Question about Car Audio & Video
I need to disconnect my battery from my car ,[mx5 mk 2.5 02 reg] but have not got the rodio code with my paperwork to enter when power is back on ,can you help
  • 70 Answers
Get 2 more battery cords and hook them to the cords that are on the the the battery right now, then hook the new cords to the new battery and disconnect the old battery
Posted on Jun 12, 2008
Can I reset the computer of my Audi A4 cabriolet B6 model,if yes ,what is the procedure.
Which computer (module) are you referring to?
Generally: disconnect the battery for 20 min. This often helps to reset the modules (computers).
Note: if not done, you should look for the radio code. Originally part of the paperwork that came with the car (often a rip out card in the operator manual). Some write it down in the manual. If the radio is without power for a long time, it may be required to enter the code again. If code is not available, the dealer can look it up by VIN number and serial number of the radio (need to remove radio typically to get the serial number).
Jan 12, 2017 | Audi A4 Cars & Trucks
Radio displays "check"
How To Enter The Radio Code On an Audi TT MK 1 ...
? 1:56
www.youtube.com/watch?v=C_3BO9KRBzc
Jan 13, 2013 - Uploaded by Andy Byrne How to enter the 4 digit unlock code in your Audi TT Concertradio if you've disconnected the battery (The ...
Jul 25, 2015 | 2004 Audi TT
How do I code my car radio?
Hi there are 3 things you can do but depends on which car you have 1 the code could be in with your documents paperwork for the car 2 sometimes the code is on the back of the stereo radio and 3 you could call your car main dealer they may need proof of ownership and registration and they should be able to give you the code.
Nov 25, 2014 | Cars & Trucks
No power going to my radio after changing battery. Wanted to check fuses for the radio but I bought the vehicle without an owners manual. I need a fuse diagram for 2004 Ford Expedition please. Thank you
Radio is usually wired as an accessories fuse on the panel. Is it possible there is power but you need to re enter the security code?
If you don't have the paperwork you may be able to get the code from an online site when you enter the make model serial number. It might cost a couple of bucks? Next time you disconnect the battery, make up a couple of leads with croc clips on, wire them to a small 12v battery and connect them to your batt leads before removing the main batt and the small battery will have enough power to keep your radio/ alarm etc working when the main batt is removed.
Jul 21, 2014 | Cars & Trucks
DESIDERATA SEEKING CODE FOR FORD 4000 RDS RADIO
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Ford servicecentre and get them to enter this code for you.
Apr 26, 2012 | Car Audio & Video
Took my factory radio out my 2006 hummer h3 went back to put it in hiked it back up only the lights come on the cd player . . . .not power on
The radio is in theft lock due to being disconnected from power, you (or the original owner) where given the code and instructions on entering it with the owners manual and other new vehicle paperwork. If you do not have this info contact any GM dealer for assistance with obtaining your unique radio security code.
Feb 10, 2012 | Hummer H3 Cars & Trucks
I tried messing with the light switches in my car to cut the yellow lights and brake lights off. No matter what they will not cut off. I hit my keyless entry earlier to unlock the doors and Im thinking...
the thermostat will need to be changed. The light problem may be solved if you first get the code for your car stereo and then disconnect the negative battery cable from the battery for 30 seconds. This should reset the keyless entry system. It will also cause anti-theft stereos to shut down until the proper code is entered. Some car stereos have an anti-theft system where you must enter a code to get the stereo to work again after a loss of power. The code is usually in the paperwork you received when you purchased the car. It may be written down in the owner's manual. But have the code ready before you disconnect the battery.
Feb 10, 2011 | Honda Accord Cars & Trucks
Hi is it possible to get the pin code for a nissan almera reg;NL04 JVD, chassis No sjnfaan16u0485206, i need another key as there was only 1 with the car and no paperwork, thanks Jeff
The only way to get the PIN is to go into a Nissan dealership. Thing is they will definitely ask you for paperwork to prove ownership before they provide you with the information. You may have to go back to your place of purchase and get the necessary paperwork.
Apr 25, 2010 | Vehicle Parts & Accessories
Mazda mx 5 2001 starting problem
have the fault codes read
the problem at the servo could have been EVAP system problem and the non start now could be crank/ cam position sensor or wiring
Apr 26, 2017 | 2001 Mazda MX-5 Miata
Need a master code for audio set
this worked for my 2003 1.6 mx5. I am only posting this as the dealership wanted to charge me £150 to do this - pres in one at a time - 6, AM, AutoM, Seek (up) you should now see -- -- -- -- enter 1414 then press and hold AutoM and 6. good luck. if it doesnt work try these codes instead - 4989, 5011, 0532.
Apr 28, 2009 | Audio Players & Recorders
Car Audio & Video Logo
87 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
