Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
My vegetables keep freezing in the crisper. I have had this refrigerator less than 2 years. I have adjusted the vent on the side, I have raised the refrigerator temp above the suggested temp.
  • 618 Answers
Check the temperature in the freezer if too low (0 deg f -18 deg c is normal) turn warmer.
Posted on Oct 15, 2010
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Kenmore Side by Side Refrigerator Model 363.9554780. Vegetables keep freezing in refrigerator both in crisper baskets and on shelves. Raised cool setting to warmer but still freezing. Other...
your control with the letters turn it to colder for freezer that will shut off some cold air from freezer. try different letters until u can twit it to stop freezing. ok
Feb 12, 2011 | Refrigerators
Crisper drawers are feezing vegetables.
look down at the bottom crisper and there should be an air control that lets more or less air in from the freezer section. close this control down so that most of the air stays in the freezer. some models may say meats(colder) and vegetables(warmer).
some models the control in the down position opens up the vent more allowing it to get colder and in the up position closes the vent down more allowing less cold air into the refrigerator. you can remove the crisper and experiment with the control.
Jul 14, 2010 | GE Profile¿ Arctica® Energy...
Vegetable drawer freezes items
Adjust your thermostat / temperature setting to a warmer temperature.
You could also have a lot of food placed in front of the vent in the top of the refrigerator compartment. Tall jugs (like milk jugs) are usual culprits of this one. Cold air is deflected in other direction, it might be going straight to the crisper rather than diffusing first.
Jan 04, 2010 | Jenn-Air JCD2389G Side by Side...
Vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 17, 2009 | Refrigerators
Vegetable section too cold, freezing the vegetables
if youd like you can remove the affected crisper, locate the "adjustment slidelever" and remove it, behind there youll find a hole(which is what youve been restricting to lessen the cold air flow.) try wadding up a ball of perma-gum, window sealer, some sorta plug forthe hole, its not nessecary for function of refrig, only to make the crispers colder, but usually too cold. blocking of fthe hole willl make the crispers only as cold as rest of refrig
Mar 23, 2009 | KitchenAid KSCS25FKSS Side by Side...
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
Water despenser is apparently frozen
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Aug 14, 2008 | Amana AFD2535DES French Door Refrigerator
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
314 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
