Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
My wireless keyboard stopped working i have replaced batteries ,checked usb port ,device is recognised by pc,driver ok but wireless device not connecting witth keyboard
  • angela olsen Oct 15, 2010
    have you tried switching channels or cleaning the contacts to your connections.
    President:
  • 1,015 Answers
The keyboard may have lost connection with the wireless receiver. Take a look at the back of the keyboard. There should be a small recessed button located on the back. The button might be red and say "connect". Once you have found that button you will then need to press the connect button on the wireless receiver. After you press the connect button on the receiver it will be looking for the keyboard to transmit it's frequency. Now press the connect button on the back of the keyboard while you are close to the receiver. When you press the button on the back of the keyboard watch for any light activity on the receiver. You should see some when the keyboard connects to the receiver. After this the keyboard should be connected to the receiver and working properly. If you have a wireless mouse and it is also not working you can repeat the same process with it. It will also have a small recessed connect button on it.
If it does not connect you will want to verify that there is nothing near by that might be interfering with the signal like a wireless phone, baby monitor ect. Sometimes these devices can interfere with the signal.
Let me know if this works or if you have any other questions and thanks for using FixYa.
Posted on Oct 15, 2010
Why the wireless keyboard and wireless mouse don't work on my acer Aspire Z1-621 all in one pc
Strange that BOTH stopped working. Did you check batteries?
Remove USB controller for mouse and test keyboard alone,
Then replace mouse and remove keyboard USB You should use another keyboard (USB or PS2) because your computer won't start up without a keyboard.
If both fail, test them on some othrer computer, ask a friend. Might take sust seconsds to do it.
If test on other computer shows ok, you may have some problem in USB ports.
If actually neither of them work anywhare, so no way but still interesting question, how both of them went bad at same time?
Actually I 've heard many complaints of these wirelss keyboards and Mouse. Probably there are some very bad quality around.
I had a wireless mouse and worked only for about 3 months.
Apr 29, 2015 | Acer Computers & Internet
My Genius Traveler 6000x wireless mouse suddenly stopped working
Double check the batteries, although the lights work and the computer sees it, the voltage could drop low enough to stop the sensors.
next, try another USB device in that plug. USB port can go bad.
If the port works, it could be the wireless USB connector starting to fail, if they are bumped to hard sideways it can cause loose connections internally.
then, you might just need to update drivers. Computer update s can conflict with drivers cause devices toss top working.
May 20, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
Compaq keyboard 5107
XP has built-in support for USB devices.
Try a different USB port on the same computer.
Try the keyboard in a different computer, to prove that the keyboard is OK.
Jan 23, 2014 | Televison & Video
My mouse wont get recognized
Have you tried to use the mouse in another computer to determine that the mouse if fully working. There are many reasons why it could be non-recognised. Has it ever worked on your system? Is it new and just a faulty mouse. It may be you could just take it back to the shop for a replacement one. Do other devices work in the same USB port. Some times my computer just stops recognising my USB keyboard yet it has been working for months. I found that it seems to be the USB port where the problem is. So not I just switch my mouse and Keyboard usb connectors around and it starts to recognise both again. I can not figure out why it stops. As another device is recognised suggesting the port is not faulty.
Nov 01, 2013 | Computers & Internet
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
Hp wireless mouse not getting detected by dell inspiron 1545
First, boot to system BIOS. Check BIOS to see if USB is enabled and might as well enable legacy USB devices as well. To enter BIOS, press enter in most cases. If BIOS checks ok and USB is enabled, your problem is one of two things:
a) You do not have the proper driver for the USB infrared device (download proper driver)
b) The device is not plugged all the way in the USB port or batteries are low, incorrectly installed or have no batteries.
Jan 23, 2010 | HP Wireless Optical Mouse
Wireless keyboard and mouse not working, battery in receiver?
The receiver should not have a battery. It gets its power from the USB port. Try uninstalling both keyboard and mouse via (Control Panel...Device Manager) and reinstalling them. Sometimes the drivers get corrupted and reinstalling them will fix that. Also there are on/off switches on the mouse and maybe the keyboard. Check that someone hasn't turned them off to save batteries when not in use.
Sep 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
LG GSA E 40 L External dvd writer not recognised
you may be having conflicts with usb devices. try temporarily removing all unnecessary devices from the usb ports. unplug and then plug the drive back in. you could try another port. if all ports are in use, then unplug another device, like the mouse and plug in to that port, then plug the mouse into the writers port. i had a similar problem with a wireless usb lan that stopped another device from being recognised. when i removed the lan and replugged the unrecognised device, windows recognised it. i obviously had to use the wireless lan, so i swapped that with the mouse and it worked.
Jul 19, 2009 | LG GSA-E40L Burner
USB wireless keyboard doesn't work
You need to unload the USB drivers for the keyboard and let windows find them again at restart. How does a novice do this? It's not hard. Go to Start, Control Panel, System, Hardware, Device Manager, Keyboards. Right click on this and select uninstall. Reboot your machine. If the drivers are not corrupted they should load fine, if they are corrupted then Windows will ask for the original operating system disk.
All this assumes that your keyboards are electronically working. This last holiday season alot of people brought in their Logitech - Target specials that no longer worked. Seems that if you insert the batteries backwards once the keyboard no longer operates (mouse OK). Never checked in to it too deep.
Good Luck
Mar 19, 2009 | Acer Aspire 5100 Notebook
Keyboard not working
Just buy a USB keyboard, that should work fine, it seems your PS2 port is faulty or its disabled in BIOS check there.
Nov 25, 2008 | Computers & Internet
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
388 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
