Hi i have a simpson EZI sensor top loader washing machine 12 months old and the lid lock alarm keeps peeping afther 10 mins into the load. How do i solve this problem and im also geting electric shocks whem i touch the machine.
  • 4 Answers
We had the same problem. Electrolux repairman came last week and replaced the lid switch parts with a new designed part. Told me the original part was subject to recall because of a problem with the design, was getting wet and stopping the maching operating correctly, and causing shocks. Ring Electrolux, should be covered under the two year warranty (but because the fault was there when the machine was bought, shouldn't matter even if warranty period had expired)
Posted on Oct 25, 2010
I have a Simpson ezi set 9.5 kg washing machine.It has stopped in the middle of a wash and the LCD screen I showing EFO.Can you tell me what this means and what I need to do to get machine to finish...
i have a 9.5kg simpson washing machine just 5months old and ive had this problem E20 quite frequently that its annoying. I printed out a manual and foundout why. i do not have the patience to remove draining hose im sure there is a simplier way. Ive notice if i tap the side of machine 3 to 5 times it drains lol! seriously never had a problem with my old 7.5kg hoover machine, please help
Jun 19, 2013 | Washing Machines
Simpson Ezi Sensor Front Loader keeps pausing during washes, doesn't put through the detergent.
you might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves.
You have to ask yourself what has changed,cheers.
Aug 14, 2012 | Simpson Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
I have a Simpson EZI Loader 5.5kg, where is the lint filter
HI just read your posting.Now the SIMPSON EZI LOADER comes in front and top loader versions.Which type is yours?Are you getting a lot of lint on your clothes?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 03, 2010 | Washing Machines
Hi, i have an Simpson Ezi Set 950 - Top Loader that im looking at bying online that needs a part 4 runing order, just wondering if u knw if and were i can get the part witch is (main Bearing) for it and if...
Hi just read your posting.Now how old is this Simpson.When I have replaced bearings in the EZI SET range of washing machines I always have to change both bearings and the main seal as well.Can you tell me why you need to change this bearing,Is the machine noisy on spin?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 18, 2010 | Washing Machines
Simpson ezi sensor 8.0 kg won't spin lid lock flashes and alarms
Hi
To solve the beeping and lid lock light flashing and the machine not doing a spin dry. Do the following.
I have a SIMPSON EZI SENSOR 8Kg top loader. This is what I did.
WARNING HIGH VOLTAGE. switch the power off and unplug the machine.
DO NOT do this if you are not familiar with working with high voltages.
To get access to the lid lock switch,
1. Remove 2 screws at the rear of the washer.
2. Remove 2 screws at the front of the machine located under the lid and covered by small round plastic plugs.
The top cover can now be raised gently from the front.
3. Remove the 2 screws that hold the lid switch.
4. Remove the clear plastic cover from the lid switch.
5. DANGER HIGH VOLTAGE ( Verify that power is off)
6. Find 2 blue wires these go to a magnetic reed switch (25mm long 3mm Diameter).
Cut the blue wires and discard the reed switch. insulate the ends of the blue wires and push them back into the track in different directions so there is no possibility that they can make contact with each other.
7. Find 2 white wires these go to a set of contacts that are mechanically closed by the solenoid.
8. Pull out the contacts and the 2 white wires.
9. Cut the white wires at the contacts, strip 5mm of plastic off the wires and twist them together, The wires will have corrosion, clean them with sand paper, they must make good contact. I recommend that you solder them together.
10. Insulate them and push them back into the track.
11.Reassemble starting with fitting the clear plastic cover.
Your good to go BUT BUT BUT,
WARNING
The Lid safety protecting during the spin dry cycle will no longer function,
So don't do this if you need the safety of the lid closed during the spin cycle.
Remove 2 screws at the back of the machine
Jul 30, 2010 | Fisher and Paykel IWL12 Top Load Washer
Simpson front loader washing machine repair person
I have Simpson EZI sensor 9.5kg and during the washing i have a EF message coming up.
Dec 21, 2009 | Washing Machines
Washing Machines Logo
453 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
