Question about Dryers
Kenmore 600 series dryer, does not get hot - Dryers
  • Anonymous Mar 28, 2009
    i have no heat but dryer runs fine, 600 seris, electric
  • aftomei May 17, 2009
    where is the igniter located?  how do I change it.  I took off the back pannel and the front pannel but do not see the igniter or thermal fuse
  • 868 Answers
Check (if it is gas)power atthe igniter....If there is and it doesnt glow when you start dryer ...Replace the Igniter.....2nd. ..If you
have no power at the igniterkenmore 600 series dryer, does - 0526080941.jpg7758769.jpg ....replace the Thermal fuse (see picture above)
Posted on Jun 02, 2008
My kenmore 600 dryer auto moisture sensing not working. Is this is easy fix? If so where is the sensor?
That sensor will be somewhere along the exit duct work, Open up the back of the machine to find it, first clean out the duct work and the sensor might just be plugged with lint.
Dec 21, 2014 | Kenmore 600 6962 Dryer
Kenmore 600 series electric dryer runs but wont heat
There are several things that could cause this problem but the most common can be can be checked by following this guide:
Electric Dryer Runs But Dont Heat
Jan 11, 2014 | Kenmore 600 7962 Dryer
I have a kenmore 600 series tl washer. it will only fill with water very slow
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 09, 2011 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 600 Series Dryer heating element comes on, but will not shut off. What should we do?
With your dryer not running, touch the to surface. If it is to hot to tough then, iIt is your elements. I know this sounds weird, but one of your elements is touching the grounding housing and making a connection. This is not safe to use. I recommend to unplug it or through the breaker to it, until you get it fix.
May 18, 2011 | Kenmore Dryers
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
Kenmore 600 series gas dryer not warm
Make sure the vent is clear and air movement is good through the rear vent.
Ten,
Check and or replace the flame sensor and the gas valve coils.
Mar 11, 2009 | Kenmore 73952 Gas Dryer
Kenmore 600 series dryer doesn't heat
I have a 600 sieries kenmore gas dryer can i use LP or not.
Aug 08, 2008 | Dryers
Dryers Logo
802 people viewed this question
Top Dryers Experts
