Question about Norcent Technologies Televison & Video
My volume keeps going down until it is completely muted and u cant turn it back up until after you plug it for hours.
  • 998 Answers
Try to reset the setting of your tv.
Posted on Oct 15, 2010
How to mute the beep on a Hamilton beach microwave. Or is there even a way to completely mute it. If not then is there a way to turn down the beep volume
unplug machine. you will need to remove the cover. careful for the capacitor. usually after not running for an hour or so the capacitor will completely discharge on its own. looking at the back of the control board, you ill see a small round, usually black cylindrical part about 1/2 inch high with a hole in it. cover the hole with a couple small pieces of duct tape. this will mute the daylights out of it. to eliminate sound completely you will need to unsolder this part..
Jun 12, 2017 | Hamilton Beach Microwave Ovens
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
I have a Bose Wave II radio. Never a problem until today. No sound from radio, CD, aux. Display works fine. Remote works. Have tried unplugging and plugging back in. Tried turning volume up, muting and...
in your boss amplifire system hardware problem in u try to mute and volume button please check aux port also if found no output sound then go boss service station there are some hardware problem
May 16, 2012 | Bose Audio Players & Recorders
When i turn the tv on the volume is stuck all the way up and if i mute it it stays muted until you turn it off and back on
Muting is not designed to lower volume it shuts it off completely That;s why it resets when turned on and off.
Unless by muted you mean you can lower the volume to a listenable level but it reverts to full when you restart it.
Try using settings and set the volume and the type of sound(mode) you want then when you exit the menu it sshould save those settings.
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Planar XP15SSA-01 15 in. LCD Television
I have a Teac a-R600 integrated amp. The muting light strarts to flash after about an hour playing and mutes the sound until unit is switched off and re started. Any ideas . Thanks Ian
YOU ARE GOING TOO FAR IN VOLUME CONTROL AND YOUR AMPLIFIER TRY TO PROTECT ITSELF BY MUTING-MAKE YOUR VOLUME LITTLE BIT DOWN.IF THE PROBLEM REPEATED WITH LOWER VOLUME SETTING YOU WILL HAVE INTERNAL PROBLEM.ANYWAY CHECK YOUR CABLES FOR GOOD CONDITION.
Dec 19, 2009 | Audio Players & Recorders
It just stopped talking. No voice directions, on
Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
Aug 01, 2009 | Garmin nuvi 885T GPS Receiver
Pc beeps.
Uninstall the audio driver and install it again.
Otherwise tick the mute box on the sound volume or turn the sound volume right down.
Apr 14, 2009 | Dell Latitude CPX Notebook
How do i change the keypad tone volume or switch it off
on the left side off the phone there should be a slider button press on the arrow that shows down and it should show you a volume meter on the display keep pessing the down button until you cant hear any more sounds from the keypad.
Jan 25, 2009 | Samsung SGH-J750 Cell Phone
Setting the clock
hold down the mute button until the screen says clock adjustment if it doesn't saw the use the volume until it does. the press the ENT button in the upper left hand corner then the hour # should flash use the volume button to adjust then press the ENT button the change the minute and when the corect time is in press mute untill the screen is back to normal
Oct 07, 2007 | Car Audio & Video
Televison & Video Logo
115 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
