Question about Panasonic TH-42PZ700U 42 in. Plasma Television
Led light flashes 7 times??? - Panasonic TH-42PZ700U 42 in. Plasma Television
  • Panasonic Master
  • 8,457 Answers
The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Oct 15, 2010
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Where and what does the reset switch for the 1996Volvo 850 lookslike
Volvo 850 (1993-1995) Service Light Reset
Under the hood there are 2 diagnostic units (labeled A and B on the cover) next to the washer reservoir.
1. Turn on the ignition and open diagnostic unit A.
2. Locate the flylead (the test wire that is in the plastic holder).
3. Insert the flylead into socket 7.
4. Press the large round test button on the diagnostic unit 4 times, briefly but firmly.
5. When the LED flashes and then stays lit, it will accept the reset code.
6. The reset code for the service light is 1-5-1.
7. Press the large round test button firmly one time and then release it. The LED should be lit.
8. Press the button firmly 5 times and then release it. The LED should be lit.
9. Press the button firmly one more time and then release it. The LED will flash several times.
10. Turn off the ignition switch and replace the flylead in its holder and close the cover.
The Service Light has now been reset.
May 13, 2015 | 1996 Volvo 850
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
Oct 20, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
No picture
you have the ATC311 chassis. do this proceedure and you can track down where the problem is. let me know if you need more assistance. i can also post a link where you can get the training manual at a cheap cost emailed to you if you would like a copy.
5. Apply AC power and press power button.
6. If LED turns on and then off, disconnect J11501 (Audio CBA) and press power
button again. If power LED comes on and stays on suspect Audio CBA. If LED
still flashes or does not light go to step 7.
7. Disconnect J26903 (AV IN CBA) and press power button again. If power LED
comes on and stays on suspect AV IN CBA. If LED still flashes or does not
light go to next step.
8. Disconnect J19500 (Convergence CBA) and press power button again. If
power LED comes on and stays on troubleshoot the Convergence CBA. If
LED still flashes or does not light go to next step.
9. Disconnect J14801 (Deflection CBA) and press power button again. If power
LED comes on and stays on suspect Deflection CBA. If LED still flashes or
does not light suspect DM2 module.
Jun 08, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Panasonic TH-42PZ700U 42 in. Plasma Television Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
