Ne w brief case, do not know how to lock the combination
    Genius:
  • 1,218 Answers
What has this got to do with FAX machines.???
Posted on Oct 18, 2010
  • Anonymous Oct 18, 2010
    What does this have to do with FAX machines.
I lost the combination and I need to know how to open it without the combination. Help!!!
man I hate this when it happens . to destroy a perfectly good case . saw or grind the lock off .
Dec 09, 2015 | Vaultz Locking VZ01353 SLR Camera Case
Is there an owner's manual available on line for a Stebco Attache Case Model P-16? I need to know how to set the combinations on the dial lock system.
I couldn't find the manual for your particular briefcase, but please read the instructions on the attached link. It should help you since most briefcase combination locks work the same. Hope it helps.
How to Change the Lock Combination on Briefcase
Oct 27, 2014 | Lands Phones
TV LOCKED
If you can come into "set-up" program from the remote,youshould come to a lock on or off. 1234 often works to come the object in function.
Feb 16, 2012 | Televison & Video
I have an old samsoniate vanity case bought about 16 or 17 years ago - it is open but locked with a combination which i have long since forgotten. Can you help me to reset it please
I don't know what you mean by open but locked, however, these locks can be changed to a new combination by sliding a stud inside the case (under the wheels) and holding it while setting new numbers on the wheels. I don't think this works unless you start with the wheels in the position of the old combination, though.
Nov 30, 2010 | Samsonite Tripod
How do I set a new combination if I don't know the oldone. Tehe suitecase is open. tks Leo
What follows are Samsonite's own instructions. Note that they don't work on the new Samsonite CURV though, but you didn't say which case you have:-
"The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
If you still have a problem with the combination lock, contact the nearest authorized repair center to your zip code for repair assistance. Our warranty and repair information can be viewed at http://www.samsonite.com under the heading “Customer Service Repair Centers” for your reference."
Please note that I've simply cut and pasted this answer from an identical question from a few days ago, but it did resolve the question and there's no point in me re-inventing the wheel. If you want to see the original question and answer then please click here.
Please remember to rate both my answer and also whichever of the answers in the original question you wish to vote for.
Feb 14, 2010 | Samsonite Tripod
HELP needed to open combinaiton lock
side latches of my samsonite brei case is open but cant get the combination lock to release
Jan 21, 2010 | Samsonite Case & Tripod Kit for Digital...
I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Oct 16, 2009 | Samsonite Tripod
Samsonite vanity case lock broken
most likely go to your local lock smith
Aug 10, 2009 | Locks & Locksmithing
L'appareil ne fonctionne plus
Ok, je l'espère, ma traduction est correcte s'il vous plaît ne soyez pas offensé si elle ne l'est pas.
Ce que vous devez faire est de retirer les piles et l'alimentation électrique d'attendre environ 10 à 15 minutes, puis mettez-les en puissance et sur le périphérique.
Qu'est-ce que la marque et le modèle d'appareil est-il?
Jan 21, 2009 | Panasonic KX-TG5771 Cordless Phone
19 people viewed this question
jasbo
jasbo
