Question about Olympus Stylus 7010 Digital Camera
I didn't turn off the camera before taking out the battery. Now it wont turn on after reinserting the component. What can I do? The camera is the stylus 7010
    President:
  • 2,185 Answers
Try to plug it into your computer using the usb cable and turn it on from there. If it doesnt work, fully charge the battery and try inserting it again after an hour.
Posted on Oct 15, 2010
Olympus stylus 300 seem to have a common problem lens wont come out lights just flash battery changed did not cure problem
that is a mechanical issue, with the internal workings. and taking it apart is not a good option. do you have a warranty on this item?
Jun 20, 2008 | Olympus Cameras
I have a coolpix and I spilled orange juice on it. I imediatly cleaned and dried it off but when I would try to turn it on...nothing. It's been a few months I tried to turn it on and it says battery...
First off, are you sure that the battery is charged? It is definitely possible that spilling orange juice on it messed it up, but it might be all right.
Assuming the battery is charged, it is likely that the spill caused some internal damage. When you spilled on it, did you open the battery door, take the battery out, and allow the the camera to air-dry completely before turning it on? If you didn't, it is almost surely fried. If you didn't allow it to air-dry, it is likely that there was residual moisture and liquid on the internal components, and when you powered it on you likely messed them up. This is really a repair that is not worth paying for, as the cost of a new camera would be much cheaper.
May 07, 2011 | Nikon COOLPIX L4 Digital Camera
Wont turn on, battery is charged
Remove the battery off the set for few hours and reinsert to check , if the set had hung up this might solve but if not the camera must be checked from the battery voltage to the circuit within of the system controller.
remove the covers to check only if equipped to probe with tools as you must not end up tampering the camera. Take consensus.
Nov 25, 2010 | Samsung SL620 Digital Camera
Samsung NV3 wont turn on
take out an reinsert the battery...that works always for me.
Dec 18, 2008 | Samsung NV3 Digital Camera
My fuji finepixs 5200 wont let me take photos and when i try it says "FOCUS ERROR"
Karen,
First let's see if the camera will reset. Remove the battery or batteries and leave them out for 5-10 minutes. Then, reinsert batteries. Try taking pictures in various lighting situations. Also, try taking pictures at various focal lengths (distance from subject to camera). Follow-up and let me know how the photos turn out -- and in which situations you receive the FOCUS ERROR. I'll gladly help you further at that time.
Nov 17, 2008 | Fuji Cameras
Total power falure
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Sep 19, 2008 | Fuji FinePix S5000 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Sony cybershot dsc-s90
Hey Gregorious03,
You could try removing the batteries for at least one minute and then reinserting them, or you could try initializing the camera back to the factory settings under the setup menu. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Olympus Stylus 7010 Digital Camera Logo
107 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
