How do you use lightscribe computer software to burn onto CD/DVD's
  • 707 Answers
Http://www.google.com/search?q=LIGHTSCRIBE+TUTORIAL&hl=en&client=opera&hs=F1H&rls=en&prmd=v&source=univ&tbs=vid:1&tbo=u&ei=Ftm3TNKeO4OKlwed3uTSDA&sa=X&oi=video_result_group&ct=title&resnum=3&ved=0CCgQqwQwAg
Posted on Oct 15, 2010
A freind let me borrow their hp dvd 1040e external 20x multiformat dvd writer. i can burn the music on cds fine with itunes, but i cant figure out how to use the litescribe to burn images on the tops....
You will need Nero burning software. It will after the normal burn show you a screen where you place the image you want to burn for lightscribe. Another failing with lightscribe is that you must have lightscribe discs!
Jul 09, 2011 | HP DVD1040i 20x Super Multiformat Dvd...
Where do i go on my computer to start the light scribe prgram and print? i have a DELL xps with 6 Gig of RaM running windows Vista
You can download the Lightscribe software directly from Lightscribe: http://www.lightscribe.com/downloadsection/windows/index.aspx?id=810
This software package contains all the software need to burn a label on a Lightscribe disc.
Happy Computing, Myridom
Mar 05, 2011 | LG Slimline Ext 8x DVDRW LightScribe...
What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
Lightscribe means you can create a label on a disk.
Check these Links fro more information:
http://en.wikipedia.org/wiki/LightScribe
http://www.lightscribe.com/gettingstarted/index.aspx
Good Luck!!!!!!!!!!!!!!
Sep 18, 2009 | HP Pavilion dv1000 Notebook
I just bought a HP dvd1170 DVD duplicator and I can't get the LightScribe to work. The Lightscribe Control Panel says no devise is found. Did eveyting I can think of.
Hi, HP use Sonic software to burn CD and work with the CD DVD writer. If burn CD using Sonic soon as the CD burn complete the CD will auto matic will eject just turn the up side down and push it back you can burn the text or image to the CD label. I have 3 HP desktop and that's the way I used to burn CD and Lightscribe labeling.
Jul 27, 2009 | Computers & Internet
Burning images to DVDs
you need to launch the lightscribe software, insert the disk upside down (opposite to what we use when burning data into disk), select the image in the software and start burning.
Jul 07, 2009 | Computers & Internet
Why Can't I get my computer to print Lightscribe labels
Try going to www.lightscribe.com and using their program. It works really well for me
Dec 23, 2008 | HP LightScribe dvd640i (DVD640I)...
Is there any way I can burn an image onto a printable cd/dvd using a burner either through my printer or directly from the burner?
1) buy a printer with cd/dvd print tray - like canon 4500, it prints on printable dvd only (printable dvd's have a special white coat to absorb the ink).
2) buy a dvd burner that supports lightscribe like asus drw-1814bl (it prints black only on special coated "lightscribe dvd's"
3) NOT RECOMENDED but also possible, buy cd/dvd labels print on any printer and adhere to cd/dvd, usually over time the glue will destroy cd's and trapped air will make bubbles when the cd/dvd is hot (air expands in hot environment).
Shapirit Computers
050-2330137
www.shapirit.biz
May 04, 2008 | Office Equipment & Supplies
Lightscribe CD Burner
try and reinstall the sonic program if you have it. it sounds like the computer did not have the sonic software on it when you bought it, so it would have been removed when you restored your computer.
Nov 18, 2007 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
