Question about E-Machines T5010 PC Desktop
Corrupt windows file. do not have restore disk. system will not boot up in safe mode or latest good file.
Maybe you can try this. first know the model of your computer then search the internet from another computer on how to recover your system. most probably the installer is in the harddrive if you don't have any recovery disk. else, if you have a bootable usb or disk boot from it then see if there is a folder "I386" in drive "c:/". this is the folder of your windows installer. then select "win.exe" if you boot up on dos or select "win32.exe" if you bootup from winternals (windows of a bootable usb)
Posted on Oct 15, 2010
Windows help support
do you have your boot disks that came with your comp. what version are you running
Aug 20, 2014 | Microsoft Windows 7 Home Premium 64BIT...
\windows\system32\kdcom.dll Missing or corrupt Kernel debugger
Try tapping F8 at bootup to enter safe mode, read your manual to see if you have a recovery partition on your HDD. You didn't post the model so I have no clue.
If you can enter safe mode you need to try system restore, not last good know configuration.
If you see last know config on your screen, then you should also see safe mode.
So you need to run in safe mode, and run system restore, or run the recovery mode if you have a recovery partition on the HDD.
If none of these work, then you only have three options, go to Avira.com, download the rescue disk, burn it to a CD and run it in DOS, this is before windows boots. Now if malware corrupted the DLL, Avira will kill it, but there is a chance it can't clean it and will destroy the files,DLL, and windows won't boot. So now you have to do below.
The other option is you need to download windows, what ever version you have, if you have win 7 home 32bit, then you have to download it, and burn it to a DVD. Then try a repair, if a repair does not work then you need to reinstall windows, and then install all the drivers like, (chipset, video, sound, lan, wifi)
This option, you can contact Acer and see if they have a recovery disk for you.
Good luck.
Apr 01, 2013 | Computers & Internet
How to solve disk error while booting xp, restarts automatically
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
Note : If you are not able to log in to Safe Mode and the PC still restarts from entry mode of Safe Mode this means the Operating System Files are corrupted and the system should be reformatted with fresh Operating System.
Good Luck
Sep 05, 2011 | Computers & Internet
When i start my pc, it starts well but a page appers telling me to start windows normally. when i click on that then windows starts loading bt after 2 sec the systems gets restarted.
1.You have to do a diagnostics test on your hard drive to check if the there are any bad sectors developed on the hard drive!
2. If your system restart, when you just click your mouse, your system files are probably corrupted and your may have to reinstall the system ie. provided your hard drive has no errors.
Here is an option you can try.
Can you boot your system to "safemode"? & Use the "Dos Prompt" to do a "Check Disk" on your System. ie Run -> "CHKDSK /f/r" (without quotes)
Hope it helps.
Apr 17, 2011 | Computers & Internet
Will not re-boot
Hello #1: Use a Windows startup diskOne of the first things you should reach for when troubleshooting a Windows XP boot problem is a Windows startup disk. This floppy disk can come in handy if the problem is being caused when either the startup record for the active partition or the files that the operating system uses to start Windows have become corrupted.
To create a Windows startup disk, insert a floppy disk into the drive of a similarly configured, working Windows XP system, launch My Computer, right-click the floppy disk icon, and select the Format command from the context menu. When you see the Format dialog box, leave all the default settings as they are and click the Start button. Once the format operation is complete, close the Format dialog box to return to My Computer, double-click the drive C icon to access the root directory, and copy the following three files to the floppy disk:
  • Boot.ini
  • NTLDR
  • Ntdetect.com
After you create the Windows startup disk, insert it into the floppy drive on the afflicted system and press [Ctrl][Alt][Delete] to reboot the computer. When you boot from the Windows startup disk, the computer will bypass the active partition and boot files on the hard disk and attempt to start Windows XP normally.
#2: Use Last Known Good ConfigurationYou can also try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
#3: Use System RestoreAnother tool that might be helpful when Windows XP won't boot is System Restore. System Restore runs in the background as a service and continually monitors system-critical components for changes. When it detects an impending change, System Restore immediately makes backup copies, called restore points, of these critical components before the change occurs. In addition, System Restore is configured by default to create restore points every 24 hours.
To use System Restore, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Start button, access the All Programs | Accessories | System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
#4: Use Recovery ConsoleWhen a Windows XP boot problem is severe, you'll need to use a more drastic approach. The Windows XP CD is bootable and will provide you with access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROM drive on the problem system and press [Ctrl][Alt][Delete] to reboot the computer. Once the system begins booting from the CD, simply follow the prompts that will allow the loading of the basic files needed to run Setup. When you see the Welcome To Setup screen, shown inFigure A, press R to start the Recovery Console.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 30, 2010 | HP Pavilion dv1000 Notebook
Windows freezes up before boot is complete
If you have your computer Recovery disk, place the disk in the drive and restart the computer. It sounds like your OS is corrupted and needs to be reloaded.
Apr 05, 2010 | EliteGroup P6IWP-Fe Motherboard
Error says file: systemroot\system32\config\system
Can you boot into Safe Mode? Restart the computer and hit the F8 key continually until you get to the Advanced Boot options and choose Safe Mode. Here you can run System Restore. If you can't, then boot off of the Windows XP CD and get to the Recovery Console. Here you would type in chkdsk /f/r and hit enter. The Check Disk utility will try and fix any errors in the file system.
Mar 19, 2010 | Computers & Internet
How do I know if the HD is damaged? I suspected HD failure due to the following? computer won't start. It says, "invalid Boot.INF file." And then, it say "press Ctrl+Alt+Del to restart". What could it be?...
It is probably BOOT.INI. However, might be anything from a virus to manual mistake, altho this file should be hidden.
HDD Regenerator: http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Regenerator.shtml free trial will help you check the HDD.
Nov 12, 2009 | HP Pavilion 533c (P9939AR#ABA) PC Desktop
Windows error code, my computer starts up gets to windows sign in screen you sign in and it turns back off. when I press the F5 key and try to boot from hard disk cd-rom or the other option it wont let me...
Please tap F8 continuously as the machine first boots up
Choose safe mode from the menu
Then click on start and all programs
Click on accessories and then system tools
Click on system restore and choose an earlier time
Choose a date before this started
Sep 07, 2009 | Computers & Internet
E-Machines T5010 PC Desktop Logo
66 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
