Question about Hitachi P50H401 50 in. Plasma HDTV
Spilled about 1/2 cup of water over rear slots of my TV. Am drying it with a fan. Is that safe, and will it work?
  • 998 Answers
Just let it dry for one week to be sure before you plug it again
Posted on Oct 15, 2010
I have a flat tv on wall but my 4 old wet it with duck on the bottom of tv. Now shows it have lines on side. If let dry with a fan will it work normally help any tip
MOST, electronics should work properly after being wet.. as long as:
1.it was not / does not get turned on well it is wet.
2.it is only water that was spilled on it (NO- soda, milk, juice)
your best bet is to let it fully dry for a week or so, not in direct sunlight, and make sure there is no power running to it.
May 17, 2015 | Televison & Video
Tip
Spilled liquid on Keyboard!
1. Purchase plastic keyboard cover. 2. Keep coffee etc. anywhere not near keyboard.
For spill, unplug keyboard. If non sugar liquid, invert keyboard, shake or tap gently. Wipe with lent free absorbent cloth while still inverted. If soda or coffee with sugar, pour 1/4 cup of clear clean (distilled the best) water onto keyboard (yes), Then invert. Let dry a minimum of several hours still inverted. I cheat with a hairdryer on low 6-12 inches. After keyboard is completely dry (and cool). Plug in after turning computer off, restart, test all keys, including shift, option etc. If keys miss or don't work buy new keyboard and cover! Aloha, Cliff
on Sep 27, 2014 | Apple 24" iMac Desktop
I need insturctions on using the avon rice cooker for microwave
1. Before cooking, optionally rinse or soak the rice. This is necessary for some types of rice (especially brown rice, which is much harder than white rice), but it improves the flavor and texture of most types. To rinse, put the desired amount of dry rice in a container and fill it up with cold water. Use clean hands to sift the rice in the water. Drain and repeat. To soak, put the desired amount of dry rice in a container and fill it up with cold water. Let stand for 30 minutes, and then drain.
2.Mix rice and water in a microwave-safe container. A good place to start is two parts water for every part of rice (e.g., 2 cups rice to 4 cups water). You can adjust the ratio through experimentation, depending on how dry or moist you prefer your rice, the power of your microwave and the size/shape of the container.
3.Enhance the rice with flavor. Add salt, vegetable oil, olive oil or butter before cooking. A teaspoon of salt/vegetable oil or 1/2 tablespoon of butter should do the trick for each cup of rice.
4. Stir the rice mixture slowly with a wooden spoon. Combine the ingredients thoroughly. This is especially important if you have added other ingredients for flavoring.
5.Cover the rice. Place in the microwave and set the timer. Here are some suggested guidelines for a 700 watt microwave and white rice:
  • 1/2 cup rice, 9 minutes
  • 3/4 cup rice, 12 minutes
  • 1 cup rice, 16 minutes
  • 1 1/4 cups rice, 20 minutes
  • 1 1/2 cups rice, 23 minutes6
6. For brown rice, start with three cups of boiling water per cup of rice and cook it for 25 minutes
7. Let the rice sit in the microwave for five minutes after it turns off. Don't open the door. The steam will complete the cooking process. You might observe that the rice grains start to orient themselves vertically, like they're "saluting".
8. Fluff the rice with a fork and serve.
hop you enjoy it
Aug 15, 2014 | Kitchen Appliances - Others
Water got into my Xbox 360 by the fan can I fix it
Let it dry out give it a day or two before plugging it in put it in front of a fan or heater to dry out good. Was the Xbox plugged in when it got the water on it? Once its dryed out you can try plugging it in.If it doesn't power up you probably fried the power supply. But if it was like a glass of water got spilled and some splashed near fan it probably will work. I think there are even some fuses in side the Xbox but you should leave that to a professional. If it doesn't come on once its dryed out
Apr 11, 2012 | Microsoft Video Game Consoles & Games
My grandson spilled some water which got into my mitsibishi tv and created a black spot in the lower left hand corner. How can i fix this?
Take it apart and clean the dried water spots off. Its hard to say if it will work but that's the first thing I would try.
Jul 30, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have surge protector 99021. I spilled water on the surge protector. I let it dry. Both lights are green. Is is safe to plug in the computer
Use something not so expensive to test it first - Like Lamp.
If it works fine and You are sure it's dry - You may use it with computer
Jan 06, 2011 | Computers & Internet
I spilled some water on my tv and now the sound is broken
Turn the TV off imediately. Remove the back cover and heat up the wet area with an hair dryer to thoroughly dry the board. Then try tv again.If it doesnt solve the problem look for the board that the speaker wires connect to and replace that board..You should be able to buy online.
Oct 17, 2009 | Insignia IS-LCDTV32 32 in. Television
I have a RCA big screen tv (model # rca m50wh72s). I accidentally dropped water on the back on the slot that says "cable card slot" on top of the mother board. Now I can't turn on the tv. The fuse is...
Unplug it and allow to dry. It's important that it be unplugged so long as any wetness is present as you can cause further damage. You might use a fan to speed the drying. After the TV is dry you can reconnect to power and try it. If no luck, unplug it and give it some more time. Without the aid of alcohol and compressed air, it can take two days or more to dry the water from under some of the parts. Be patient! or call a servicer.
Jun 20, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Jasjar-no sound-after spilled water on it.
I think you still have a good (not 100%) chance of saving it. It usually takes much longer than 1 day to dry out electronics that are still intact. I would open it up and let it dry. Otherwise, see if have a nerdy friend who has access to a non-humidified incubator and leave it in there for a few days. (that's how I salvaged a phone that went through the wash!)
Aug 31, 2008 | i-mate JASJAR Smartphone
Hitachi P50H401 50 in. Plasma HDTV Logo
105 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
