Question about ViewSonic VX2235wm LCD Monitor
Viewsonic vx2235wm display issues
Hi. I've got a vx2235wm monitor, the picture quality is great....while it's on. After hitting power, the display goes black in aproximately 1 second but the power light stays lit...I've noticed comments for other monitors having this issue and it's either a fuse or capacitor issue in the power area...but the screens that I'm seeing are different for this monitor...could it be the same issue and is there some way to get a more accurate view of what I'd be replacing?
  • zacr Jun 03, 2008
    there aren't any home options to be able to repair this? As I said, there were some others with similar monitors that just had to replace the fuse and one maybe two capacitors but the pictures that were shown were completely different from what I've got but it did the job for them....
Just got this problem. Exactly with the symptoms described.
I swapped out 3 slightly bulged Capacitors in the power supply area.
Sorry, I was meant to write down the exact designations, but only remembered once I put it all back together again. (oops)
The Cappies in question were 3 exactly the same ones.
220uF, 25v ,about 1cm tall and black. Can't miss them.
Posted on Jan 21, 2009
I recently have the same issue. I've ohmed out any fuses I can see (there are many) and looked for obvious cap issues, but no luck. Will get out the scope when I find some time.
While it may be "cheaper" to replace the monitor (done that already), it gnaws at me to have an almost perfect monitor sitting next to a fully equiped wotk bench....
Will update if I find anything.
Posted on Aug 26, 2008
    Genius:
  • ViewSonic Master
  • 1,689 Answers
There are many areas of the LCD monitor that can cause very much the same effect that you see. Most of the time there are capacitors that go defective.
The caps can be tested with an ESR meter. This is a time consuming job. The caps are mostly surface mount types, and will require the proper tools to change them.
Normaly the service centers will change the defective boards rather than try to service them. There is no component level service support for any of these monitors.
In the end, it would be cheaper for you to replace the monitor rather than to fix it.
Jerry G.
Posted on Jun 03, 2008
No power to vx2235wm. How can I fix it?
Black screens or no pictures are usually caused by a failure in the back light power supply. Many times the monitor is working but with the back lights not turning on you can't see the display. Here is a link to a repair guide that will show you how to open the unit and what to look for and replace to rebuild the power supply and bring the unit back to life.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Dec 07, 2011 | ViewSonic VX2235WM Monitor
How to open a viewsonic vx2235wm monitor?
Here is a link to a repair guide with pictures and videos showing how to open the unit and then repair the power supply board that is the most common cause of issues in the VX2235wm monitor.
BuddyMc
Nov 14, 2010 | ViewSonic VX2235wm LCD Monitor
My viewsonic vx2235wm monitor keeps going black and then after a few seconds shows the picture again.. what the heck is wrong??!!
It could be a power-inverter board problem.
These 22s tend to have bulb issues too.
It would have to be opened up to check for possible obvious problems on the power board first.
If you can open it and get me a picture or two of the board to bammbamm@ptd.net, I might be able to see if any obvious troubles are showing.
Aug 18, 2010 | ViewSonic VX2235wm LCD Monitor
Instructions on how to disassemble and fix a Viewsonic VX2235WM
Here is a link to a repair guide that shows how to dis-assembly the unit and that what to look for any replace on the power supply board to repair most problems on the VX2235wm monitors. The repair guide has pictures and videos showing the procedures.
BuddyMc
May 19, 2010 | ViewSonic VX2235WM Monitor
I need sofware of my viewsonic
The links below are two picture of the CD came together with the viewsonic monitor.
http://i590.photobucket.com/albums/ss341/VHC08/VX2235CameraAssistantSoftware.jpg
http://s590.photobucket.com/albums/ss341/VHC08/?action=view&current=VX2235Driver.jpg
If you happen need the driver only viewsonic.com has it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.viewsonic.com/products/archive/vx2235wm.htm
X2235wm User Guide, English PDF: 513KB
The CD contain Camera Assistant Software is only 18M, which is an executable file. The software is not too impressed to me. The other CD is the driver disc. It also has a pdf owner's manual and the Adobe reader 4.0
View More Drivers/Utilities »
Jun 03, 2009 | ViewSonic VX2235WM Monitor
Monitor shows on receiving signal, will not display image.
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or no picture is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 02, 2009 | ViewSonic VX2235WM Monitor
Moniter flips out after it warms up
I repaired my VX2235WM that wouldn't turn the display on anymore (would accept a video signal for a PC, but no image would be shown) by replacing 5 stressed electrolytic capacitors on the power supply board.
Apr 04, 2009 | ViewSonic VX2235WM Monitor
Viewsonic VX2235wm Horizontal Image Problem
Tricky one. Have you tried using different dispay resolutions from your Windows Display Control Panel?
ie 1200x1014, 1600x1400, etc.
When you say you used the manual adjust, do you mean the horizontal sync option?
Did you perform a Settings Recall?
And most monitors have a way of entering into an engineering "Factory Service Menu". Usually by depressing specific buttons while the monitor is OFF, and then pressing the power button while still holding the others. Then let all button go at once. From there, hit the normal button that you use for getting into the OSD. In the OSD, there's usually a new field with all kinds of cool new settings to play with. One of them being a soft reset. You'll have to search the net for how to enter into your Factory service menu.
Oh wait! I know!
If your picture has moved to the right, move yourself accordingly.
So that now you and your picture will be aligned properly.
He he he...
Kidding!
That one was from ViewSonic customer support.
Apr 03, 2009 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235wm working fine on old computer, wrong on new
especially the old drivers. If you didnt remove them then you will have issues.
Dec 19, 2008 | ViewSonic VX2235WM Monitor
ViewSonic VX2235wm LCD Monitor Logo
288 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
