The remote control is not working - Televison & Video
  • 901 Answers
Hope the batteries are OK
To check the hand held remote do as follows. There are two layman method of checking!!
1. Tune your radio to M W band. Set the tuning pointer or dial at
650 khz range. Hold your remote close to the radio and start pressing the keys. If you hear garbled sound on pressing the keys the remote is functioning.
2. Use your mobile phone in, camera movie mode ( video shooting mode ) Point the remote front red screen end towards the camera.Watch the camera screen as you press some keys. If you find a light flshing and goinf off on pressing the keys, the remote is totally OK. To make 100% sure that the hand remote is OK, you have to try in similar mode TV only.
If the hand remote is OK, then the fault could be due to sensor at the TV end is faulty or the IC connected to the not responding etc.
On the item 1 & 2 if the remote is not functioning, open the remote by using screw driver and flip all around the cover from the grooves. If you can access the Printer Circuit Board, clean it with clean water and dry with a blower or hair dryer. Similarly clean the rubber pads also. Do not scrap the carbon track on the board. Good luck!!
Posted on Oct 15, 2010
Pioneer remote contyrol does't work with Pioneer 31FD blu ray
It will best to buy a remote control for TV, rather than try to repair this remote control. Sometimes, after repair, it won't work with Blu-ray; and it will be difficult to get a universal remote control for blue-ray. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Mar 02, 2014 | Pioneer Used Original VXX3351 Remote...
Vcr recocognizing my remote.
Hi coldrh what remote controler aer you using?
Jan 03, 2008 | Philips VRZ362AT VHS VCR
Tip
Polaroid HDTV Remote Control Codes
Polaroid HDTV Remote Codes
Can't find a code to program your universal remote to control your Polaroid HDTV? Can't find a listing for Polaroid in your remote control code list?
Many manufacturers recycle remote control codes, so often the best solution is to use the code search function of your universal remote.
Here are some remote control codes that have worked to control Polaroid HDTVs:
  1. My 19" w/DVD uses the following Mitsubishi code: 10178
  2. Dish Network remotes: 627, 659, or 688
  3. DirecTV RC64 remote control revealed a code of 10835. This means that 10835, 0835, 835 or some variant many work with many programmable remote controls. On my DirecTV DVR system, this was indicated as a Moxell and/or Motorola TV code.
  4. Use the mitsubshi tv codes they worked for me.
  5. Try Element codes if they are listed in your remote code list.
I hope that helps.
_____________________________________________
Polaroid HDTV Manual Download
Polaroid HDTV Service Manual Download
on May 02, 2010 | Televison & Video
Volume control on reciver isn't working. Only using remote control for volume works. So I must need a volume control for the receiver. Is this an easy fix or not worth the time to fix
Hello
You haven't specified if all the other functions are working with the remote control or not. If no functions are working with remote control, either there is no infrared emission from your remote control handset. Check it with the help of a cellphone with camera option. Cellphone digital camera can detect the infrared rays comes out of the remote control. Just put the cellphone to camera mode, and place the remote control just about 1 feet away from its camera lens and push each button on the remote control and see whether there is any image of infrared rays indicates at your cellphone camera screen. If not, be sure that the remote control is not working, and should be replaced or repaired. Replace the cells first, and check. If this does not helps you and still the remote control is not working, replace it.
If the remote control works, and the all the other functions of your device can be set with it, the motor of the volume control or it control circuitary has damaged. To check this, you must have through knoledge in electronics and is a time taking service work. OK.
Apr 24, 2011 | Sherwood RD-6500 Receiver
IR Remote Control Remote Control: Volume control doesn't work on my remote...
Guest
I have provided a link with instructions on how to program your remote to your TV. I have also provided a link with the remote code. I hope this helps.
Program remote to TV, setup 6:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
May 17, 2010 | DISH Network IR Remote Control
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
Jul 12, 2009 | Universal Remote Control Hampton Bay...
Remote Control wont Work
I cant seem to program my RCA universal remote to my emerson tv
May 28, 2008 | RCA Universal Remote Control
Remote is no longer working
i need a universal remote that can work for a jwin dvd player
Feb 03, 2008 | Jwin JD-VD502 DVD Player
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Electro Med Services...
