Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
When i try to start my dryer it clicks to turn on but doesnt fire the drum
  • 618 Answers
Reach in and turn the drum by hand if you can do so with very little resistance then the belt may be broken or off the motor.
Posted on Oct 15, 2010
Model DPSB620GC1WW, SET SETTINGS, PUSH START AND DOES NOTHING BUT CLICK
Reach inside and move the "drum" by hand. then close the door and try again. I have seen the exhaust fan so full of lint that the motor can't turn. If you are not comfortable taking the back off then you will need to hire it done
May 17, 2015 | GE Gas Dryer Model Dpsb620gc1ww
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
When Itry to start my dry, it won't come on and I hear a noise(like an electrical relay when it stuck on)
the dryer drum belt is broken and there's a belt switch that shuts off the unit to prevent a fire from the drum not turning and the clothes overheating,the buzz is the motor start switch trying to start the dryer
Mar 08, 2011 | Frigidaire AEQ6700FS Dryer
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
I have a kenmore 80 series dryer and when i try to start it it makes a loud noise but doesnt start i have replaced the switch and still have the same problem
have you checked the drive belt that turns the dryer drum it may be broken and need replacing can you hear the motor..does it sound like it is working if it is and drum not turning this is probably your problem
Dec 15, 2009 | Kenmore Dryers
Husband just changed belt on dryer, and drum still doesnt turn
While you have the drum out check the motor to see if it runs. It could be you have a faulty motor.
If the motor is running then you may have a faulty timer or start switch
Good luck,
I hope this helps
Oct 28, 2009 | Maytag Dryers
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Kenmore dryer electric doesnt start
It sounds like the dryer drum belt is broken
there is a drive belt that goes all the way around the dryer drum and when you press start the drum starts turning unless teh belt is off or broken
You can change the belt or call and have service technician change it
Jan 04, 2009 | Maytag HYE3657A Electric Dryer
There is a clicking sound when you press start.
If you heat a click when you push the button,but the drum doesnt turn your belt is broken. About $15 and simple to install.
Oct 20, 2008 | Kenmore 63942 Dryer
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
160 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
