I can hear a loud humming when turned on but none of the keys make any sound
    Genius:
  • 1,325 Answers
What is the model and manufacturer ?
Posted on Oct 15, 2010
2 Suggested Answers
  • 357 Answers
SOURCE: one of the speakers when
we need to do a little bit of fault finding here to narrow down where it's coming from or what is at fault.
First try physically swopping the speakers over and reconnecting (do not just switch the cables at the back of the amp). Is the sound still coming from the same side or has it swopped over? If it's swopped over, it's a speaker issue and needs replacing.
Ok, if the strange sound is still happening from the same side, have a look along the speakers cable path. Is the cable running along side any power cables or extension leads or is it near any wall warts or mains transformers (the type you get with mobile phones, keyboards, answer machines,etc). If so, move the speaker cable a considerable distance away from these. Now, has it stopped or the noise reduced?
If we are still not getting anywhere, see if you can try your speakers on a friend's system and/or try someone else's speakers you know to work on yours.
If his/her speakers are noisy on yours, firstly you have to consider that most sytems at very high volume will produce some noise, but if it's actually quite a loud audible noise that's relatively new to the system, you need to get the amplifer serviced.
Hope this helps
Good luck
Posted on Jan 07, 2011
Humming noise when i turn the key on in the morning
power steering pump make humming noise and alternator with bad shaft bearing make noise.
Feb 12, 2013 | 2005 Toyota Sequoia SR5
Humming sound undercar
Does this happen at all while turning the car? It could be a hub bearing. Just replaced mine and it was a humming sound. It would be pretty loud around 15 to 40 mph but got quieter after that.
Aug 25, 2012 | 2003 Pontiac Bonneville
Loud hum intermittent throughout the day and night
The hum that you hear is due to the compressor vibrating and cause by a nut not so tight. Check it's back- a bumping motion into metal case will also cause that hum. If none of it cause the humming, it is the compressor itself causing it. But there nothing you can do because it is sealed.
Thanks for asking.
Jun 25, 2011 | Electrolux EI26SS55GS Stainless Steel ...
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
Should i be able to hear the fuel pump when I turn the key
yes and no it shouldnt be to loud but you should be able to hear a hum from it
Dec 02, 2010 | 2001 Daewoo Lanos
I have a Schumacker Model SS-51A-PE charger and was charging a boat battery when I heard a medium-to-loud pop. I checked the charger and realized there was no output. It hums quite loudly when plugged in...
Quite simply - the unit has suffered component failure - most likely more than one. Capacitors are the usual source of noisy 'bang' or 'pop' sounds, followed by diodes and bridge rectifiers. If you have some knowledge of electronics, you can attempt repair, but, if none, I suggest leaving possible repairs to someone who does.
The humming sound you hear is the transformer under stress, and, if left connected, it too will die.
Sep 21, 2010 | Schumacher 10 Amp Fully Automatic/Manual...
Have an older Lowrey organ with loud hum.
Of course it is repairable.
Find a competent repair person. You did not describe the "noise". If it is 60 cycle hum, the filter caps need replacing. If it is an organ tone, then probably a key contact is stuck.
May 05, 2010 | Music
Whenever i turn the key to on position and after cranking engine i hear about a 3-8 sec. humming or small motor sound
That's your fuel pump bringing the system up to pressure. Perfectly normal unless it is exceptional loud in which case it could be a sign that the pump may need replacing soon.
Nov 13, 2009 | 2002 GMC Yukon Denali
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Pioneer Receiver SX-750: Getting a loud hum through the speakers
The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
May 17, 2009 | Pioneer Audio Players & Recorders
12 people viewed this question
 Grubhead
Grubhead
