Question about Whirlpool LGR3624JQ Gas Dryer
I have an older whirlpool gas dryer model LGR7646EQ3 and everything works but it won't get hot. Is it most likely the igniter?
aborcass
  • 2651 Answers
SOURCE: Whirlpool gas Dryer LGR5636JQ1
theres a thermal fuse located on back panel usually white maybe 2 inches tall 1/2 wide 2 blue wires leading to it. ck for continuity, if none replace that(most common problem)... if good you can go back to the ignitor and unplug the white connector it plugs into. place your meter leads into the connector and turn on dryer, you should get 110v. if you do you have a bad ignitor, if not a thermo's gone bad (check the thermal fuse first though.
Posted on Mar 12, 2008
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
  • 1028 Answers
SOURCE: whirlpool gas dryer model # lgr7646eq3
put back back on with top off remove screws in top corners of front panel remove bottom panel and screws holding blower/lint screen housing on remove door springs remove screws on bottom corners of front belt is probably lying in bottom
Posted on Sep 03, 2008
SOURCE: Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Posted on Nov 02, 2008
gary1121
  • 332 Answers
SOURCE: Whirlpool nay gas dryer will not ignite flame Model #GGW9200LWO
is it new with a piliot or electric ignitor, if is is piliot you could need a thermocoupling, if it is an electric ignitor you will need to change the ignitor, both are eazy on a dryer you have alot of room to do this, if it is an ignitor do not touch the carbon but take it out and take it to an appliance store that as parts, you must have it with you so that the hold down braket is the same and the plug is the same, if it is a thermocoupling it is just a screw that holds it in place and you can pull it out of the holder you don't have to be so gental, but it must be pushed all the way in the holder till it clicks
Posted on May 30, 2009
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Whirlpool Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Whirlpool supreme gas dryer will not heat up. model# LGR7646EQ3
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Whirlpool LGR7646E Dryer
I have a whirlpool dryer M460-G (SN#MH4612126 ? LGR7646EQ3). The dryer does not heat up. I checked the back and cleaned all the lint. The gas ignites and heats some time but not all the time and when it is...
Replace your gas valve coils!! They will allow the dryer to heat initially, but fail after about the 3rd or 4th iginition sequence.
Part number 279834 and are around $20.
They are located on top of the valve and held on by a steel bracket with two phillips head screws. Plug and play wires you cant mess up.
Fix it up!!
Aug 14, 2010 | Roper REX4634KQ Electric Dryer
I have a Whirlpool dryer Model: lgr7646eq3 serial #:mh4104127 The unit does not generate any heat when under operation. It is a gas dryer and there doesn't appear to be a pilot light. Any recommendations?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 12, 2010 | Dryers
Igniter won't glow
I am assuming that everything works OK except you have no heat?
When you turn on dryer listen for gas valve to click(this may take a few seconds).If you don't have a click then the gas valve my be bad or it is not getting power.
Dryer has to be running to check for power only experienced persons should perform machine running power tests.
Let me know If I can do anything else to help.
Mar 20, 2010 | Whirlpool LGR5636L Gas Dryer
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Gas Dryer Problem
Nov 02, 2008 | Whirlpool Dryers
Whirlpool gas dryer model # lgr7646eq3
Sep 03, 2008 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool LGR3624JQ Gas Dryer Logo
77 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
