning application definitely has to be aware of the DVD format you want to use (i.e. DVD-R or DVD-RW in your case). For Windows, you can use GEAR for burning CDs, but you'd need to upgrade to GEAR Professional Edition to be able to burn both CDs and DVDs. Toast Titanium does burn DVD-R and DVD-RW so you should be set in that department.
Hope it helps, if you need further, pls contact me.
regards, fossildude
Posted on Oct 15, 2010
Dvd driver does not play or burn blank dvds compaq r4000 but it will play dvds & cd its got dvdrw/r rw dvd+r dl n the driver
Try another DVD-RW drive because it sounds like the laser is going bad. Burning requires alot of power from the laser. Playing DVD or playing cd's doesn't require much so thats why it would play those.
Feb 06, 2012 | HP Compaq Presario R4000 Notebook
What type of disks does my TS L632D burn? +- ,CD, DVD Can't get CD's to burn?
go to my computer and look at the cd drive.if it says cd-rom you can't burn cds,dvd-rom will not burn dvds.only cd-rw,dvd-ram,dvd/cd-rw can burn cds.dvd-+,dvd-minus and dvd ram can burn dvds
Aug 04, 2009 | Computers & Internet
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Should it burn
  1. DVD-RW reads and burn DVDs and CDs with or without a tv connections (computer accessory)
  2. DVD-R if its is a dvd player it should be able to read DVD and record dvds with tv connection (this is not a computer accessory but a tv accessory)
  3. DVD-ROM can only read and can not write on DVDs
Jan 11, 2008 | Computers & Internet
Need to set up my laptop with DVD RW drive to burn DVD
Yes, you can install the cd with the Nero Software in the new Laptop, and you will be able to write CDs or DVDs, but if you have a combo only you will only be able to write/burn CDs but read DVDs no problem.
ciao Ed.
Dec 10, 2007 | Computers & Internet
DVD / CD - RW Combo
When you say you cannot burn DVD's, do you mean you cannot burn DVD movies or do you mean you cannot burn data files to a DVD?
Burning DVD movies requires specific software to transcode the video and create a directory structure that DVD's players expect.
When you try to burn DVD's does it produce an error? What software are you using to burn?
Nov 19, 2007 | Acer Aspire 3680 Laptop
DVD drive not recognized as RW
If you use the Nero Smart start, you should see an icon to switch from burning CDs to burning DVDs. Once you click this icon, you should be able to burn to DVDs. Step-by-Step tuturials can be found for nero products here" Nero 7 http://ww2.nero.com/nero7/enu/Tutorials.html Nero 6 http://ww2.nero.com/nero6/enu/Tech_Support.html
Sep 16, 2006 | IBM ThinkPad T42 Notebook
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
