Question about Sony RDR-VX525 DVD Recorder/VCR
Remote control not "talking" to system. Can't finalize DVD because it won't respond. Tried new batteries...any ideas?
  • 998 Answers
Try to check battery terminal that connect the main board of your remote if well contact try to check the led sensor to check the sensor use a camera or your cellphone if had a camera point the sensor in the lens of your camera then press any button you will see a red light that glows if you are not seeing a red light replace the sensor its defective thank you.
Posted on Oct 15, 2010
The remote to my RCA DVD Player, Model DRC220N, has stopped working. I've tried new batteries, hitting the DVD button 1st, etc. Nothing works. The player itself still seems to work as the buttons...
You could try a universal remote (if one is available which will provide most functions to your player, such as STOP/PLAY etc.).
You can try a simple test on your existing RCA remote to see if it provides a 'frequency pulse'. Turn a radio on, select a black section of the AM band (not FM) turn volume up halfway, place remote near it, listen for pips and noises from the speaker(s) - if this occurs, the remote itself is OK. This is the cheapest idea to try first before going out and buying a new remote.
* If the unit does not respond to the universal (regardless of whether a remote code is required or not) then the IRD within the unit itself and its associated controller circuit may have failed (hence why the remote does not work). Repair of this requires a qualified workshop technician (because of the many surface-mounted components in the IRD controller circuit). *
But try the original remote-to-AM-radio test and/or purchase a universal remote or similar if necessary.
May 12, 2011 | RCA DRC220N DVD Player
The buttons on my remote don't work and every time I press on certain buttons it won't respond right away.
Have you tried replacing the batteries? Do you see any damage on the remote? Have you spilled any liquids on it? If the batteries have been replaced and it does not work, you may want to try reprogramming the remote control. If all that fails it may need replacement.
May 05, 2011 | Panasonic EUR7720KY0 Remote Control
Panasonic HT520 remote not responding
Hi.Im Dani from Spain.I have the same pb.To solve this problem-a new one remote.My remote its
a panasonic universal remote control dvd system eur7722x30(i dint find it but i find this:panasonic universal remote control dvd system eur7722x40;i need to see if its compatible(hope so)
This is the link http://cgi.ebay.com/Panasonic-Universal-Remote-Control-DVD-Syste-EUR7722XD0_W0QQitemZ130350261905QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1e597b2691
Good luck
Jan 24, 2010 | Panasonic SC-HT520 System
Unit does not respond to remote control
I had this same problem with the Onkyo TX-SR706 this evening, and finally found the solution in the "Controlling Other Components" section of the manual: Resetting the remote control did the trick. (P.S. This problem started after I spent many hours today trying to get my new Acer laptop equipped with a Hauppauge TV tuner stick to correctly display its image on my Samsung HDTV, with sound. I tried connecting the laptop via HDMI first to the Onkyo receiver and then directly to the TV, neither of which worked as it should. I assume that somehow, in all those hours of much plugging and unplugging and fiddling around, I screwed up the remote sensor -- thank goodness I eventually found the "Resetting the Remote Controller" solution a little while ago -- I was approaching the point of ripping everything apart and throwing it out the window!)
Jul 06, 2009 | Onkyo TX-DS575 Receiver
No response from remote
user manual
FINALLY no need to thank me
User Manual
Aug 31, 2008 | Televison & Video
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 17, 2008 | Samsung HT-Q100 System
Emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 14, 2007 | One For All URC-3021 Remote Control
Remote Control
Go to http://www.remotes.com and get a new remote.
Sep 27, 2006 | LG XBR342 DVD Recorder / VCR Combo
Sony RDR-VX525 DVD Recorder/VCR Logo
105 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
