Question about LG 32LG30 32 in. LCD HDTV
How to use external speakers - LG 32LG30 32 in. LCD HDTV
  • 998 Answers
Try to look for audio out in the back of your tv then connect your amp there.
Posted on Oct 15, 2010
How do I connect conventional speakers to Alexa?
  1. Set your Echo Dot and external speaker at least three feet apart. When Echo Dot is close to external speakers, it may be more difficult for Alexa to hear the wake word and other requests.
  2. Turn your external speaker on.
  3. Plug one end of an audio cable into your speaker and the other end into Echo Dot. All audio from Echo Dot now streams through your external speaker.
May 21, 2017 | Computers & Internet
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
Speakers are mounted on the side of tv (mitsubishi CS 40503 1995 model) want to remove them and have them in a different location
"Speaker: Internal/External" controls which speaker (built-in or external) is available. Set to "Internal" for normal operation of the internal speaker system. When connected to external speakers or an external audio system, the speakers can be turned off by setting this function to "External."
From reading this I see that the speakers may be internal because the setup allows to switch between external or internal. A mounted speaker is either permanent, part of the case, or has something that the speaker case slips into. I had one like that. You simply lift them and set them else where. How far they can be moved will depend on the wire. The wire is either attached internal through the back or attached via connectors on the back. That can either be loose wire or RCA plugs. Normally the wire coming from the speakers is attached internal, making the removal of them impossible. The wire is usually 3 to 6 feet long. You can buy an external speaker wire that has RCA plugs (and or plain wire) that will attach to the existing speaker wire and TV.
Good luck and post back
Jun 04, 2011 | Televison & Video
Can't turn off internal speakers when i have external speakers connected via headphone socket
First, check if you put the connector for external speakers all the way to the end. Sometimes when the connector isn't fully inside both internal and external speakers will work. After you do that, once you connect the external speakers, go to the sound settings in windows and look for the volume mixer. You can regulate the sound for each type of speaker there.
May 04, 2011 | Computers & Internet
Output from my thinkpad x40 is balanced (left-right) through the built-in speakers, but only the left channel can be heard when external speakers are plugged in.
As you said your internal speakers are OK, then may be the problem with the external speaker. Check with another set of external speaker. if works fine then check your previous external speakers connection. if still no sound the neeed to check the motherboard.
Aug 21, 2010 | IBM ThinkPad X40 Notebook
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
Plug in external speakers w/ volume very low in HP2009m screen
check if the external speakers u plugged in came with an internal amplifier, if not then u will have to use an external amplifier to get max output from your external speakers.
Sep 02, 2009 | Audio Players & Recorders
I want to hook up an external speaker to the radio
you need to wire up the speaker to the orange and black wire. orange is speaker positive and black is speaker ground the other wires are as follows thick black= dc ground orange= external speaker positive black= external speaker ground green=gps data in brown= gps ground yellow= nc
Apr 08, 2009 | Uniden Solara Vhf Dsc Fixed Mount Radio
External speakers for acer laptop 5220 series
Hi there
On acer laptop you have already speakers. but you want to connect external speakers then please find
that three conector in your laptop and connect you external speakers on one of them. please try each connector and you are able to connect external speaker.
Thanks
Robert
Sep 24, 2008 | Computers & Internet
Computer speakers work but external speakers do not
Schuttie
hello there!
First Things First:
1) Check if your external Speakers are connected on the external sound card output connector **
2) Check on control panel and multimedia if your sound card (external) is enable, and not MUTED sound. Rise the volume.
3) check cables from Speakers and see if not old or broke.
Good Luck
Feb 09, 2008 | Audio Players & Recorders
LG 32LG30 32 in. LCD HDTV Logo
137 people viewed this question
Computer Repairing
Computer Repairing
