Question about Hitachi VT-RM391A Remote Control
F392, VCR, on playback the video will flash for a second then go to blue screen. I removed the lid and found that when I put just slight pressure on the silver post on the left side and increase then tension a bit the video/sound comes on. How do I fix this?
  • 998 Answers
Try to open it and resolder the main board you will see a crack solder resolder only the the affected parts.
Posted on Oct 15, 2010
I'm trying to transfer VHS film from my Daewoo VCR into my computer to copy it onto a DVD. HI FI flashes on the screen a couple of times and stays for about 10 seconds. How do I get rid of this?
It's an screen display for the Hi-Fi sound playing. However it should only come on when first starting. If it keeps popping up during playback it means that the Hi-Fi sound is dropping out then coming back on. This is often caused by poor tracking or the result of dirt on the video head. Clean the head and see if that solves the problem. If you are doing a lot of tapes keep cleaning it. Few video's have the option to remove on-screen displays. However if they do it will be on the menu somewhere.
Dec 11, 2010 | Daewoo DV-T8DN VHS VCR
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
Gray horizontal lines in playback mode
Gray horizontal lines across the screen in playback is symptom of dirty / clogged video head and you need to use good quality mini-dv video head cleaning tape to clean video head.
Mar 16, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
No playback just blue screen
sounds like the dvc7 needs a cleaning tape.
Sep 24, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hitachi F392 VCR
Do you have the manual?...accordianman
Feb 08, 2008 | Televison & Video
VCR Play Back is OK, but Recording produces Blue Screen on playback
If the heads are TOO dirty, a head cleaner will not help. If you are cinfident enough to open up the recorder, then they can be cleaned manually.
Disconnect the VCR from the mains.
Remove the screews from the side and back (if applicable) of the lid.
Remove the lid.
Look at the large drum (set at a slight angle) If you gently rotate the drum you will see 2 or 4 small sensors set into the drum.
Tear of a clean piece of A4 paper about 1inch square.
Hold between thumb and first finger and rub the centre of the paper against each sensor in turn. Make sure the edge of the paper does not catch the sensor.
After each sensor check the paper for dirt (black marks) and change paper if need be.
Try a recording / playback.
Repeat if necessary.
Nov 08, 2007 | Philips VR330 VHS VCR
Flashing
One possibility is the tracking/audio head is dirty. Remove top cover of VCR, this head sits just to the right of the rotating video head. Use a cotton swab moistened with rubbing alcohol, or other video head cleaner and clean this head, especially the lower edge, as the tracking info is recorded along the lower edge of the tape (if memory serves). Another possibility is a problem with tape travel past this head. If the tape is lifting or moving up or down, even slightly as it passes this head, tracking will be lost, hence your blue screen & bad audio. This could be observed by playing a tape with the VCR cover off.
Jul 10, 2007 | Sharp VC-H982U VHS VCR
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
Oct 31, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
