Question about Tippmann 98 Custom Act Paintball Gun
I ahve owned my gun for many years and never had a problem but now when i pull the trigger the gun will go full auto and empty the hopper in less than ten seconds i have replaced the rear sear spring the rear sear looks fine and all the o-rings have been replaced recently the bolt recocks far enough back to load a paintball everytime and there appears to be nothing in the slides for wither rear or front bolt what do i need to do to fix it back to shooting semi auto??
    Novelist:
    Scholar:
  • 111 Answers
The sear and pin can certainly "look" fine but still be a fraction off and let the marker loose. Also, you may notice that the pin on the sear is different than the others? Perhaps silver where the others are black?
My best advice at this point would be to check with a buddy who's willing to let you exchange the sear and pin and see if that's the problem, or check with a local airsmith who can try this for you and check for any other problems as well.
Play hard, play safe, play with honor!
8^)
Posted on Jan 04, 2011
Gun is full of nails, but acts like it is empty (the plunger won't advance). You go to tap it with the trigger pulled, and it just does nothing. Seems like firing pin is not getting air or somet
If no air is leaking from the gun, take out the nails, remove trigger by removing 3mm hex head bolt to expose the trigger pin. With air connected and side door open so that you can see the feeder, quickly depress the trigger pin with finger. Gun should fire. If gun does not fire (only makes air sound at trigger) dissconnect airline, remove head and lube headvalve with white grease and reinstall. Test again. If ok replace trigger. If still no joy, replace trigger valve with new factory or generic (part # TVA6). If gun fires but does not activate the feeder claw, remove two 6mm hex bolts from front of gun and split apart upper and lower body and check white oring (part # 149885) Good luck
Oct 16, 2012 | Stanley Bostitch Rn461 Gun Coil Roofing...
Mossberg 88. after closing the bolt, sometimes the gun will not fire.. It makes a dull thud.. the gun is old but only got it out of the box this year and has about 250 rounds shot thru it.. It seems if...
Weak main spring. It's the back-most pin in the trigger group. The spring isn't moving fast enough to get the hammer past the half **** notch on the hammer. It's catching the sear. In a pinch, you can just jerk the trigger extra stout, no hesitation. If you have a decent stone, you can stone off the half **** notch on the hammer. The half **** is when you pull the trigger group out of the gun and hold the hammer lightly as you pull the trigger. The spot where the hammer locks straight up and down is the half **** notch. Current hammers don't have the half ****....it's simply not necessary. It was a redundant safety feature if the gun ever fell hard when cocked and chambered. It causes more probs than it fixes, though. You can replace your hammer with a new part....all of them fit including the Mossberg 500 lines....or you can stone the notch yourself....or you can replace the main spring. All will fix your prob.
Great gun, btw! I have one and love it!
Jun 05, 2017 | Mossberg Sport & Outdoor - Others
I have a Max cn70 nail gun. When trying to fire the gun, air seeps from the trigger assembly and will not fire. Help!
Hello, sounds like a nail is jammed in the chamber. Happens frequently. What you do first is disconnect the gun and empty any nails. Then, with a screwdriver or a big nail hit the ram driver back down . Reconnect and test by depressing safety latch and pulling trigger. Repeat. Hope this helps. -ROB
Feb 10, 2011 | Air Tools & Compressors
Nail gun shoots 2-3 nails, not one. last week 2 of them hit me in the thumb. has been doing this for years. I have put up with it because I did not know what to do about it.
Most nailers work better by bump firing the gun. Less likely to double fire. This is a common problem amoung brands. If you place nailer on work then trigger, you may/will have problems as you describe. There is usually an option of triggers or builtin method of single firing the gun. With single fire trigger, you can place gun on work and fire. The will not reset for next round untill you let go of trigger and lift gun off the work. If your gun is double firing even with bump method, then replace the trigger valve.
Nov 16, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Tdwbit269@aol.commy gun will not shut off even when i pull the trigger, liquid keeps flowing out. good thing is that i am getting something through the hose so that means my machine is working right?
You need a re-build kit for your gun.
The needle that pulls back when you squeeze the trigger is no longer making a seal when you release the trigger.
The problem is worse when you spray thin oil-based paints.
Depending on the gun, Sherwin Williams has kits for the Graco gun. That's where we bought ours for years up until I retired from painting.
Home Depot and Lowes may have parts.
Oct 28, 2010 | GRACO INC 243012 Airless Spray Gun Sg3
I have an a5 paintball gun with electronic trigger, when i hook it to air and pull the trigger, the hopper is not moving!!!
On the A5 the hopper or Cyclone feed is powered thru a small tube on the feeder side
of the gun. Make sure that tube is connected and if so, pull it off and see if air is flowing
thru it when you pull the trigger. If not, the internal passage may be blocked. Tear down
the gun and clean out the obstruction. If there is a pulse of air coming out the tube when firing
then it may be the Cyclone feed mechanism. Just unscrew the 3 phillips head bolts
under the Cyclone and observe the air driven gear drive. Air up the marker and see
what is moving or not moving. Complete replacement upgrade Cyclone gear drives
are available that say they increase performance if you cant get it moving.
Here is your manual
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Sep 25, 2010 | Tippmann A 5 Standard Paintball Gun
Dewalt angled finish nailer, just got, when nose is depressed and trigger pulled, just sound of air releasing, wont fire..... need trigger assembly?
if air is released when the trigger is pulled then stops when the trigger is released , then the trigger is doing its job. its probably a firing valve issue. four screws will take off the top cap of the gun the firing valve is inside of the cap . first check to see if the gun has enough oil( unless its an oil less gun) if its dry then grease or oil all of the orings, if this dose not work check to see if any of the orings or plastic parts need replacing. pls rate this answer...;tks
Feb 14, 2010 | Dewalt Air Tools & Compressors
Trigger pull is not as far as older model
some models have less trigger movement than others.
at the back of the gun you have two adjusting knobs the lower one controls the trigger movement, which controls the fluid flow from the nozzle.
Oct 06, 2009 | DeVilbiss PLUS? Pressure Feed Spray Gun #...
I cannot figure out how to use my cleaner floor mate
At the risk of giving a simplistic answer, let me go through the steps I go through every time I use mine:
1) Plug it into the wall
2) Take out the upper "hopper" and fill it up to the fill line with hot water
3) Put in the capful of cleaning solution (about 2 oz.)
4) Gently swish it back and forth, then put back into upper unit until it clicks into place
5) For best results, set the vacuum on Dry and vacuum the house first, then clean the lower "hopper"
6) Set the vacuum to Wet, put the scrub brushes on, depress the trigger and do overlapping strokes, a section at a time I depress the trigger on the push stroke, then release it for the pull stroke. I clean a section, then turn off the scrub brushes and go over it again without the scrub brush or touching the trigger (trying to pick up as much water as possible).
On average, when refilling the water/cleaner solution for the top hopper, empty and clean the lower hopper. When the floors are finished, completely clean that lower hopper or it will smell!
Hope this helps...
Jul 18, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Tippmann 98 Custom Act Paintball Gun Logo
119 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Tom Chichester
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
